#include "base/cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include <ple_coupling.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_array.h"#include "base/cs_coupling.h"#include "base/cs_mem.h"#include "base/cs_parall.h"#include "base/cs_prototypes.h"#include "base/cs_selector.h"#include "base/cs_timer.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_connect.h"#include "fvm/fvm_defs.h"#include "fvm/fvm_nodal_from_desc.h"#include "base/cs_paramedmem_coupling_utils.h"
Include dependency graph for cs_paramedmem_coupling.cxx:Functions | |
| cs_paramedmem_coupling_t * | cs_paramedmem_coupling_by_id (int cpl_id) |
| Retrieve coupling struct pointer by id. More... | |
| cs_paramedmem_coupling_t * | cs_paramedmem_coupling_by_name (const char *name) |
| Retrieve coupling struct pointer by name. More... | |
| cs_paramedmem_coupling_t * | cs_paramedmem_coupling_create (const char *app1_name, const char *app2_name, const char *cpl_name, cs_medcpl_dec_t type_dec) |
| Create a new ParaMEDMEM coupling. More... | |
| cs_paramedmem_coupling_t * | cs_paramedmem_coupling_create_uncoupled (const char *cpl_name) |
| Create a new ParaMEDMEM handler structure with no actual coupling. More... | |
| void | cs_paramedmem_coupling_destroy (cs_paramedmem_coupling_t *c) |
| Destroy a given ParaMEDMEM coupling structure. More... | |
| void | cs_paramedmem_coupling_all_finalize (void) |
| Destroy all coupling structures. More... | |
| int | cs_paramedmem_get_number_of_couplings (void) |
| Get number of defined couplings. More... | |
| void | cs_paramedmem_coupling_log_setup (void) |
| Log ParaMEDMEM coupling setup information. More... | |
| void | cs_paramedmem_coupling_all_init (void) |
| initialize couplings based on user functions. More... | |
| void | cs_paramedmem_coupling_define_mesh_fields (void) |
| initialize coupled mesh and fields based on user functions. More... | |
| static constexpr bool | CS_PARAMEDMEM_DBG = false |
| void cs_paramedmem_coupling_all_finalize | ( | void | ) |
| void cs_paramedmem_coupling_all_init | ( | void | ) |
| cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_id | ( | int | cpl_id | ) |
| [in] | cpl_id | index of the sought coupling |
| cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_name | ( | const char * | name | ) |
| [in] | name | name of the coupling |
| cs_paramedmem_coupling_t * cs_paramedmem_coupling_create | ( | const char * | app1_name, |
| const char * | app2_name, | ||
| const char * | cpl_name, | ||
| cs_medcpl_dec_t | type_dec | ||
| [in] | app1_name | Name of app n°1 or null if calling app is app1 |
| [in] | app2_name | Name of app n°2 or null if calling app is app2 |
| [in] | cpl_name | Name of the coupling. If null an automatic name is generated. |
| [in] | type_dec | Type of DEC used for Data exchange |
| cs_paramedmem_coupling_t * cs_paramedmem_coupling_create_uncoupled | ( | const char * | cpl_name | ) |
This can be useful for a "dry run" when setting up a coupling, so as to first debug local commands before actually running in coupled mode.
In this case, data "received" matches the initialized values.
| void cs_paramedmem_coupling_define_mesh_fields | ( | void | ) |
| void cs_paramedmem_coupling_destroy | ( | cs_paramedmem_coupling_t * | c | ) |
| [in] | c | pointer to cs_paramedmem_coupling_t structure |
| void cs_paramedmem_coupling_log_setup | ( | void | ) |
| int cs_paramedmem_get_number_of_couplings | ( | void | ) |
staticconstexpr |
