58#define CS_FUNCTION_INTENSIVE (1 << 0)
61#define CS_FUNCTION_EXTENSIVE (1 << 1)
64#define CS_FUNCTION_TIME_INDEPENDENT (1 << 2)
67#define CS_FUNCTION_USER (1 << 3)
70#define CS_FUNCTION_NO_MPI_CALL (1 << 4)
73#define CS_FUNCTION_NO_SUB_TASK (1 << 5)
time step descriptor
Definition: cs_time_step.h:60
cs_datatype_t
Definition: cs_defs.h:290
Definition: cs_defs.h:325
cs_function_t * cs_function_define_by_analytic_func(const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided "degree of freedom" type eval...
Definition: cs_function.cpp:342
cs_function_t * cs_function_define_by_dof_func(const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
Definition: cs_function.cpp:384
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:108
cs_function_t * cs_function_by_name(const char *name)
Return a pointer to a function object based on its name.
Definition: cs_function.cpp:481
void cs_function_set_label(cs_function_t *f, const char *label)
Assig a label to a function object.
Definition: cs_function.cpp:527
cs_function_t * cs_function_define_by_func(const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided evaluation function.
Definition: cs_function.cpp:299
void cs_function_log_defs(void)
Log function definition setup information.
Definition: cs_function.cpp:541
void cs_function_evaluate(const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
Evaluate function values.
Definition: cs_function.cpp:783
void cs_function_log_all_settings(void)
Print info relative to all given function object settings to log file.
Definition: cs_function.cpp:689
cs_function_t * cs_function_by_name_try(const char *name)
Return a pointer to a function object based on its name if present.
Definition: cs_function.cpp:507
int cs_function_n_functions(void)
Return the number of defined functions.
Definition: cs_function.cpp:439
cs_function_t * cs_function_by_id(int id)
Return a pointer to a function object based on its id.
Definition: cs_function.cpp:457
void cs_function_destroy_all(void)
Destroy all functions management metadata.
Definition: cs_function.cpp:410
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_restart_file_t
Definition: cs_restart_default.h:50
char * label
Definition: keywords.h:58
Definition: cs_function.h:117
cs_dof_func_t * dof_func
Definition: cs_function.h:153
const cs_datatype_t datatype
Definition: cs_function.h:131
int log
Definition: cs_function.h:137
cs_eval_at_location_t * eval_func
Definition: cs_function.h:149
const int id
Definition: cs_function.h:123
int post_vis
Definition: cs_function.h:133
const char * name
Definition: cs_function.h:119
cs_restart_file_t restart_file
Definition: cs_function.h:144
int type
Definition: cs_function.h:124
char * label
Definition: cs_function.h:120
const int location_id
Definition: cs_function.h:129
int time_stamp
Definition: cs_function.h:141
cs_analytic_func_t * analytic_func
Definition: cs_function.h:151
void * func_input
Definition: cs_function.h:156
const int dim
Definition: cs_function.h:126
