cs_initialize_fields.cpp File Reference
Various field initializations. More...
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_ale.h"
#include "base/cs_array.h"
#include "base/cs_array_reduce.h"
#include "base/cs_assert.h"
#include "cfbl/cs_cf_model.h"
#include "cfbl/cs_cf_thermo.h"
#include "base/cs_dispatch.h"
#include "base/cs_field.h"
#include "base/cs_gas_mix.h"
#include "gui/cs_gui.h"
#include "gui/cs_gui_mobile_mesh.h"
#include "base/cs_ibm.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parameters_check.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_porosity_from_scan.h"
#include "base/cs_scalar_clipping.h"
#include "base/cs_solve_navier_stokes.h"
#include "turb/cs_turbulence_init.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_vof.h"
#include "atmo/cs_atmo.h"
#include "cogz/cs_combustion_d3p.h"
#include "cogz/cs_combustion_ebu.h"
#include "cogz/cs_combustion_lw.h"
#include "cogz/cs_combustion_slfm.h"
#include "comb/cs_coal_initialize.h"
#include "ctwr/cs_ctwr_initialize.h"
#include "elec/cs_elec_model.h"
#include "base/cs_initialize_fields.h"
+ Include dependency graph for cs_initialize_fields.cpp:
void cs_initialize_fields_stage_0 (void)
 Computed variable and property initialization. More...
void cs_initialize_fields_stage_1 (void)
 Initialize variable, time step, and wall distance fields. More...
◆ cs_initialize_fields_stage_0()
void cs_initialize_fields_stage_0 ( void  )
The time step, the indicator of wall distance computation are also initialized just before reading a restart file or use the user initializations.
◆ cs_initialize_fields_stage_1()
void cs_initialize_fields_stage_1 ( void  )
