cs_resource.h
1#ifndef CS_RESOURCE_H
2#define CS_RESOURCE_H
5 * Resource allocation management (available time).
30#include "base/cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "base/cs_base.h"
42/*=============================================================================
43 * Macro Definitions
45
46/*=============================================================================
47 * Type Definitions
49
51 * Global variables
53
54/*============================================================================
55 * Public function prototypes
57
58/*--------------------------------------------------------------------------*/
62/*--------------------------------------------------------------------------*/
63
64void
66(
67 const bool status
68);
69
70/*----------------------------------------------------------------------------*/
76/*----------------------------------------------------------------------------*/
77
78double
80
81/*----------------------------------------------------------------------------*/
87/*----------------------------------------------------------------------------*/
88
89void
91
92/*----------------------------------------------------------------------------*/
100/*----------------------------------------------------------------------------*/
101
102void
104 int *ts_max);
105
106/*----------------------------------------------------------------------------*/
107
108#endif /* CS_RESOURCE_H */
void cs_resource_set_wt_limit(double wt)
Set wall-clock time limit.
Definition: cs_resource.cpp:242
double cs_resource_get_wt_limit(void)
Get current wall-clock time limit.
Definition: cs_resource.cpp:228
void cs_resource_wt_limit_check_set_status(const bool status)
Set wall time limit check to false or true.
Definition: cs_resource.cpp:212
void cs_resource_get_max_timestep(int ts_cur, int *ts_max)
Limit number of remaining time steps if the remaining allocated time is too small to attain the reque...
Definition: cs_resource.cpp:258
