cs_param_types.cpp File Reference
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_log.h"
#include "base/cs_param_types.h"
+ Include dependency graph for cs_param_types.cpp:
Macros
#define CS_PARAM_TYPES_DBG   0
bool cs_param_space_scheme_is_face_based (cs_param_space_scheme_t scheme)
 Return true if the space scheme has degrees of freedom on faces, otherwise false. More...
const char * cs_param_get_space_scheme_name (cs_param_space_scheme_t scheme)
 Get the name of the space discretization scheme. More...
const char * cs_param_get_time_scheme_name (cs_param_time_scheme_t scheme)
 Get the name of the time discretization scheme. More...
const char * cs_param_get_advection_form_name (cs_param_advection_form_t adv_form)
 Get the label associated to the advection formulation. More...
const char * cs_param_get_advection_scheme_name (cs_param_advection_scheme_t scheme)
 Get the label of the advection scheme. More...
const char * cs_param_get_advection_strategy_name (cs_param_advection_strategy_t adv_stra)
 Get the label associated to the advection strategy. More...
const char * cs_param_get_advection_extrapol_name (cs_param_advection_extrapol_t extrapol)
 Get the label associated to the extrapolation used for the advection field. More...
const char * cs_param_get_bc_name (cs_param_bc_type_t type)
 Get the name of the type of boundary condition. More...
const char * cs_param_get_bc_enforcement_name (cs_param_bc_enforce_t type)
 Get the name of the type of enforcement of the boundary condition. More...
const char * cs_param_get_nl_algo_name (cs_param_nl_algo_t algo)
 Get the name of the non-linear algorithm. More...
const char * cs_param_get_nl_algo_label (cs_param_nl_algo_t algo)
 Get the label (short name) of the non-linear algorithm. More...
const char * cs_param_get_solver_name (cs_param_solver_type_t solver)
 Get the name of the solver. More...
const char * cs_param_get_precond_name (cs_param_precond_type_t precond)
 Get the name of the preconditioner. More...
const char * cs_param_get_precond_block_name (cs_param_precond_block_t type)
 Get the name of the type of block preconditioning. More...
const char cs_sep_h1 [80]
const char cs_sep_h2 [80]
const char cs_sepline [80]
const char cs_med_sepline [50]
◆ CS_PARAM_TYPES_DBG
◆ cs_param_get_advection_extrapol_name()
const char * cs_param_get_advection_extrapol_name ( cs_param_advection_extrapol_t  extrapol)
[in]extrapoltype of extrapolation for the advection field
the associated label
◆ cs_param_get_advection_form_name()
const char * cs_param_get_advection_form_name ( cs_param_advection_form_t  adv_form)
[in]adv_formtype of advection formulation
◆ cs_param_get_advection_scheme_name()
const char * cs_param_get_advection_scheme_name ( cs_param_advection_scheme_t  scheme)
[in]schemetype of advection scheme
the associated advection scheme label
◆ cs_param_get_advection_strategy_name()
const char * cs_param_get_advection_strategy_name ( cs_param_advection_strategy_t  adv_stra)
[in]adv_stratype of advection strategy
◆ cs_param_get_bc_enforcement_name()
const char * cs_param_get_bc_enforcement_name ( cs_param_bc_enforce_t  type)
[in]typetype of enforcement of boundary conditions
the associated name
◆ cs_param_get_bc_name()
const char * cs_param_get_bc_name ( cs_param_bc_type_t  type)
[in]typetype of boundary condition
the associated bc name
◆ cs_param_get_nl_algo_label()
const char * cs_param_get_nl_algo_label ( cs_param_nl_algo_t  algo)
[in]algotype of algorithm
the associated algorithm label
◆ cs_param_get_nl_algo_name()
const char * cs_param_get_nl_algo_name ( cs_param_nl_algo_t  algo)
the associated algorithm name
◆ cs_param_get_precond_block_name()
const char * cs_param_get_precond_block_name ( cs_param_precond_block_t  type)
[in]typetype of block preconditioning
the associated type name
◆ cs_param_get_precond_name()
const char * cs_param_get_precond_name ( cs_param_precond_type_t  precond)
[in]precondtype of preconditioner
the associated preconditioner name
◆ cs_param_get_solver_name()
const char * cs_param_get_solver_name ( cs_param_solver_type_t  solver)
[in]solvertype of iterative solver
the associated solver name
◆ cs_param_get_space_scheme_name()
const char * cs_param_get_space_scheme_name ( cs_param_space_scheme_t  scheme)
[in]schemetype of space scheme
the associated space scheme name
◆ cs_param_get_time_scheme_name()
const char * cs_param_get_time_scheme_name ( cs_param_time_scheme_t  scheme)
[in]schemetype of time scheme
the associated time scheme name
◆ cs_param_space_scheme_is_face_based()
bool cs_param_space_scheme_is_face_based ( cs_param_space_scheme_t  scheme)
true or false
◆ cs_med_sepline
const char cs_med_sepline[50]
Initial value:
"# ========================================\n"
◆ cs_sep_h1
const char cs_sep_h1[80]
Initial value:
"=======================================================================\n"
◆ cs_sep_h2
const char cs_sep_h2[80]
Initial value:
"-----------------------------------------------------------------------\n"
◆ cs_sepline
const char cs_sepline[80]
Initial value:
"# =====================================================================\n"
