1#ifndef CS_BOUNDARY_CONDITIONS_H
2#define CS_BOUNDARY_CONDITIONS_H
53#define CS_MAX_BC_TYPE 200
159 const char *type_name);
228 ple_locator_t *locator,
264 int source_location_id,
Definition: cs_boundary_conditions.h:102
ple_locator_t * locator
Definition: cs_boundary_conditions.h:112
int bc_location_id
Definition: cs_boundary_conditions.h:106
Definition: cs_boundary_conditions.h:107
double tolerance
Definition: cs_boundary_conditions.h:110
cs_real_t coord_shift[3]
Definition: cs_boundary_conditions.h:108
void update()
Definition: cs_boundary_conditions.cpp:3410
Definition: cs_field.h:275
Definition: cs_time_control.h:92
void cs_boundary_conditions_realloc(void)
Reallocate the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.cpp:2216
void cs_boundary_conditions_create(void)
Create the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.cpp:2165
void * cs_boundary_conditions_get_model_inlet_try(const cs_zone_t *zone)
Return pointer to model inlet structure associated with a given boundary zone, if associated,...
Definition: cs_boundary_conditions.cpp:2748
cs_time_control_t * cs_boundary_conditions_open_get_time_control(const cs_zone_t *zone)
Acess the time control structure of an open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.cpp:2855
void cs_boundary_conditions_open_turb(void)
void cs_boundary_conditions_open_set_volume_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant volume flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.cpp:3212
void cs_boundary_conditions_open_set_mass_flow_rate_by_value(const cs_zone_t *z, cs_real_t q)
Assign a constant mass flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.cpp:3048
void cs_boundary_conditions_open_set_velocity_by_normal_value(const cs_zone_t *z, cs_real_t u_norm)
Assign a constant velocity normal to an inlet.
Definition: cs_boundary_conditions.cpp:2916
cs_boundary_condition_pm_info_t * cs_glob_bc_pm_info
cs_bc_map_t * cs_boundary_conditions_get_maps()
Return maps to mapping of boundary face locations (usually from boundary zones).
Definition: cs_boundary_conditions.cpp:2130
const int * cs_glob_bc_type
cs_real_t cs_boundary_conditions_open_get_mass_flow_rate(const cs_zone_t *z)
Return the volume flow rate to an inlet or outlet.
Definition: cs_boundary_conditions.cpp:3009
void cs_boundary_conditions_open_set_mass_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a mass flow rate to an inlet or outlet based on provided function.
Definition: cs_boundary_conditions.cpp:3142
void cs_boundary_conditions_ibm_create(cs_lnum_t n_ib_cells)
Update the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.cpp:2263
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w)
Set mapped boundary conditions for a given field and mapping locator.
Definition: cs_boundary_conditions.cpp:1884
void cs_boundary_conditions_complete(int bc_type[])
Automatic adjustments for boundary condition codes.
Definition: cs_boundary_conditions.cpp:2609
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition: cs_boundary_conditions.cpp:1732
cs_real_t * cs_boundary_conditions_get_b_head_loss(bool alloc_if_null)
Return pointer to boundary head losses array.
Definition: cs_boundary_conditions.cpp:2798
int cs_boundary_conditions_add_map(int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic int...
Definition: cs_boundary_conditions.cpp:2079
int * cs_boundary_conditions_get_bc_type(void)
Return pointer to boundary conditions BC type array.
Definition: cs_boundary_conditions.cpp:2415
void cs_boundary_conditions_create_legacy_zone_data(void)
Create the legacy boundary conditions zone data arrays.
Definition: cs_boundary_conditions.cpp:2142
void cs_boundary_conditions_open_set_velocity_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a normal velocity to an inlet using a provided function.
Definition: cs_boundary_conditions.cpp:2963
void cs_boundary_conditions_free(void)
Free the boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.cpp:2308
void cs_boundary_conditions_compute(int bc_type[])
Update per variable boundary condition codes.
Definition: cs_boundary_conditions.cpp:2429
void * cs_boundary_conditions_get_model_inlet(const cs_zone_t *zone)
Return pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.cpp:2720
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Handling of boundary condition definition errors and associated output.
Definition: cs_boundary_conditions.cpp:1678
int cs_boundary_conditions_get_number_of_maps()
Return the number of maps to mapping of boundary face locations (usually from boundary zones).
Definition: cs_boundary_conditions.cpp:2115
int cs_boundary_conditions_get_legacy_zone_num(const cs_zone_t *z)
Definition: cs_boundary_conditions.cpp:2773
void cs_boundary_conditions_inlet_set_turbulence_intensity(const cs_zone_t *zone, cs_real_t ti)
Base the inlet turbulence values on a a circular duct with smooth wall (see ref cs_turbulence_bc_ke_h...
Definition: cs_boundary_conditions.cpp:3377
void cs_boundary_conditions_assign_model_inlet(const cs_zone_t *zone, void *s_ptr, void *s_del)
Assign pointer to model inlet structure associated with a given open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.cpp:2823
void cs_boundary_conditions_reset(void)
Prepare (reset) condition coefficients for all variable fields.
Definition: cs_boundary_conditions.cpp:2350
void cs_boundary_conditions_inlet_set_turbulence_hyd_diam(const cs_zone_t *zone, cs_real_t hd)
Definition: cs_boundary_conditions.cpp:3355
void cs_boundary_conditions_open_set_volume_flow_rate_by_func(const cs_zone_t *z, cs_eval_at_location_t *func, void *input)
Assign a volume flow rate to an inlet or outlet based on provided function.
Definition: cs_boundary_conditions.cpp:3296
void cs_boundary_conditions_open_set_velocity_by_value(const cs_zone_t *z, const cs_real_t u[3])
Assign a constant velocity to an open (inlet/outlet) boundary.
Definition: cs_boundary_conditions.cpp:2877
int ** cs_boundary_conditions_get_bc_type_addr(void)
Get address of global boundary conditions type array.
Definition: cs_boundary_conditions.cpp:3396
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
Definition: cs_defs.h:325
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:108
Definition: cs_mesh_location.h:60
Definition: cs_boundary_conditions.h:87
int * iautom
Definition: cs_boundary_conditions.h:93
int * izfppp
Definition: cs_boundary_conditions.h:90
