cs_resource.cpp File Reference
Resource allocation management (available time). More...
#include <errno.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_math.h"
#include "base/cs_timer.h"
#include "base/cs_resource.h"
+ Include dependency graph for cs_resource.cpp:
void cs_resource_wt_limit_check_set_status (const bool status)
 Set wall time limit check to false or true. More...
double cs_resource_get_wt_limit (void)
 Get current wall-clock time limit. More...
void cs_resource_set_wt_limit (double wt)
 Set wall-clock time limit. More...
void cs_resource_get_max_timestep (int ts_cur, int *ts_max)
 Limit number of remaining time steps if the remaining allocated time is too small to attain the requested number of steps. More...
◆ cs_resource_get_max_timestep()
void cs_resource_get_max_timestep ( int  ts_cur,
int *  ts_max
[in]ts_curcurrent time step number
[in,out]ts_maxmaximum time step number
◆ cs_resource_get_wt_limit()
double cs_resource_get_wt_limit ( void  )
current wall-time limit (in seconds), or -1
◆ cs_resource_set_wt_limit()
void cs_resource_set_wt_limit ( double  wt)
[in]wtwall-time limit (in seconds), or -1
◆ cs_resource_wt_limit_check_set_status()
void cs_resource_wt_limit_check_set_status ( const bool  status)
[in]statusstatus to set (activation or deactivation)
