cs_parameters.h File Reference
#include <stdarg.h>
#include "cdo/cs_equation_param.h"
#include "base/cs_field.h"
#include "base/cs_tree.h"
+ Include dependency graph for cs_parameters.h:
Classes
struct  cs_solving_info_t
struct  cs_space_disc_t
 Space discretisation options descriptor. More...
struct  cs_time_scheme_t
 Time scheme descriptor. More...
struct  cs_restart_auxiliary_t
 Additional checkpoint/restart files. More...
Macros
#define CS_INDEF   CS_UNDEF /* For backward compatibility with 9.0 */
Typedefs
typedef cs_equation_param_t cs_var_cal_opt_t
Enumerations
enum  {
  CS_UNDEF = 1 , CS_INLET = 2 , CS_OUTLET = 3 , CS_SYMMETRY = 4 ,
  CS_SMOOTHWALL = 5 , CS_ROUGHWALL = 6 , CS_ESICF = 7 , CS_SSPCF = 8 ,
  CS_SOPCF = 9 , CS_EPHCF = 10 , CS_EQHCF = 11 , CS_COUPLED = 12 ,
  CS_COUPLED_FD = 13 , CS_FREE_INLET = 14 , CS_FREE_SURFACE = 64 , CS_CONVECTIVE_INLET = 16
enum  {
  CS_DRIFT_SCALAR_ON = (1 << 0) , CS_DRIFT_SCALAR_ADD_DRIFT_FLUX = (1 << 1) , CS_DRIFT_SCALAR_THERMOPHORESIS = (1 << 2) , CS_DRIFT_SCALAR_TURBOPHORESIS = (1 << 3) ,
  CS_DRIFT_SCALAR_ELECTROPHORESIS = (1 << 4) , CS_DRIFT_SCALAR_CENTRIFUGALFORCE = (1 << 5) , CS_DRIFT_SCALAR_IMPOSED_MASS_FLUX = (1 << 6) , CS_DRIFT_SCALAR_ZERO_BNDY_FLUX = (1 << 7) ,
  CS_DRIFT_SCALAR_ZERO_BNDY_FLUX_AT_WALLS = (1 << 8) , CS_DRIFT_SCALAR_NO_MASS_AGGREGATION = (1 << 9)
int cs_parameters_iscavr (cs_field_t *f)
 For a given field, returns the scalar number of the fluctuating field if given field is a variance. More...
cs_space_disc_t * cs_get_glob_space_disc (void)
 Provide access to cs_glob_space_disc. More...
cs_time_scheme_t * cs_get_glob_time_scheme (void)
 Provide access to cs_glob_time_scheme. More...
void cs_parameters_set_init_state_on (int idx)
 Set init state to 1. This is necessary for fortran mapping and should be changed in the future. More...
void cs_parameters_define_field_keys (void)
 Define general field keys. More...
void cs_parameters_read_restart_info (void)
 Read general restart info. More...
void cs_parameters_add_variable (const char *name, int dim)
 Define a user variable. More...
void cs_parameters_add_variable_variance (const char *name, const char *variable_name)
 Define a user variable which is a variance of another variable. More...
void cs_parameters_add_property (const char *name, int dim, int location_id)
 Define a user property. More...
int cs_parameters_n_added_variables (void)
 Return the number of defined user variables not added yet. More...
int cs_parameters_n_added_properties (void)
 Return the number of defined user properties not added yet. More...
void cs_parameters_create_added_variables (void)
 Create previously added user variables. More...
void cs_parameters_define_auxiliary_fields (void)
 Create properties definied directly in C. More...
void cs_parameters_create_added_properties (void)
 Create previously added user properties. More...
void cs_add_model_field_indexes (cs_field_t *f)
 Add field indexes associated with a new non-user solved scalar variable, with default options. More...
cs_field_t * cs_parameters_add_boundary_values (cs_field_t *f)
 Define a boundary values field for a variable field. More...
cs_field_t * cs_parameters_add_boundary_temperature (void)
 Define a boundary values field for temperature, if applicable. More...
bool cs_parameters_need_extended_neighborhood (void)
 Check if extended neighborhood is needed. More...
void cs_parameters_global_complete (void)
 Complete global parameters. More...
void cs_parameters_eqp_complete (void)
 Complete general equation parameter definitions. More...
void cs_parameters_output_complete (void)
 Complete general output options definitions. More...
cs_equation_param_t cs_parameters_equation_param_default (void)
 Return a local equation param structure, with default options. More...
void cs_time_scheme_log_setup (void)
 Print the time scheme structure to setup.log. More...
void cs_space_disc_log_setup (void)
 Print the space discretization structure to setup.log. More...
const cs_space_disc_t * cs_glob_space_disc
const cs_time_scheme_t * cs_glob_time_scheme
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
cs_tree_node_t * cs_glob_tree
◆ CS_INDEF
Typedef Documentation
◆ cs_var_cal_opt_t
◆ anonymous enum
anonymous enum
Enumerator
CS_UNDEF
undefined
CS_INLET
standard inlet
CS_OUTLET
standard outlet
CS_SYMMETRY
CS_SMOOTHWALL
solid wall, with friction
CS_ROUGHWALL
rough wall, with friction
CS_ESICF
compressible flow, prescribed inlet/outlet (for example supersonic inlet)
CS_SSPCF
compressible flow, supersonic outlet
CS_SOPCF
subsonic outlet with prescribed pressure
CS_EPHCF
mixed inlet with prescribed total pressure and enthalpy
CS_EQHCF
subsonic inlet with prescribed mass and enthalpy flow (not available yet)
CS_COUPLED
coupled face
CS_COUPLED_FD
coupled face with decentered flux
CS_FREE_INLET
free outlet or inlet (based on Bernoulli relationship)
CS_FREE_SURFACE
free surface (CS_BOUNDARY_FREE_SURFACE)
CS_CONVECTIVE_INLET
inlet with zero diffusive flux for all transported variables (species and velocity)
◆ anonymous enum
anonymous enum
Enumerator
CS_DRIFT_SCALAR_ON
◆ cs_add_model_field_indexes()
void cs_add_model_field_indexes ( cs_field_t *  f)
[in,out]ffield
◆ cs_get_glob_space_disc()
cs_space_disc_t * cs_get_glob_space_disc ( void  )
space discretization description structure
◆ cs_get_glob_time_scheme()
cs_time_scheme_t * cs_get_glob_time_scheme ( void  )
time scheme information structure
◆ cs_parameters_add_boundary_temperature()
cs_field_t * cs_parameters_add_boundary_temperature ( void  )
When a volume temperature variable field already exists, this amounts to calling cs_parameters_add_boundary_values for that field. When such a variable does not exist but we have an Enthalpy variables, an associated temperature boundary field is returned.
pointer to boundary values field, or null if not applicable
◆ cs_parameters_add_boundary_values()
cs_field_t * cs_parameters_add_boundary_values ( cs_field_t *  f)
[in,out]fpointer to field structure
◆ cs_parameters_add_property()
void cs_parameters_add_property ( const char *  name,
int  dim,
int  location_id
[in]namename of property and associated field
[in]dimproperty dimension
[in]location_idid of associated mesh location
◆ cs_parameters_add_variable()
void cs_parameters_add_variable ( const char *  name,
int  dim
[in]namename of variable and associated field
[in]dimvariable dimension
◆ cs_parameters_add_variable_variance()
void cs_parameters_add_variable_variance ( const char *  name,
const char *  variable_name
[in]namename of variance and associated field
[in]variable_namename of associated variable
◆ cs_parameters_create_added_properties()
void cs_parameters_create_added_properties ( void  )
◆ cs_parameters_create_added_variables()
void cs_parameters_create_added_variables ( void  )
◆ cs_parameters_define_auxiliary_fields()
void cs_parameters_define_auxiliary_fields ( void  )
◆ cs_parameters_define_field_keys()
void cs_parameters_define_field_keys ( void  )
◆ cs_parameters_eqp_complete()
void cs_parameters_eqp_complete ( void  )
Also set associated field properties such as number of associated time values.
◆ cs_parameters_equation_param_default()
cs_equation_param_t cs_parameters_equation_param_default ( void  )
◆ cs_parameters_global_complete()
void cs_parameters_global_complete ( void  )
◆ cs_parameters_iscavr()
int cs_parameters_iscavr ( cs_field_t *  f)
inline
[in]ffield
if f is a variance: scalar number of fluctuating field else if f is not a variance: 0 else if f is the variance of a field that is not a scalar: -1
◆ cs_parameters_n_added_properties()
int cs_parameters_n_added_properties ( void  )
This number is reset to 0 when cs_parameters_create_added_properties() is called.
◆ cs_parameters_n_added_variables()
int cs_parameters_n_added_variables ( void  )
This number is reset to 0 when cs_parameters_create_added_variables() is called.
◆ cs_parameters_need_extended_neighborhood()
bool cs_parameters_need_extended_neighborhood ( void  )
true if extended neighborhoo is needed, false otherwise.
◆ cs_parameters_output_complete()
void cs_parameters_output_complete ( void  )
◆ cs_parameters_read_restart_info()
void cs_parameters_read_restart_info ( void  )
This updates the previous time step info and notebook varaibles values.
◆ cs_parameters_set_init_state_on()
void cs_parameters_set_init_state_on ( int  idx)
[in]idxid of variable. 1 density.
◆ cs_space_disc_log_setup()
void cs_space_disc_log_setup ( void  )
◆ cs_time_scheme_log_setup()
void cs_time_scheme_log_setup ( void  )
◆ cs_glob_restart_auxiliary
cs_restart_auxiliary_t* cs_glob_restart_auxiliary
extern
◆ cs_glob_space_disc
const cs_space_disc_t* cs_glob_space_disc
extern
◆ cs_glob_time_scheme
const cs_time_scheme_t* cs_glob_time_scheme
extern
◆ cs_glob_tree
cs_tree_node_t* cs_glob_tree
extern
Global parameters tree structure
