1#ifndef CS_VELOCITY_PRESSURE_H
2#define CS_VELOCITY_PRESSURE_H
Definition: cs_time_control.h:92
cs_velocity_pressure_model_t cs_stokes_model_t
Definition: cs_velocity_pressure.h:194
void cs_velocity_pressure_set_n_buoyant_scalars(void)
Definition: cs_velocity_pressure.cpp:391
void cs_velocity_pressure_param_log_setup(void)
Print Velocity-pressure parameters to setup.log.
Definition: cs_velocity_pressure.cpp:512
cs_velocity_pressure_param_t cs_piso_t
Definition: cs_velocity_pressure.h:195
cs_velocity_pressure_param_t * cs_get_glob_velocity_pressure_param(void)
Provide access to cs_glob_velocity_pressure_param.
Definition: cs_velocity_pressure.cpp:379
void cs_velocity_pressure_set_solid(void)
Definition: cs_velocity_pressure.cpp:415
cs_velocity_pressure_model_t * cs_get_glob_velocity_pressure_model(void)
Definition: cs_velocity_pressure.cpp:363
const cs_velocity_pressure_param_t * cs_glob_velocity_pressure_param
const cs_velocity_pressure_model_t * cs_glob_velocity_pressure_model
void cs_velocity_pressure_model_log_setup(void)
Print the stokes model parameters to setup.log.
Definition: cs_velocity_pressure.cpp:436
Stokes equation model descriptor.
Definition: cs_velocity_pressure.h:49
int ivisse
Definition: cs_velocity_pressure.h:51
int idilat
Definition: cs_velocity_pressure.h:56
int n_buoyant_scal
Definition: cs_velocity_pressure.h:68
bool fluid_solid
Definition: cs_velocity_pressure.h:64
int iprcdo
Definition: cs_velocity_pressure.h:71
Inner velocity/pressure iteration options descriptor.
Definition: cs_velocity_pressure.h:81
int icalhy
Definition: cs_velocity_pressure.h:91
int irevmc
Definition: cs_velocity_pressure.h:107
double arak
Definition: cs_velocity_pressure.h:149
double epsdp
Definition: cs_velocity_pressure.h:186
double xnrmu
Definition: cs_velocity_pressure.h:179
int iifren
Definition: cs_velocity_pressure.h:113
int igrdpp
Definition: cs_velocity_pressure.h:135
int ipredfl
Definition: cs_velocity_pressure.h:102
int nterup
Definition: cs_velocity_pressure.h:172
double xnrmu0
Definition: cs_velocity_pressure.h:184
int ipucou
Definition: cs_velocity_pressure.h:141
cs_time_control_t time_control
Definition: cs_velocity_pressure.h:188
int rcfact
Definition: cs_velocity_pressure.h:152
int update_p_bc_after_prediction
Definition: cs_velocity_pressure.h:162
int igpust
Definition: cs_velocity_pressure.h:129
int iprco
Definition: cs_velocity_pressure.h:97
double epsup
Definition: cs_velocity_pressure.h:175
int igprij
Definition: cs_velocity_pressure.h:124
int iphydr
Definition: cs_velocity_pressure.h:83
int staggered
Definition: cs_velocity_pressure.h:157
int irecmf
Definition: cs_velocity_pressure.h:117
int itpcol
Definition: cs_velocity_pressure.h:145
