cs_parall.h File Reference
+ Include dependency graph for cs_parall.h:
Namespaces
namespace  cs
namespace  cs::parall
Enumerations
enum  cs_e2n_sum_t { CS_E2N_SUM_SCATTER , CS_E2N_SUM_GATHER }
static void cs_parall_counter (cs_gnum_t cpt[], const int n)
 Sum values of a counter on all default communicator processes. More...
static void cs_parall_counter_max (cs_lnum_t cpt[], const int n)
 Maximum values of a counter on all default communicator processes. More...
static void cs_parall_sum (int n, cs_datatype_t datatype, void *val)
 Sum values of a given datatype on all default communicator processes. More...
static void cs_parall_max (int n, cs_datatype_t datatype, void *val)
 Maximum values of a given datatype on all default communicator processes. More...
static void cs_parall_min (int n, cs_datatype_t datatype, void *val)
 Minimum values of a given datatype on all default communicator processes. More...
static void cs_parall_bcast (int root_rank, int n, cs_datatype_t datatype, void *val)
 Broadcast values of a given datatype to all default communicator processes. More...
void cs_parall_allgather_r (int n_elts, int n_g_elts, cs_real_t array[], cs_real_t g_array[])
 Build a global array from each local array in each domain. More...
void cs_parall_allgather_ordered_r (int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[])
 Build an ordered global array from each local array in each domain. More...
void cs_parall_gather_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t array[], cs_real_t g_array[])
 Build a global array on the given root rank from all local arrays. More...
void cs_parall_gather_ordered_r (int root_rank, int n_elts, int n_g_elts, int stride, cs_real_t o_key[], cs_real_t array[], cs_real_t g_array[])
 Build an ordered global array on the given root rank from all local arrays. More...
void cs_parall_scatter_r (int root_rank, int n_elts, int n_g_elts, const cs_real_t g_array[], cs_real_t array[])
 Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. More...
void cs_parall_gather_f (int root_rank, int n_elts, int n_g_elts, const float array[], float g_array[])
 Build a global array on the given root rank from all local arrays. Function dealing with single-precision arrays. More...
void cs_parall_scatter_f (int root_rank, int n_elts, int n_g_elts, const float g_array[], float array[])
 Distribute a global array from a given root rank over all ranks. Each rank receive the part related to its local elements. Function dealing with single-precision arrays. More...
void cs_parall_max_loc_vals (int n, cs_real_t *max, cs_real_t max_loc_vals[])
 Maximum value of a real and the value of related array on all default communicator processes. More...
void cs_parall_min_loc_vals (int n, cs_real_t *min, cs_real_t min_loc_vals[])
 Minimum value of a real and the value of related array on all default communicator processes. More...
void cs_parall_min_id_rank_r (cs_lnum_t *elt_id, int *rank_id, cs_real_t val)
 Given an (id, rank, value) tuple, return the local id and rank corresponding to the global minimum value. More...
size_t cs_parall_get_min_coll_buf_size (void)
 Return minimum recommended scatter or gather buffer size. More...
void cs_parall_set_min_coll_buf_size (size_t buffer_size)
 Define minimum recommended scatter or gather buffer size. More...
static int cs_parall_n_threads (cs_lnum_t n_elements, cs_lnum_t min_thread_elements)
 Compute recommended number of threads for a section. More...
static void cs_parall_thread_range (cs_lnum_t n, size_t type_size, cs_lnum_t *s_id, cs_lnum_t *e_id)
 Compute array index bounds for a local thread. When called inside an OpenMP parallel section, this will return the start an past-the-end indexes for the array range assigned to that thread. In other cases, the start index is 1, and the past-the-end index is n;. More...
static void cs_parall_thread_range_upper (cs_lnum_t n, size_t type_size, cs_lnum_t *s_id, cs_lnum_t *e_id)
 Compute array index bounds for a local thread for upper triangular matrix elements. More...
static size_t cs_parall_block_count (size_t n, size_t block_size)
 Compute number of blocks needed for a given array and block sizes. More...
static void cs_parall_counter (const cs_mpi_wrapper &mpi_w, cs_gnum_t cpt[], const int n)
static void cs_parall_counter_max (const cs_mpi_wrapper &mpi_w, cs_lnum_t cpt[], const int n)
static void cs_parall_sum (const cs_mpi_wrapper &mpi_w, int n, cs_datatype_t datatype, void *val)
 Sum values of a given datatype on all of a communicator processes. More...
static void cs_parall_max (const cs_mpi_wrapper &mpi_w, int n, cs_datatype_t datatype, void *val)
static void cs_parall_min (const cs_mpi_wrapper &mpi_w, int n, cs_datatype_t datatype, void *val)
static void cs_parall_thread_range (cs_lnum_t n, size_t type_size, int t_id, int n_t, cs_lnum_t *s_id, cs_lnum_t *e_id)
 Compute array index bounds for a given thread. This will return the start an past-the-end indexes for the array range assigned to that thread. In other cases, the start index is 1, and the past-the-end index is n;. More...
template<typename T , typename... Vals, typename std::enable_if<!std::is_array< T >::value, int >::type = 0>
static void sum (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Sum values of a given datatype over a given communicator. More...
static void sum (T &first, Vals &...values)
template<int Stride, typename T , typename... Vals>
static void sum (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
 Sum strided-values of a given datatype over a communicator. More...
static void sum (T first[], Vals &&... values)
 Sum strided-values of a given datatype on all default communicator processes. More...
template<typename T , int N, typename... Vals>
static void sum (T(&first)[N], Vals &&...values)
 Sum values of a fixed-size C array over the default communicator. More...
static void sum (const cs_mpi_wrapper &mpi_w, T(&first)[N], Vals &&... values)
template<typename T , typename... Vals>
static void max (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Maximum values of a given datatype on a given communicator processes. More...
static void max (T &first, Vals &... values)
static void max (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void max (T first[], Vals &&... values)
static void min (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Minimum values of a given datatype on a given communicator processes. More...
static void min (T &first, Vals &... values)
static void min (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void min (T first[], Vals &&... values)
static void cs_parall_sum_scalars (T &first, Vals &... values)
static void cs_parall_sum_scalars (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
static void cs_parall_sum_strided (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void cs_parall_sum_strided (T first[], Vals &&... values)
static void cs_parall_max_scalars (T &first, Vals &... values)
static void cs_parall_max_scalars (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Maximum values of a given datatype over a communicator. More...
static void cs_parall_max_strided (T first[], Vals &&... values)
static void cs_parall_max_strided (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
static void cs_parall_min_scalars (T &first, Vals &... values)
static void cs_parall_min_scalars (const cs_mpi_wrapper &mpi_w, T &first, Vals &... values)
 Minimum values of a given datatype over a communicator. More...
static void cs_parall_min_strided (T first[], Vals &&... values)
static void cs_parall_min_strided (const cs_mpi_wrapper &mpi_w, T first[], Vals &&... values)
cs_e2n_sum_t cs_glob_e2n_sum_type
◆ cs_e2n_sum_t
Algorithm classes for indirect sums from a graph's edges to its nodes, such as face-to cell sums.
Enumerator
CS_E2N_SUM_SCATTER
Iterate on edges and scatter values to nodes, with data race avoinding numbering or atomics.
CS_E2N_SUM_GATHER
Iterate on nodes and gather (indexed) edge values
◆ cs_parall_allgather_ordered_r()
void cs_parall_allgather_ordered_r ( int  n_elts,
int  n_g_elts,
int  stride,
cs_real_t  o_key[],
cs_real_t  array[],
cs_real_t  g_array[]
Local array elements are ordered based on a given key value (usually some form of coordinate, so the result should be independent of partitioning as long as the definition of the o_key array's defintion is itself independent of the partitioning.
Use of this function may be quite practical, but should be limited to user functions, as it may limit scalability (especially as regards memory usage).
[in]n_eltsnumber of local elements
[in]n_g_eltsnumber of global elements
[in]stridenumber of values per element
[in]o_keyordering key (coordinate) value per element
[in]arraylocal array (size: n_elts*stride)
[out]g_arrayglobal array (size: n_g_elts*stride)
◆ cs_parall_allgather_r()
void cs_parall_allgather_r ( int  n_elts,
int  n_g_elts,
cs_real_t  array[],
cs_real_t  g_array[]
Local arrays are appended in order of owning MPI rank. The size of each local array may be different.
[in]n_eltssize of the local array
[in]n_g_eltssize of the global array
[in]arraylocal array (size: n_elts)
[out]g_arrayglobal array (size: n_g_elts)
◆ cs_parall_bcast()
static void cs_parall_bcast ( int  root_rank,
int  n,
void *  val
inlinestatic
[in]root_rankrank from which to broadcast
[in]nnumber of values
[in]datatypematching code_saturne datatype
[in,out]valvalues to broadcast; input on root_rank, output on others (size: n)
◆ cs_parall_block_count()
static size_t cs_parall_block_count ( size_t  n,
size_t  block_size
inlinestatic
[in]nsize of array
[in]block_sizeblock size for sub-loops
number of required blocks
◆ cs_parall_counter() [1/2]
static void cs_parall_counter ( const cs_mpi_wrapper &  mpi_w,
cs_gnum_t  cpt[],
const int  n
inlinestatic
[in]ecparallel execution context
[in,out]cptlocal counter in, global counter out (size: n)
◆ cs_parall_counter() [2/2]
static void cs_parall_counter ( cs_gnum_t  cpt[],
const int  n
inlinestatic
◆ cs_parall_counter_max() [1/2]
static void cs_parall_counter_max ( const cs_mpi_wrapper &  mpi_w,
cs_lnum_t  cpt[],
const int  n
inlinestatic
◆ cs_parall_counter_max() [2/2]
static void cs_parall_counter_max ( cs_lnum_t  cpt[],
const int  n
inlinestatic
◆ cs_parall_gather_f()
void cs_parall_gather_f ( int  root_rank,
int  n_elts,
int  n_g_elts,
float  g_array[]
[in]root_rankrank which stores the global array
[out]g_arrayglobal array (size: n_g_elts) only usable by the root rank
◆ cs_parall_gather_ordered_r()
void cs_parall_gather_ordered_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
int  stride,
cs_real_t  o_key[],
cs_real_t  array[],
cs_real_t  g_array[]
◆ cs_parall_gather_r()
void cs_parall_gather_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
cs_real_t  g_array[]
◆ cs_parall_get_min_coll_buf_size()
size_t cs_parall_get_min_coll_buf_size ( void  )
This is used by some internal part to block or scatter/gather algorithms, so as to allow I/O buffer size tuning.
minimum recommended part to block or gather buffer size (in bytes)
◆ cs_parall_max() [1/2]
static void cs_parall_max ( const cs_mpi_wrapper &  mpi_w,
int  n,
void *  val
inlinestatic
[in,out]vallocal value input, global value output (array)
◆ cs_parall_max() [2/2]
static void cs_parall_max ( int  n,
void *  val
inlinestatic
◆ cs_parall_max_loc_vals()
void cs_parall_max_loc_vals ( int  n,
cs_real_t *  max,
[in]nsize of the related array
[in,out]maxlocal max in, global max out
[in,out]max_loc_valsarray values at location of local max in, and at location of global max out
◆ cs_parall_max_scalars() [1/2]
static void cs_parall_max_scalars ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
[in]mpi_wParallel execution context
[in,out]firstFirst scalar to update
[in,out]valuesAdditional scalars to update
◆ cs_parall_max_scalars() [2/2]
static void cs_parall_max_scalars ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ cs_parall_max_strided() [1/2]
static void cs_parall_max_strided ( const cs_mpi_wrapper &  mpi_w,
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
stride: stride/dimension of values
[in,out]valuesAdditional values to update
◆ cs_parall_max_strided() [2/2]
static void cs_parall_max_strided ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ cs_parall_min() [1/2]
static void cs_parall_min ( const cs_mpi_wrapper &  mpi_w,
int  n,
void *  val
inlinestatic
◆ cs_parall_min() [2/2]
static void cs_parall_min ( int  n,
void *  val
inlinestatic
◆ cs_parall_min_id_rank_r()
void cs_parall_min_id_rank_r ( cs_lnum_t *  elt_id,
int *  rank_id,
cs_real_t  val
[in,out]elt_idelement id for which the value is the smallest (local in, global out)
[in,out]rank_idrank id for which the value is the smallest (local in, global out)
[in]valassociated local minimum value
◆ cs_parall_min_loc_vals()
void cs_parall_min_loc_vals ( int  n,
cs_real_t *  min,
[in,out]minxlocal min in, global min out
[in,out]min_loc_valsarray values at location of local min in, and at location of global min out
[in,out]minlocal min in, global min out
◆ cs_parall_min_scalars() [1/2]
static void cs_parall_min_scalars ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
[in,out]valuesAdditional scalar to update
◆ cs_parall_min_scalars() [2/2]
static void cs_parall_min_scalars ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ cs_parall_min_strided() [1/2]
static void cs_parall_min_strided ( const cs_mpi_wrapper &  mpi_w,
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
[in,out]firstFirst value to update
◆ cs_parall_min_strided() [2/2]
static void cs_parall_min_strided ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ cs_parall_n_threads()
static int cs_parall_n_threads ( cs_lnum_t  n_elements,
inlinestatic
This is based on the available number of threads, and limited by a minimum number of elements per thread.
[in]n_elementssize of array
[in]min_thread_elementsminimum number of elements per thread.
◆ cs_parall_scatter_f()
void cs_parall_scatter_f ( int  root_rank,
int  n_elts,
int  n_g_elts,
float  array[]
Use of this function may be quite practical, but should be limited to specific usage, as it may limit scalability (especially as regards memory usage).
[in]g_arrayglobal array (size: n_g_elts) only usable by the root rank
[out]arraylocal array (size: n_elts)
◆ cs_parall_scatter_r()
void cs_parall_scatter_r ( int  root_rank,
int  n_elts,
int  n_g_elts,
cs_real_t  array[]
◆ cs_parall_set_min_coll_buf_size()
void cs_parall_set_min_coll_buf_size ( size_t  buffer_size)
[in]buffer_sizeminimum recommended part to block or gather buffer size (in bytes)
◆ cs_parall_sum() [1/2]
static void cs_parall_sum ( const cs_mpi_wrapper &  mpi_w,
int  n,
void *  val
inlinestatic
◆ cs_parall_sum() [2/2]
static void cs_parall_sum ( int  n,
void *  val
inlinestatic
◆ cs_parall_sum_scalars() [1/2]
static void cs_parall_sum_scalars ( const cs_mpi_wrapper &  mpi_w,
T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ cs_parall_sum_scalars() [2/2]
static void cs_parall_sum_scalars ( T &  first,
Vals &...  values
static
Template Parameters
T: datatype
◆ cs_parall_sum_strided() [1/2]
static void cs_parall_sum_strided ( const cs_mpi_wrapper &  mpi_w,
T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ cs_parall_sum_strided() [2/2]
static void cs_parall_sum_strided ( T  first[],
Vals &&...  values
static
Template Parameters
T: datatype
◆ cs_parall_thread_range() [1/2]
static void cs_parall_thread_range ( cs_lnum_t  n,
size_t  type_size,
cs_lnum_t *  s_id,
cs_lnum_t *  e_id
inlinestatic
[in]nsize of array
[in]type_sizeelement type size (or multiple)
[in,out]s_idstart index for the current thread
[in,out]e_idpast-the-end index for the current thread
◆ cs_parall_thread_range() [2/2]
size_t  type_size,
int  t_id,
int  n_t,
cs_lnum_t *  s_id,
cs_lnum_t *  e_id
inlinestatic
[in]nsize of array
[in]t_idthread id
[in]n_tnumber of threads
◆ cs_parall_thread_range_upper()
static void cs_parall_thread_range_upper ( cs_lnum_t  n,
size_t  type_size,
cs_lnum_t *  s_id,
cs_lnum_t *  e_id
inlinestatic
Compared to cs_parall_thread_range, this variant assumes work on the upper triangular part of a matrix, where the lower part is ignored.
[in]nsize of array
◆ cs_glob_e2n_sum_type
extern
