cs_log_iteration.cpp File Reference
Log field and other array statistics at relevant time steps. More...
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "base/cs_array_reduce.h"
#include "base/cs_base.h"
#include "alge/cs_blas.h"
#include "base/cs_dispatch.h"
#include "base/cs_fan.h"
#include "base/cs_field.h"
#include "base/cs_function.h"
#include "base/cs_log.h"
#include "base/cs_map.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_notebook.h"
#include "base/cs_parall.h"
#include "base/cs_range_set.h"
#include "base/cs_reducers.h"
#include "base/cs_time_moment.h"
#include "base/cs_time_plot.h"
#include "lagr/cs_lagr_stat.h"
#include "lagr/cs_lagr_log.h"
#include "fvm/fvm_convert_array.h"
#include "ctwr/cs_ctwr.h"
#include "base/cs_log_iteration.h"
+ Include dependency graph for cs_log_iteration.cpp:
void cs_log_iteration_destroy_all (void)
 Free arrays possible used by logging of array statistics. More...
void cs_log_iteration (void)
 Log field and other array statistics for the current time step. More...
cs_time_control_t * cs_log_iteration_get_time_control (void)
 Retrieve the time control associated to the iteration logging. More...
void cs_log_equation_convergence_info_write (void)
 Default function for equation convergence log info. More...
void cs_log_iteration_set_automatic (int n)
 Set adaptive interval for "per time step" logging information. More...
void cs_log_iteration_set_interval (int n)
 Set interval for "per time step" logging information. More...
void cs_log_iteration_set_active (void)
 Activate or deactivate default log for current iteration. More...
void cs_log_iteration_add_array (const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, const int dim, const cs_real_t val[])
 Add or update array not saved as permanent field to iteration log. More...
void cs_log_iteration_clipping (const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[])
 Add or update clipping info for a given array. More...
void cs_log_iteration_clipping_field (int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[])
 Add or update clipping info for a field. More...
void cs_log_iteration_prepare (void)
 Initialize structures used for logging for new iteration. More...
void cs_log_iteration_l2residual (void)
 Log L2 time residual for variable fields. More...
void cs_log_iteration_log_setup (void)
 Print default log per iteration options to setup.log. More...
◆ cs_log_equation_convergence_info_write()
void cs_log_equation_convergence_info_write ( void  )
◆ cs_log_iteration()
void cs_log_iteration ( void  )
◆ cs_log_iteration_add_array()
void cs_log_iteration_add_array ( const char *  name,
const char *  category,
bool  is_intensive,
const int  dim,
[in]namearray name
[in]categorycategory name
[in]loc_idassociated mesh location id
[in]is_intensiveare the matching values intensive ?
[in]dimassociated dimension (interleaved)
[in]valassociated values
◆ cs_log_iteration_clipping()
void cs_log_iteration_clipping ( const char *  name,
int  dim,
[in]namefield or array name
[in]n_clip_minnumber of local clippings to minimum value
[in]n_clip_maxnumber of local clippings to maximum value
[in]min_pre_clipminimum values prior to clipping
[in]max_pre_clipmaximum values prior to clipping
◆ cs_log_iteration_clipping_field()
void cs_log_iteration_clipping_field ( int  f_id,
[in]f_idassociated field id
[in]n_clip_min_compnumber of clip min by component
[in]n_clip_max_compnumber of clip max by component
◆ cs_log_iteration_destroy_all()
void cs_log_iteration_destroy_all ( void  )
◆ cs_log_iteration_get_time_control()
cs_time_control_t * cs_log_iteration_get_time_control ( void  )
a pointer to the time control structure
◆ cs_log_iteration_l2residual()
void cs_log_iteration_l2residual ( void  )
◆ cs_log_iteration_log_setup()
void cs_log_iteration_log_setup ( void  )
◆ cs_log_iteration_prepare()
void cs_log_iteration_prepare ( void  )
◆ cs_log_iteration_set_active()
void cs_log_iteration_set_active ( void  )
◆ cs_log_iteration_set_automatic()
void cs_log_iteration_set_automatic ( int  n)
Logging will also occur:
  • Each time step for the first n absolute or restarted time steps.
  • Every 5 time steps between n and 5.n time steps.
  • Every 10 time steps between 5.n and 10.n time steps.
  • Every 50 time steps between 10.n and 50.n time steps.
  • Every 100 time steps between 50.n and 100.n time steps.
  • At the last time step
[in]nbase interval for output.
◆ cs_log_iteration_set_interval()
void cs_log_iteration_set_interval ( int  n)
Logging will also occur for the 10 first time steps, as well as the last one.
[in]ninterval between 2 output time steps.
