#include "base/cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <EOS/API/EOS.hxx>#include <EOS/API/EOS_Field.hxx>#include <EOS/API/EOS_Fields.hxx>#include <EOS/API/EOS_Error_Field.hxx>#include <EOS/API/EOS_properties.hxx>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_mem.h"#include "cs_eos.hxx"
Include dependency graph for cs_eos.cxx:Functions | |
| DISABLE_WARNING_PUSH static DISABLE_WARNING(-Wcast-qual) DISABLE_WARNING_POP NEPTUNE void | _eos_error_code (const char *function_name, NEPTUNE::EOS_Error return_code) |
| void | cs_eos_create (const char *EOSMethod, char *EOSRef) |
| void | cs_eos_destroy (void) |
| void | cs_phys_prop_eos (cs_phys_prop_thermo_plane_type_t thermo_plane, cs_phys_prop_type_t property, const cs_lnum_t n_vals, double var1[], double var2[], cs_real_t val[]) |
| Computes physical properties in (P,h,Yi) for compressible flow. More... | |
static |
| void cs_eos_create | ( | const char * | EOSMethod, |
| char * | EOSRef | ||
| void cs_eos_destroy | ( | void | ) |
| void cs_phys_prop_eos | ( | cs_phys_prop_thermo_plane_type_t | thermo_plane, |
| cs_phys_prop_type_t | property, | ||
| const cs_lnum_t | n_vals, | ||
| double | var1[], | ||
| double | var2[], | ||
| cs_real_t | val[] | ||
| [in] | thermo_plane | type of thermal plane |
| [in] | property | type of property to compute |
| [in] | n_vals | size of properties arrays |
| [in] | var1 | array of pressure |
| [in] | var2 | array of thermal properties |
| [out] | val | array of property |
