cs_runge_kutta_integrator.cpp File Reference
#include <stdarg.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_dispatch.h"
#include "base/cs_runge_kutta_integrator.h"
#include "base/cs_runge_kutta_integrator_param.h"
+ Include dependency graph for cs_runge_kutta_integrator.cpp:
int cs_runge_kutta_integrator_create (cs_runge_kutta_scheme_t scheme, const char *name, const cs_real_t *dt, int dim, cs_lnum_t n_elts)
 Create a RK integrator. More...
void cs_runge_kutta_integrators_initialize ()
 Create RK integrator structures. More...
cs_runge_kutta_integrator_t * cs_runge_kutta_integrator_by_id (int rk_id)
 Return a Runge-Kutta integrator by id. More...
void cs_runge_kutta_integrators_destroy ()
 Clean all Runge-Kutta integrators. More...
void cs_runge_kutta_staging_potential (cs_dispatch_context &ctx, cs_runge_kutta_integrator_t *rk, cs_real_t *phi_stage)
 Perform one Runge-Kutta staging for the potential in the NS system. More...
void cs_runge_kutta_stage_complete_scalar_rhs (cs_dispatch_context &ctx, cs_runge_kutta_integrator_t *rk, int idtvar, int f_id, int imucpp, cs_equation_param_t *eqp, cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t i_massflux[], const cs_real_t b_massflux[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_t viscel[][6], const cs_real_t weighf[][2], const cs_real_t weighb[], int icvflb, const int icvfli[], cs_real_t pvar[], const cs_real_t xcpp[])
 prepare and complete rhs per stage for Runge-Kutta integrator. Align with legacy equations' building sequence. 1) Collect initial rhs done in cs_solve_navier_stokes/cs_solve_equation_scalar 2) Complete rhs with adding explicit part of the convection/diffusion balance More precisely, the right hand side $ \vect{Rhs} $ is updated as follows: More...
cs_runge_kutta_integrator_t ** _rk_lst = nullptr
int _n_rk_integrators = 0
◆ cs_runge_kutta_integrator_by_id()
cs_runge_kutta_integrator_t * cs_runge_kutta_integrator_by_id ( int  rk_id)
◆ cs_runge_kutta_integrator_create()
int cs_runge_kutta_integrator_create ( cs_runge_kutta_scheme_t  scheme,
const char *  name,
const cs_real_t *  dt,
int  dim,
cs_lnum_t  n_elts
[in]schemeRK scheme type (RK_NONE, RK1, RK2, RK3, RK4)
[in]nameassociated equation or field's name
[in]dttime step
[in]dimvariable dimension
[in]n_eltsnumber of computational elements
return the RK integrator's id in the RK list
◆ cs_runge_kutta_integrators_destroy()
void cs_runge_kutta_integrators_destroy ( )
◆ cs_runge_kutta_integrators_initialize()
void cs_runge_kutta_integrators_initialize ( )
◆ cs_runge_kutta_stage_complete_scalar_rhs()
void cs_runge_kutta_stage_complete_scalar_rhs ( cs_dispatch_context &  ctx,
cs_runge_kutta_integrator_t *  rk,
int  idtvar,
int  f_id,
int  imucpp,
cs_equation_param_t *  eqp,
cs_field_bc_coeffs_t *  bc_coeffs,
int  icvflb,
const int  icvfli[],
cs_real_t  pvar[],
\vect{Rhs} = \vect{Rhs} - \sum_{\fij \in \Facei{\celli}}      \left(
       \dot{m}_\ij \left( \vect{\varia}_\fij - \vect{\varia}_\celli \right)
     - \mu_\fij \gradt_\fij \vect{\varia} \cdot \vect{S}_\ij  \right)
Warning:
  • $ \vect{Rhs} $ has already been initialized before calling cs_balance_vector!
  • mind the sign minus
[in]ctxReference to dispatch context
[in,out]rkpointer to a Runge-Kutta integrator
[in]idtvarindicator of the temporal scheme
[in]f_idfield id (or -1)
[in]imucppindicator
  • 0 do not multiply the convectiv term by Cp
  • 1 do multiply the convectiv term by Cp
[in]eqppointer to a cs_equation_param_t structure which contains variable calculation options
[in]bc_coeffsboundary condition structure for the variable
[in]i_massfluxmass flux at interior faces
[in]b_massfluxmass flux at boundary faces
[in]i_visc$ \mu_\fij \dfrac{S_\fij}{\ipf \jpf} $ at interior faces for the r.h.s.
[in]b_visc$ \mu_\fib \dfrac{S_\fib}{\ipf \centf} $ at boundary faces for the r.h.s.
[in]viscelsymmetric cell tensor $ \tens{\mu}_\celli $
[in]weighfinternal face weight between cells i j in case of tensor diffusion
[in]weighbboundary face weight for cells i in case of tensor diffusion
[in]icvflbglobal indicator of boundary convection flux
  • 0 upwind scheme at all boundary faces
  • 1 imposed flux at some boundary faces
[in]icvfliboundary face indicator array of convection flux
  • 0 upwind scheme
  • 1 imposed flux
[in]pvarsolved variable (current time step)
[in]xcpparray of specific heat (Cp)
◆ cs_runge_kutta_staging_potential()
void cs_runge_kutta_staging_potential ( cs_dispatch_context &  ctx,
cs_real_t *  phi_stage
[in,out]phi_stagehigh level variable array along stages
◆ _n_rk_integrators
◆ _rk_lst
cs_runge_kutta_integrator_t** _rk_lst = nullptr
