base Directory Reference
Files
file  cs_1d_wall_thermal.cpp
file  cs_1d_wall_thermal.h [code]
file  cs_ale.cpp
file  cs_ale.h [code]
file  cs_algorithm.cpp
file  cs_algorithm.h [code]
file  cs_all_to_all.cpp
file  cs_all_to_all.h [code]
file  cs_array.cpp
file  cs_array.h [code]
file  cs_array_cuda.h [code]
file  cs_array_hip.h [code]
file  cs_array_reduce.cpp
file  cs_array_reduce.h [code]
file  cs_assert.h [code]
file  cs_aster_coupling.cpp
file  cs_aster_coupling.h [code]
file  cs_base.cpp
file  cs_base.h [code]
file  cs_base_accel.cpp
file  cs_base_accel.h [code]
file  cs_base_cuda.h [code]
file  cs_base_headers.h [code]
file  cs_base_hip.cpp
file  cs_base_hip.h [code]
file  cs_block_dist.cpp
file  cs_block_dist.h [code]
file  cs_block_to_part.cpp
file  cs_block_to_part.h [code]
file  cs_boundary.cpp
 Handle the "physical" boundary conditions attached to a computational domain.
file  cs_boundary.h [code]
file  cs_boundary_conditions.cpp
file  cs_boundary_conditions.h [code]
file  cs_boundary_conditions_check.cpp
 Check boundary condition codes.
file  cs_boundary_conditions_check.h [code]
file  cs_boundary_conditions_coupling.cpp
file  cs_boundary_conditions_coupling.h [code]
file  cs_boundary_conditions_priv.h [code]
file  cs_boundary_conditions_set_coeffs.cpp
 Translation of the boundary conditions given by the user in a form that fits the solver.
file  cs_boundary_conditions_set_coeffs.h [code]
file  cs_boundary_conditions_set_coeffs_symmetry.cpp
 Compute the symmetry boundary condition coefficients.
file  cs_boundary_conditions_set_coeffs_symmetry.h [code]
file  cs_boundary_conditions_set_coeffs_turb.cpp
file  cs_boundary_conditions_set_coeffs_turb.h [code]
file  cs_boundary_conditions_type.cpp
file  cs_boundary_conditions_type.h [code]
file  cs_boundary_zone.cpp
file  cs_boundary_zone.h [code]
file  cs_c_bindings.f90
 Definition of C function and subroutine bindings.
file  cs_compute_thermo_pressure_density.cpp
file  cs_compute_thermo_pressure_density.h [code]
file  cs_control.cpp
file  cs_control.h [code]
file  cs_coolprop.cxx
file  cs_coolprop.hxx [code]
file  cs_coupling.cpp
file  cs_coupling.h [code]
file  cs_crystal_router.cpp
file  cs_crystal_router.h [code]
file  cs_cuda_contrib.h [code]
file  cs_cuda_reduce.h [code]
file  cs_debug.h [code]
file  cs_defs.cpp
file  cs_defs.h [code]
file  cs_dilatable_scalar_diff_st.cpp
file  cs_dilatable_scalar_diff_st.h [code]
file  cs_dispatch.h [code]
file  cs_dispatch_queue.h [code]
file  cs_drift_convective_flux.cpp
file  cs_drift_convective_flux.h [code]
file  cs_eos.cxx
file  cs_eos.hxx [code]
file  cs_equation_iterative_solve.cpp
 This file gathers functions that solve advection diffusion equations with source terms for one time step for a scalar, vector or tensor variable.
file  cs_equation_iterative_solve.h [code]
file  cs_execution_context.cpp
file  cs_execution_context.h [code]
file  cs_ext_library_info.cpp
file  cs_ext_library_info.h [code]
file  cs_ext_neighborhood.cpp
file  cs_ext_neighborhood.h [code]
file  cs_fan.cpp
file  cs_fan.h [code]
file  cs_field.cpp
file  cs_field.h [code]
file  cs_field_default.cpp
file  cs_field_default.h [code]
file  cs_field_operator.cpp
file  cs_field_operator.h [code]
file  cs_field_pointer.cpp
file  cs_field_pointer.h [code]
file  cs_file.cpp
file  cs_file.h [code]
file  cs_file_csv_parser.cpp
file  cs_file_csv_parser.h [code]
file  cs_flag_check.cpp
file  cs_flag_check.h [code]
file  cs_fp_exception.cpp
file  cs_fp_exception.h [code]
file  cs_function.cpp
 Function objects management.
file  cs_function.h [code]
file  cs_function_default.cpp
file  cs_function_default.h [code]
file  cs_gas_mix.cpp
file  cs_gas_mix.h [code]
file  cs_halo.cpp
file  cs_halo.h [code]
file  cs_halo_cuda.h [code]
file  cs_halo_hip.cpp
file  cs_halo_hip.h [code]
file  cs_halo_perio.cpp
file  cs_halo_perio.h [code]
file  cs_head_losses.cpp
file  cs_head_losses.h [code]
file  cs_hip_reduce.h [code]
file  cs_ht_convert.cpp
file  cs_ht_convert.h [code]
file  cs_ibm.cpp
file  cs_ibm.h [code]
file  cs_initialize_fields.cpp
 Various field initializations.
file  cs_initialize_fields.h [code]
file  cs_interface.cpp
file  cs_interface.h [code]
file  cs_internal_coupling.cpp
file  cs_internal_coupling.h [code]
file  cs_interpolate.cpp
file  cs_interpolate.h [code]
file  cs_io.cpp
file  cs_io.h [code]
file  cs_log.cpp
file  cs_log.h [code]
file  cs_log_iteration.cpp
 Log field and other array statistics at relevant time steps.
file  cs_log_iteration.h [code]
file  cs_log_setup.cpp
 Setup info at the end of the setup stage.
file  cs_log_setup.h [code]
file  cs_map.cpp
file  cs_map.h [code]
file  cs_mass_source_terms.cpp
file  cs_mass_source_terms.h [code]
file  cs_math.cpp
file  cs_math.h [code]
file  cs_math_hip.h [code]
file  cs_mdspan.h [code]
file  cs_measures_util.cpp
file  cs_measures_util.h [code]
file  cs_medcoupling_intersector.cxx
file  cs_medcoupling_intersector.h [code]
file  cs_medcoupling_mesh.cxx
file  cs_medcoupling_mesh.hxx [code]
file  cs_medcoupling_postprocess.cxx
file  cs_medcoupling_postprocess.h [code]
file  cs_medcoupling_remapper.cxx
file  cs_medcoupling_remapper.h [code]
file  cs_medcoupling_utils.cxx
file  cs_medcoupling_utils.h [code]
file  cs_mem.cpp
file  cs_mem.h [code]
file  cs_mem_cuda_priv.h [code]
file  cs_mem_hip_priv.cpp
 Memory allocation wrappers for HIP.
file  cs_mem_hip_priv.h [code]
file  cs_mobile_structures.cpp
file  cs_mobile_structures.h [code]
file  cs_notebook.cpp
file  cs_notebook.h [code]
file  cs_numbering.cpp
file  cs_numbering.h [code]
file  cs_opts.cpp
file  cs_opts.h [code]
file  cs_order.cpp
file  cs_order.h [code]
file  cs_parall.cpp
file  cs_parall.h [code]
file  cs_param_types.cpp
file  cs_param_types.h [code]
file  cs_paramedmem_coupling.cxx
file  cs_paramedmem_coupling.h [code]
file  cs_paramedmem_coupling_utils.h [code]
file  cs_paramedmem_remapper.cxx
file  cs_paramedmem_remapper.h [code]
file  cs_parameters.cpp
file  cs_parameters.h [code]
file  cs_parameters_check.cpp
file  cs_parameters_check.h [code]
file  cs_part_to_block.cpp
file  cs_part_to_block.h [code]
file  cs_physical_constants.cpp
file  cs_physical_constants.h [code]
file  cs_physical_properties.cpp
file  cs_physical_properties.h [code]
file  cs_physical_properties_default.cpp
file  cs_physical_properties_default.h [code]
file  cs_porosity_from_scan.cpp
file  cs_porosity_from_scan.h [code]
file  cs_porous_model.cpp
 Porous model management.
file  cs_porous_model.h [code]
file  cs_post.cpp
 Post-processing management.
file  cs_post.h [code]
file  cs_post_default.cpp
file  cs_post_default.h [code]
file  cs_post_util.cpp
file  cs_post_util.h [code]
file  cs_preprocess.cpp
file  cs_preprocess.h [code]
file  cs_preprocessor_data.cpp
file  cs_preprocessor_data.h [code]
file  cs_pressure_correction.cpp
file  cs_pressure_correction.h [code]
file  cs_probe.cpp
 Probes and profiles management.
file  cs_probe.h [code]
file  cs_profiling.h [code]
file  cs_prototypes.h [code]
file  cs_random.cpp
file  cs_random.h [code]
file  cs_range_set.cpp
 Operations related to handling of an owning rank for distributed entities.
file  cs_range_set.h [code]
file  cs_rank_neighbors.cpp
file  cs_rank_neighbors.h [code]
file  cs_reducers.h [code]
file  cs_renumber.cpp
file  cs_renumber.h [code]
file  cs_renumber_update.cpp
file  cs_renumber_update.h [code]
file  cs_resource.cpp
 Resource allocation management (available time).
file  cs_resource.h [code]
file  cs_restart.cpp
file  cs_restart.h [code]
file  cs_restart_default.cpp
file  cs_restart_default.h [code]
file  cs_restart_main_and_aux.cpp
file  cs_restart_main_and_aux.h [code]
file  cs_restart_map.cpp
file  cs_restart_map.h [code]
file  cs_rotation.cpp
file  cs_rotation.h [code]
file  cs_runaway_check.cpp
 Runaway (diverging) computation detection.
file  cs_runaway_check.h [code]
file  cs_runge_kutta_integrator.cpp
file  cs_runge_kutta_integrator.h [code]
file  cs_runge_kutta_integrator_param.h [code]
file  cs_sat_coupling.cpp
file  cs_sat_coupling.h [code]
file  cs_scalar_clipping.cpp
 Clipping scalar field.
file  cs_scalar_clipping.h [code]
file  cs_search.cpp
file  cs_search.h [code]
file  cs_selector.cpp
file  cs_selector.h [code]
file  cs_setup.cpp
file  cs_setup.h [code]
file  cs_solid_zone.cpp
file  cs_solid_zone.h [code]
file  cs_solve_all.cpp
file  cs_solve_all.h [code]
file  cs_solve_equation.cpp
 This subroutine performs the solving the convection/diffusion equation (with eventually source terms and/or drift) for a field quantity over a time step.
file  cs_solve_equation.h [code]
file  cs_solve_navier_stokes.cpp
file  cs_solve_navier_stokes.h [code]
file  cs_solve_transported_variables.cpp
 Resolution of source term convection diffusion equations for scalars in a time step.
file  cs_solve_transported_variables.h [code]
file  cs_sort.cpp
file  cs_sort.h [code]
file  cs_sort_partition.cpp
file  cs_sort_partition.h [code]
file  cs_syr_coupling.cpp
file  cs_syr_coupling.h [code]
file  cs_sys_coupling.cpp
file  cs_sys_coupling.h [code]
file  cs_system_info.cxx
file  cs_system_info.h [code]
file  cs_thermal_model.cpp
file  cs_thermal_model.h [code]
file  cs_theta_scheme.cpp
file  cs_theta_scheme.h [code]
file  cs_time_control.cpp
file  cs_time_control.h [code]
file  cs_time_moment.cpp
 Temporal moments management.
file  cs_time_moment.h [code]
file  cs_time_plot.cpp
file  cs_time_plot.h [code]
file  cs_time_step.cpp
file  cs_time_step.h [code]
file  cs_time_step_compute.cpp
 Compute the local time step and the local Courant and Fourier number.
file  cs_time_step_compute.h [code]
file  cs_time_stepping.cpp
 Main time loop.
file  cs_time_stepping.h [code]
file  cs_time_table.cpp
file  cs_time_table.h [code]
file  cs_timer.cpp
file  cs_timer.h [code]
file  cs_timer_stats.cpp
file  cs_timer_stats.h [code]
file  cs_tree.cpp
file  cs_tree.h [code]
file  cs_turbomachinery.cpp
file  cs_turbomachinery.h [code]
file  cs_utilities.cpp
file  cs_utilities.h [code]
file  cs_velocity_pressure.cpp
file  cs_velocity_pressure.h [code]
file  cs_vof.cpp
file  cs_vof.h [code]
file  cs_volume_mass_injection.cpp
file  cs_volume_mass_injection.h [code]
file  cs_volume_zone.cpp
file  cs_volume_zone.h [code]
file  cs_wall_condensation.cpp
file  cs_wall_condensation.h [code]
file  cs_wall_condensation_1d_thermal.cpp
file  cs_wall_condensation_1d_thermal.h [code]
file  cs_wall_distance.cpp
file  cs_wall_distance.h [code]
file  cs_wall_functions.cpp
file  cs_wall_functions.h [code]
file  cs_xdef_eval_at_zone.cpp
file  cs_xdef_eval_at_zone.h [code]
file  cs_zone.h [code]
file  cstnum.f90
 Module for numerical constants.
file  cstphy.f90
 Module for physical constants.
file  field.f90
 Module for field-related operations.
file  iniini.f90
 Commons default initialization before handing over the user.
file  mesh.f90
 Module for mesh-related arrays.
file  optcal.f90
 Module for calculation options.
file  parall.f90
 Module for basic MPI and OpenMP parallelism-related values.
