cs_opts.h
1
#ifndef CS_OPTS_H
2
#define CS_OPTS_H
4
5
* Parsing of program arguments and associated initializations
6
8
9
This file is part of code_saturne, a general-purpose CFD tool.
11
Copyright (C) 1998-2026 EDF S.A.
13
14
15
16
version.
18
19
20
21
details.
23
24
25
26
28
30
* Local headers
32
34
#include "
base/cs_base.h
36
* Macro definitions
38
* Type definitions
45
* code_saturne base options structure
46
48
typedef
struct
49
50
char
app_name
/* Application name */
51
52
/* Redirection of standard output */
53
54
bool
trace
/* Trace progress to stdout */
55
bool
logrp
/* Redirection for ranks > 0
56
(false: to "/dev/null", suppressed)
57
true: to "run_solver_n*.log" file) */
58
59
/* Signal handling */
60
61
bool
sig_defaults
/* use default signal handlers */
62
63
/* Other options */
64
65
bool
preprocess
/* Mesh preprocessing mode */
66
bool
verif
/* Mesh quality verification mode */
67
int
benchmark
/* Benchmark mode:
68
0: not used;
69
1: timing (CPU + Walltime) mode
70
2: MPI trace-friendly mode */
71
72
cs_opts_t
73
74
75
* Public function prototypes
76
77
78
79
* Define options and call some associated initializations
80
* based on command line arguments
81
82
* parameters:
83
* argc --> number of command line arguments
84
* argv --> array of command line arguments
85
* opts <-- options structure
86
87
88
void
89
cs_opts_define
int
argc,
90
char
*argv[],
91
cs_opts_t
*opts);
92
93
94
95
#endif
/* CS_OPTS_H */
cs_base.h
cs_opts_define
void cs_opts_define(int argc, char *argv[], cs_opts_t *opts)
Definition:
cs_opts.cpp:178
cs_opts_t
Definition:
cs_opts.h:48
cs_opts_t::app_name
char * app_name
Definition:
cs_opts.h:50
cs_opts_t::sig_defaults
bool sig_defaults
Definition:
cs_opts.h:61
cs_opts_t::verif
bool verif
Definition:
cs_opts.h:66
cs_opts_t::trace
bool trace
Definition:
cs_opts.h:54
cs_opts_t::logrp
bool logrp
Definition:
cs_opts.h:55
cs_opts_t::preprocess
bool preprocess
Definition:
cs_opts.h:65
cs_opts_t::benchmark
int benchmark
Definition:
cs_opts.h:67
src
base
cs_opts.h
Generated on Mon Jul 6 2026 11:49:54 for code_saturne by
1.9.4
