cs_base.h File Reference
+ Include dependency graph for cs_base.h:
Macros
#define CS_APP_NAME   "code_saturne"
#define CS_APP_VERSION   PACKAGE_VERSION /* PACKAGE_VERSION from autoconf */
#define CS_MEM_ALIGN   0
#define CS_BASE_STRING_LEN   80
#define cs_mpi_device_support   0
Typedefs
typedef void() cs_base_atexit_t(void)
typedef void() cs_base_sigint_handler_t(int signum)
const char * cs_base_strtf (bool boolean)
 Return a string "true" or "false" according to the boolean. More...
char * cs_base_get_app_name (int argc, const char *argv[])
void cs_base_logfile_head (int argc, char *argv[])
void cs_base_mpi_init (int *argc, char **argv[])
MPI_Comm cs_base_get_rank_step_comm (int rank_step)
 Return a reduced communicator matching a multiple of the total number of ranks. More...
MPI_Comm cs_base_get_rank_step_comm_recursive (MPI_Comm parent_comm, int rank_step)
void cs_exit (int status)
void cs_base_error_init (bool signal_defaults)
void cs_base_mem_init (void)
void cs_base_mem_finalize (void)
void cs_base_signal_restore (void)
void cs_base_time_summary (void)
void cs_base_update_status (const char *format,...)
 Update status file. More...
void cs_base_trace_set (bool trace)
void cs_base_bft_printf_init (const char *log_name, bool rn_log_flag)
void cs_base_bft_printf_set (const char *log_name, bool rn_log_flag)
const char * cs_base_bft_printf_name (void)
bool cs_base_bft_printf_suppressed (void)
void cs_base_warn (const char *file_name, int line_num)
void cs_base_atexit_set (cs_base_atexit_t *const fct)
void cs_base_sigint_handler_set (cs_base_sigint_handler_t *const h)
void cs_base_option_string_clean (char *s)
const char * cs_base_get_localedir (void)
const char * cs_base_get_pkgdatadir (void)
const char * cs_base_get_pkglibdir (void)
void cs_base_check_bool (bool *b)
FILE * cs_base_open_properties_data_file (const char *base_name)
void cs_base_backtrace_dump (FILE *f, int lv_start)
 Dump a stack trace to a file. More...
void cs_base_at_finalize (cs_base_atexit_t *func)
 Register a function to be called at the finalization stage. More...
void cs_base_finalize_sequence (void)
 Call sequence of finalization functions. More...
void cs_base_get_run_identity (char **run_id, char **case_name, char **study_name)
 Query run-time directory info, using working directory names. More...
◆ CS_APP_NAME
◆ CS_APP_VERSION
◆ CS_BASE_STRING_LEN
◆ CS_MEM_ALIGN
◆ cs_mpi_device_support
Typedef Documentation
◆ cs_base_atexit_t
◆ cs_base_sigint_handler_t
◆ cs_base_at_finalize()
void cs_base_at_finalize ( cs_base_atexit_t *  func)
The finalization is done in the reverse (first in, last out) sequence relative to calls of cs_base_at_finalize.
[in]funcfinalization function to call.
◆ cs_base_atexit_set()
void cs_base_atexit_set ( cs_base_atexit_t *const  fct)
◆ cs_base_backtrace_dump()
void cs_base_backtrace_dump ( FILE *  f,
int  lv_start
[in]fpointer to file in which to dump trace
[in]lv_startstart level in stack trace
◆ cs_base_bft_printf_init()
void cs_base_bft_printf_init ( const char *  log_name,
bool  rn_log_flag
◆ cs_base_bft_printf_name()
const char * cs_base_bft_printf_name ( void  )
◆ cs_base_bft_printf_set()
void cs_base_bft_printf_set ( const char *  log_name,
bool  rn_log_flag
◆ cs_base_bft_printf_suppressed()
bool cs_base_bft_printf_suppressed ( void  )
◆ cs_base_check_bool()
void cs_base_check_bool ( bool *  b)
◆ cs_base_error_init()
void cs_base_error_init ( bool  signal_defaults)
◆ cs_base_finalize_sequence()
void cs_base_finalize_sequence ( void  )
◆ cs_base_get_app_name()
char * cs_base_get_app_name ( int  argc,
const char *  argv[]
◆ cs_base_get_localedir()
const char * cs_base_get_localedir ( void  )
◆ cs_base_get_pkgdatadir()
const char * cs_base_get_pkgdatadir ( void  )
◆ cs_base_get_pkglibdir()
const char * cs_base_get_pkglibdir ( void  )
◆ cs_base_get_rank_step_comm()
MPI_Comm cs_base_get_rank_step_comm ( int  rank_step)
This updates the number of reduced communicators if necessary.
[in]rank_stepassociated multiple of total ranks
◆ cs_base_get_rank_step_comm_recursive()
MPI_Comm cs_base_get_rank_step_comm_recursive ( MPI_Comm  parent_comm,
int  rank_step
◆ cs_base_get_run_identity()
void cs_base_get_run_identity ( char **  run_id,
char **  case_name,
char **  study_name
Returned names are allocated if non-null, so should be deallocated by the caller when no longer needed.
Names are extracted from the working directory structure, which is expected to be of the form: <prefix>/study_name/case_name/RESU/run_id
or, in the case of a coupled run: <prefix>/study_name/RESU_COUPLING/run_id/case_name
If some names cannot be queried, nullptr is returned.
[out]run_idrun_id, or nullptr
[out]case_namecase name, or nullptr
[out]study_namestudy name, or nullptr
◆ cs_base_logfile_head()
void cs_base_logfile_head ( int  argc,
char *  argv[]
◆ cs_base_mem_finalize()
void cs_base_mem_finalize ( void  )
◆ cs_base_mem_init()
void cs_base_mem_init ( void  )
◆ cs_base_mpi_init()
void cs_base_mpi_init ( int *  argc,
char **  argv[]
◆ cs_base_open_properties_data_file()
FILE * cs_base_open_properties_data_file ( const char *  base_name)
◆ cs_base_option_string_clean()
void cs_base_option_string_clean ( char *  s)
◆ cs_base_sigint_handler_set()
void cs_base_sigint_handler_set ( cs_base_sigint_handler_t *const  h)
◆ cs_base_signal_restore()
void cs_base_signal_restore ( void  )
◆ cs_base_strtf()
const char * cs_base_strtf ( bool  boolean)
inline
[in]booleanbool type
◆ cs_base_time_summary()
void cs_base_time_summary ( void  )
◆ cs_base_trace_set()
void cs_base_trace_set ( bool  trace)
◆ cs_base_update_status()
void cs_base_update_status ( const char *  format,
Update status file.
If the format string is null, the file is removed.
[in]formatformat string, or nullptr
[in]...format arguments
◆ cs_base_warn()
void cs_base_warn ( const char *  file_name,
int  line_num
◆ cs_exit()
void cs_exit ( int  status)
