cs_halo.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_base_accel.h"
#include "base/cs_interface.h"
#include "base/cs_mem.h"
#include "base/cs_order.h"
#include "base/cs_rank_neighbors.h"
#include "fvm/fvm_periodicity.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
+ Include dependency graph for cs_halo.cpp:
cs_halo_t * cs_halo_create (const cs_interface_set_t *ifs)
 Create a halo structure given an interface set. More...
void cs_halo_create_complete (cs_halo_t *halo)
 Ready halo for use. More...
cs_halo_t * cs_halo_create_from_ref (const cs_halo_t *ref)
 Create a halo structure, given a reference halo. More...
cs_halo_t * cs_halo_create_from_rank_neighbors (const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_idx[], const cs_lnum_t elt_id[], const int16_t elt_tr_id[], const fvm_periodicity_t *periodicity)
 Create a halo structure from distant element distant ranks and ids. More...
cs_halo_t * cs_halo_create_from_rank_neighbors (const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_idx[], const cs_lnum_t elt_id[])
void cs_halo_destroy (cs_halo_t **halo)
cs_halo_state_t * cs_halo_state_create (void)
 Create a halo state structure. More...
void cs_halo_state_destroy (cs_halo_state_t **halo_state)
 Destroy a halo state structure. More...
cs_halo_state_t * cs_halo_state_get_default (void)
 Get pointer to default halo state structure. More...
void cs_halo_renumber_cells (cs_halo_t *halo, const cs_lnum_t new_cell_id[])
void cs_halo_renumber_ghost_cells (cs_halo_t *halo, const cs_lnum_t old_cell_id[])
void * cs_halo_sync_pack_init_state (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *send_buf, cs_halo_state_t *hs)
 Initialize halo state prior to packing halo data to send. More...
void cs_halo_sync_pack (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val, void *send_buf, cs_halo_state_t *hs)
 Pack halo data to send into dense buffer. More...
void cs_halo_sync_start (const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
 Launch update array of values in case of parallelism or periodicity. More...
void cs_halo_sync_wait (const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
 Wait for completion of update array of values in case of parallelism or periodicity. More...
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val)
 Update array of values in case of parallelism or periodicity. More...
void cs_halo_sync_untyped (const cs_halo_t *halo, cs_halo_type_t sync_mode, size_t size, void *val)
void cs_halo_sync_num (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_lnum_t num[])
void cs_halo_sync_var (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
void cs_halo_sync_var_strided (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[], int stride)
bool cs_halo_get_use_barrier (void)
void cs_halo_set_use_barrier (bool use_barrier)
cs_halo_comm_mode_t cs_halo_get_comm_mode (void)
 Get default communication mode for halo exchange. More...
void cs_halo_set_comm_mode (cs_halo_comm_mode_t mode)
 Set default communication mode for halo exchange. More...
cs_alloc_mode_t cs_halo_get_buffer_alloc_mode (void)
 Get default host/device allocation mode for message packing arrays. More...
void cs_halo_set_buffer_alloc_mode (cs_alloc_mode_t mode)
 Set default host/device allocation mode for message packing arrays. More...
void * cs_halo_get_default_buffer (size_t size)
 Return pointer to working send buffer used by default halo state. More...
void cs_halo_dump (const cs_halo_t *halo, int print_level)
template<typename T >
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[])
template void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[])
template void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_lnum_t val[])
template<int Stride, typename T >
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][Stride])
template void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][2])
template void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][3])
template void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][6])
void cs_halo_sync (const cs_halo_t *halo, bool on_device, T val[])
template void cs_halo_sync (const cs_halo_t *halo, bool on_device, cs_real_t val[])
template void cs_halo_sync (const cs_halo_t *halo, bool on_device, int val[])
void cs_halo_sync (const cs_halo_t *halo, bool on_device, T val[][Stride])
template void cs_halo_sync (const cs_halo_t *halo, bool on_device, cs_real_t val[][2])
template void cs_halo_sync (const cs_halo_t *halo, bool on_device, cs_real_t val[][3])
template void cs_halo_sync (const cs_halo_t *halo, bool on_device, cs_real_t val[][6])
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][3])
 Update ghost cell values of a spatial vector field, including rotational periodicity if present. More...
template void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][3])
template void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, float val[][3])
void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, T val[][3])
template void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, cs_real_t val[][3])
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][6])
 Update ghost cell values of a symmetric tensor field, including rotational periodicity if present. More...
template void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][6])
void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, T val[][6])
template void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, cs_real_t val[][6])
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][3][3])
 Update ghost cell values of a non-symmetric tensor field, including rotational periodicity if present. More...
template void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_real_t val[][3][3])
◆ cs_halo_create()
cs_halo_t * cs_halo_create ( const cs_interface_set_t *  ifs)
[in]ifspointer to a cs_interface_set structure
pointer to created cs_halo_t structure
◆ cs_halo_create_complete()
void cs_halo_create_complete ( cs_halo_t *  halo)
Ready halo for use.
This function should be called after building a halo using the cs_halo_create_function and defined locally. It is called automatically by cs_halo_create_from_ref and cs_halo_create_from_rank_neighbors so does not need to be called again using these functions.
[in]halopointer to halo structure
◆ cs_halo_create_from_rank_neighbors() [1/2]
cs_halo_t * cs_halo_create_from_rank_neighbors ( const cs_rank_neighbors_t *  rn,
[in]rnassociated rank neighbors info
[in]n_local_eltsnumber of elements for local rank
[in]n_distant_eltsnumber of distant elements for local rank
[in]elt_rank_idxdistant element rank index in rank neighbors, ordered by rank (size: n_distant_elts)
[in]elt_iddistant element id (at distant rank), ordered by rank (size: n_distant_elts)
◆ cs_halo_create_from_rank_neighbors() [2/2]
const fvm_periodicity_t *  periodicity
[in]elt_tr_iddistant element transform id (-1 for non-periodic elements), null if non-periodic
[in]periodicityoptional periodicity, or null
◆ cs_halo_create_from_ref()
cs_halo_t * cs_halo_create_from_ref ( const cs_halo_t *  ref)
[in]refpointer to reference halo
◆ cs_halo_destroy()
void cs_halo_destroy ( cs_halo_t **  halo)
brief Destroy a halo structure.
[in,out]halopointer to pointer to cs_halo structure to destroy.
◆ cs_halo_dump()
void cs_halo_dump ( const cs_halo_t *  halo,
int  print_level
◆ cs_halo_get_buffer_alloc_mode()
cs_alloc_mode_t cs_halo_get_buffer_alloc_mode ( void  )
allocation mode
◆ cs_halo_get_comm_mode()
cs_halo_comm_mode_t cs_halo_get_comm_mode ( void  )
allocation mode
◆ cs_halo_get_default_buffer()
void * cs_halo_get_default_buffer ( size_t  size)
This allows sharing the allocation with other operations which might be used frequently, such as range set scatters (which play a similar role to halos for data which can be on process boundaries, such as vertex or face-based data).
If the current buffer's size is smaller than the requested size, it is increased.
Warning
The returned buffer should not be used while a halo exchange using the default halo state is in progress.
] halo pointer to pointer to cs_halo structure to destroy.
◆ cs_halo_get_use_barrier()
bool cs_halo_get_use_barrier ( void  )
◆ cs_halo_renumber_cells()
void cs_halo_renumber_cells ( cs_halo_t *  halo,
◆ cs_halo_renumber_ghost_cells()
void cs_halo_renumber_ghost_cells ( cs_halo_t *  halo,
◆ cs_halo_set_buffer_alloc_mode()
void cs_halo_set_buffer_alloc_mode ( cs_alloc_mode_t  mode)
[in]modeallocation mode to set
◆ cs_halo_set_comm_mode()
void cs_halo_set_comm_mode ( cs_halo_comm_mode_t  mode)
◆ cs_halo_set_use_barrier()
void cs_halo_set_use_barrier ( bool  use_barrier)
◆ cs_halo_state_create()
cs_halo_state_t * cs_halo_state_create ( void  )
pointer to created cs_halo_state_t structure.
◆ cs_halo_state_destroy()
void cs_halo_state_destroy ( cs_halo_state_t **  halo_state)
[in,out]halo_statepointer to pointer to cs_halo_state structure to destroy.
◆ cs_halo_state_get_default()
cs_halo_state_t * cs_halo_state_get_default ( void  )
◆ cs_halo_sync() [1/15]
template void cs_halo_sync ( const cs_halo_t *  halo,
bool  on_device,
cs_real_t  val[]
◆ cs_halo_sync() [2/15]
bool  on_device,
cs_real_t  val[][2]
◆ cs_halo_sync() [3/15]
bool  on_device,
cs_real_t  val[][3]
◆ cs_halo_sync() [4/15]
bool  on_device,
cs_real_t  val[][6]
◆ cs_halo_sync() [5/15]
bool  on_device,
int  val[]
◆ cs_halo_sync() [6/15]
bool  on_device,
T  val[]
◆ cs_halo_sync() [7/15]
bool  on_device,
T  val[][Stride]
◆ cs_halo_sync() [8/15]
bool  on_device,
cs_lnum_t  val[]
◆ cs_halo_sync() [9/15]
bool  on_device,
cs_real_t  val[]
◆ cs_halo_sync() [10/15]
bool  on_device,
cs_real_t  val[][2]
◆ cs_halo_sync() [11/15]
bool  on_device,
cs_real_t  val[][3]
◆ cs_halo_sync() [12/15]
bool  on_device,
cs_real_t  val[][6]
◆ cs_halo_sync() [13/15]
bool  on_device,
T  val[]
This function aims at copying main values from local elements (id between 1 and n_local_elements) to ghost elements on distant ranks (id between n_local_elements + 1 to n_local_elements_with_halo).
Template Parameters
in] T value type
[in]sync_modesynchronization mode (standard or extended)
[in]on_devicerun on accelerated device if possible
[in,out]valpointer to variable value array
◆ cs_halo_sync() [14/15]
bool  on_device,
T  val[][Stride]
◆ cs_halo_sync() [15/15]
int  stride,
void *  val
[in]data_typedata type
[in]stridenumber of (interlaced) values by entity
[in]valpointer to variable value array
◆ cs_halo_sync_num()
void cs_halo_sync_num ( const cs_halo_t *  halo,
cs_lnum_t  num[]
◆ cs_halo_sync_pack()
void cs_halo_sync_pack ( const cs_halo_t *  halo,
int  stride,
void *  val,
void *  send_buf,
cs_halo_state_t *  hs
A local state handler may be provided, or the default state handler will be used.
A local state and/or buffer may be provided, or the default (global) state and buffer will be used. If provided explicitely, the buffer must be of sufficient size.
[out]send_bufpointer to send buffer, null for global buffer
[in,out]hspointer to halo state, null for global state
◆ cs_halo_sync_pack_init_state()
void * cs_halo_sync_pack_init_state ( const cs_halo_t *  halo,
int  stride,
void *  send_buf,
This function is included in cs_halo_sync_pack, but may be called separately for specific implementations, such as for accelerator devices.
pointer to halo send buffer
◆ cs_halo_sync_r() [1/11]
template void cs_halo_sync_r ( const cs_halo_t *  halo,
bool  on_device,
cs_real_t  val[][3]
◆ cs_halo_sync_r() [2/11]
bool  on_device,
cs_real_t  val[][6]
◆ cs_halo_sync_r() [3/11]
bool  on_device,
T  val[][3]
◆ cs_halo_sync_r() [4/11]
bool  on_device,
T  val[][6]
◆ cs_halo_sync_r() [5/11]
bool  on_device,
cs_real_t  val[][3]
◆ cs_halo_sync_r() [6/11]
bool  on_device,
◆ cs_halo_sync_r() [7/11]
bool  on_device,
cs_real_t  val[][6]
◆ cs_halo_sync_r() [8/11]
bool  on_device,
float  val[][3]
◆ cs_halo_sync_r() [9/11]
bool  on_device,
T  val[][3]
Template Parameters
in] T value type
◆ cs_halo_sync_r() [10/11]
bool  on_device,
T  val[][3][3]
Template Parameters
in] T value type
◆ cs_halo_sync_r() [11/11]
bool  on_device,
T  val[][6]
Template Parameters
in] T value type
◆ cs_halo_sync_start()
void cs_halo_sync_start ( const cs_halo_t *  halo,
void *  val,
The cs_halo_sync_pack function should have been called before this function, using the same hs argument.
◆ cs_halo_sync_untyped()
void cs_halo_sync_untyped ( const cs_halo_t *  halo,
size_t  size,
void *  val
◆ cs_halo_sync_var()
void cs_halo_sync_var ( const cs_halo_t *  halo,
cs_real_t  var[]
◆ cs_halo_sync_var_strided()
void cs_halo_sync_var_strided ( const cs_halo_t *  halo,
cs_real_t  var[],
int  stride
◆ cs_halo_sync_wait()
void cs_halo_sync_wait ( const cs_halo_t *  halo,
void *  val,
The cs_halo_sync_start function should have been called before this function, using the same hs argument.
