1#ifndef CS_WALL_FUNCTIONS_H
2#define CS_WALL_FUNCTIONS_H
139 const double ydvisc = y / l_visc;
145 *
yplus = *ustar * ydvisc;
148 if (*
yplus <= ypluli) {
150 *ustar = sqrt(
vel / ydvisc);
151 *
210 double ustarwer, ustarmin, ustaro, ydvisc;
219 reynolds =
vel * ydvisc;
226 if (reynolds <= ypluli * ypluli) {
228 *ustar = sqrt(
vel / ydvisc);
229 *
250 for (iter = 0; iter < niter_max
251 && fabs(*ustar - ustaro) >=
eps * ustaro; iter++) {
257 if (iter >= niter_max) {
258 bft_printf(
_(
"WARNING: non-convergence in the computation\n"
259 "******** of the friction velocity\n\n"
260 "friction vel: %f \n" ), *ustar);
264 *
295 f_blend = exp(-0.25*cuv*pow(yp,3));
296 uplus = f_blend*yp + (log(yp)/ka +B)*(1.-exp(-pow(yp/y0,n)))*(1-f_blend);
319 dupdyp = exp(-0.25*cuv*pow(yp,3))
320 - 0.75*cuv*pow(yp,3.)*exp(-0.25*cuv*pow(yp,3.))
321 + n*(1.-exp(-0.25*cuv*pow(yp,3.)))*(pow(yp,n-1.)/pow(y0,n))
322 *exp(-pow(yp/y0,n))*((1./ka)*log(yp)+B)
323 + 0.75*cuv*pow(yp,2.)*exp(-0.25*cuv*pow(yp,3.))
324 *(1.-exp(-pow(yp/y0,n)))*((1./ka)*log(yp)+B)
325 + (1./ka/yp)*(1.-exp(-pow(yp/y0,n)))*(1-exp(-0.25*cuv*pow(yp,3.)));
372 double Re, g, t_visc_durb;
382 Re = sqrt(kinetic_en) * y / l_visc;
386 *uk = sqrt( (1.-g) * sqrt(
cs_turb_cmu) * kinetic_en
387 + g * l_visc *
vel/y);
390 *
yplus = *uk * y / l_visc;
393 *ustar =
vel / uplus;
395 if (*
yplus < 1.e-1) {
408 cstcuv, csty0, cstN);
413 *ypup = *
yplus / uplus;
427 assert(turb_model != NULL);
429 t_visc_durb = t_visc / (kinetic_en *
cs_turb_cmu ) * rnnb * 0.22;
431 t_visc_durb = t_visc;
434 = 1. - *ypup * (2. * sqrt(l_visc / t_visc_durb * dup1 * (1. - dup1))
438 if (*
yplus > ypluli) {
487 double rcprod, ml_visc, Re, g;
492 Re = sqrt(kinetic_en) * y / l_visc;
495 *uk = sqrt( (1.-g) * sqrt(
496 + g * l_visc *
vel / y);
498 *
501 if (*
yplus > ypluli) {
505 *ustar =
vel / uplus;
506 *ypup = *
yplus / uplus;
514 * ( 2. * rcprod - 1. / (2. * *
yplus));
522 if (*
yplus > 1.e-12) {
581 double rcprod, ml_visc, Re, g;
585 Re = sqrt(kinetic_en) * y / l_visc;
588 *uk = sqrt( (1.-g) * sqrt(
589 + g * l_visc *
vel / y);
591 *
595 *
598 if (*
yplus > ypluli) {
607 *dplus = ypluli - *
yplus;
618 / (*
yplus + *dplus));
642 static double aa[11] = {-0.0091921, 3.9577, 0.031578,
643 -0.51013, -2.3254, -0.72665,
644 2.969, 0.48506, -1.5944,
647 cs_real_t y1,y2,y3,y4,y5,y6,y7,y8,y9,y10, uplus;
649 y1 = 0.25 * log(
yplus);
730 double urplus, d_up, lmk15;
743 cs_real_t dyrp = 0.9 * (sqrt(krp) - krp * exp(-krp / 6.));
748 else if (dyrp <= 200.)
753 if (yrplus <= 1.e-1) {
768 }
else if (yrplus <= 200.) {
775 *ypup = *
yplus / (urplus-d_up);
784 *cofimp = 1. - (2. / (1. + *lmk) - 1. / (1. + lmk15)) * *ypup;
794 *ypup = *
803 *cofimp = 1. - (2. / *lmk - 1. / lmk15) * *ypup;
808 *ustar =
vel / (urplus-d_up);
866 double rcprod, ml_visc, Re, g;
889 Re = sqrt(kinetic_en) * (y + y0) / l_visc;
892 *uk = sqrt( (1.-g) * sqrt(
893 + g * l_visc *
vel / (y + y0));
896 *
899 *dplus = *uk * y0 / l_visc;
906 if (*
yplus > ypluli) {
910 *ustar =
vel / uplus;
911 *ypup = *
yplus / uplus;
913 bft_printf(
"uet=%f, u=%f, uplus=%f, yk=%f, duplus=%f\n",
914 *ustar,
vel, uplus, *
yplus, 1./uplus);
921 / (*
yplus + *dplus));
923 * ( 2. * rcprod - 1. / (2. * *
yplus + *dplus));
931 if (*
yplus > 1.e-12) {
991 *ustar = sqrt(
vel * l_visc / y);
992 *
yplus = *ustar * y / l_visc;
1081 if (
yplus > (*yplim)) {
1083 * (log((
yplus+dplus)/(*yplim)) + shift_temp);
1084 (*htur) = prl *
yplus / tplus;
1093 (*yplim) = pow(1000./prl, 1./3.);
1095 a2 = 15.*pow(prl, 2./3.);
1098 tplus = a2 - 500./((
yplus+dplus)*(
yplus+dplus));
1099 (*htur) = prl *
yplus / tplus;
1105 (*htur) = prl *
yplus / tplus;
1146 const int ninter_max = 100;
1158 int npeff =
cs_math_fmax((
int)(ypint / ypmax * (
double)(ninter_max)), 1);
1160 double dy = ypint / (double)(npeff);
1165 for (
int ip = 1; ip <= npeff; ip++) {
1166 double yp = ypint * (double)(ip) / (double)(npeff);
1168 stplus += dy / (1. + prlrat * 0.5 * (nut1 + nut2));
1172 if (
yplus > ypint) {
1174 stplus += log( (1. + r*
yplus) / (1. + r*ypint)) / r;
1177 if (stplus >= 1.e-6)
1178 *htur =
yplus / stplus;
1232 if (
yplus > ypluli) {
1235 (*htur) = prl *
yplus / tplus;
Definition: bft_printf.cpp:134
Definition: cs_field.h:275
Definition: cs_defs.h:528
Definition: cs_defs.h:332
#define _(String)
Definition: cs_defs.h:61
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
#define CS_UNUSED(x)
Definition: cs_defs.h:518
Definition: cs_defs.h:529
@ eps
Definition: cs_field_pointer.h:69
@ vel
Definition: cs_field_pointer.h:66
@ yplus
Definition: cs_field_pointer.h:213
static constexpr cs_real_t cs_math_epzero
Definition: cs_math.h:102
CS_F_HOST_DEVICE cs_real_t cs_math_fmax(cs_real_t x, cs_real_t y)
Definition: cs_math.h:844
CS_F_HOST_DEVICE cs_real_t cs_math_fmin(cs_real_t x, cs_real_t y)
Compute the min value of two real values.
Definition: cs_math.h:825
double cs_turb_vdriest
Definition: cs_turbulence_model.cpp:431
double cs_turb_crij2
Definition: cs_turbulence_model.cpp:537
double cs_turb_crij1
Definition: cs_turbulence_model.cpp:531
cs_turb_model_t * cs_get_glob_turb_model(void)
Provide write access to turbulence model structure.
Definition: cs_turbulence_model.cpp:1200
double cs_turb_cstlog
Definition: cs_turbulence_model.cpp:443
double cs_turb_dpow
Definition: cs_turbulence_model.cpp:476
double cs_turb_apow
Definition: cs_turbulence_model.cpp:470
double cs_turb_cmu
Definition: cs_turbulence_model.cpp:484
double cs_turb_bpow
Definition: cs_turbulence_model.cpp:473
double cs_turb_xkappa
Definition: cs_turbulence_model.cpp:422
@ CS_TURB_SECOND_ORDER
Definition: cs_turbulence_model.h:93
cs_wall_f_s_type_t
Definition: cs_wall_functions.h:68
@ CS_WALL_F_S_SMOOTH_ROUGH
Definition: cs_wall_functions.h:75
@ CS_WALL_F_S_MONIN_OBUKHOV
Definition: cs_wall_functions.h:74
@ CS_WALL_F_S_VDRIEST
Definition: cs_wall_functions.h:72
@ CS_WALL_F_S_ARPACI_LARSEN
Definition: cs_wall_functions.h:71
@ CS_WALL_F_S_UNSET
Definition: cs_wall_functions.h:70
@ CS_WALL_F_S_LOUIS
Definition: cs_wall_functions.h:73
static cs_real_t _dupdyp(cs_real_t yp, cs_real_t ka, cs_real_t B, cs_real_t cuv, cs_real_t y0, cs_real_t n)
Definition: cs_wall_functions.h:310
void cs_wall_functions_scalar(cs_wall_f_s_type_t iwalfs, cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur, cs_real_t *yplim)
Compute the correction of the exchange coefficient between the fluid and the wall for a turbulent flo...
Definition: cs_wall_functions.cpp:709
static void cs_wall_functions_2scales_continuous(cs_real_t rnnb, cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
Continuous law of the wall between the linear and log law, with two velocity scales based on the fric...
Definition: cs_wall_functions.h:356
static void cs_wall_functions_1scale_log(cs_real_t l_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
Log law: piecewise linear and log, with one velocity scale based on the friction.
Definition: cs_wall_functions.h:196
static void cs_wall_functions_2scales_smooth_rough(cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t rough_d, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
Two velocity scales wall function with automatic switch from rough to smooth.
Definition: cs_wall_functions.h:846
static void cs_wall_functions_s_smooth_rough(cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur)
Rough Smooth Thermal Wall Function - Prototype.
Definition: cs_wall_functions.h:1203
static void cs_wall_functions_1scale_power(cs_real_t l_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
Power law: Werner & Wengle.
Definition: cs_wall_functions.h:125
const cs_wall_functions_t * cs_glob_wall_functions
static cs_real_t _vdriest_dupdyp_integral(cs_real_t yplus)
Definition: cs_wall_functions.h:639
static void cs_wall_functions_s_arpaci_larsen(cs_real_t l_visc, cs_real_t prl, cs_real_t prt, cs_real_t rough_t, cs_real_t uk, cs_real_t yplus, cs_real_t dplus, cs_real_t *htur, cs_real_t *yplim)
The correction of the exchange coefficient is computed thanks to a similarity model between dynamic v...
Definition: cs_wall_functions.h:1035
static void cs_wall_functions_disabled(cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
No wall function.
Definition: cs_wall_functions.h:971
cs_wall_functions_t * cs_get_glob_wall_functions(void)
Definition: cs_wall_functions.cpp:181
static void cs_wall_functions_2scales_vdriest(cs_real_t rnnb, cs_real_t l_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp, cs_real_t *lmk, cs_real_t kr, bool wf)
Two velocity scales wall function using Van Driest mixing length.
Definition: cs_wall_functions.h:713
static void cs_wall_functions_s_vdriest(cs_real_t prl, cs_real_t prt, cs_real_t yplus, cs_real_t *htur)
The correction of the exchange coefficient is computed thanks to a numerical integration of:
Definition: cs_wall_functions.h:1138
cs_wall_f_type_t
Definition: cs_wall_functions.h:54
@ CS_WALL_F_1SCALE_LOG
Definition: cs_wall_functions.h:59
@ CS_WALL_F_1SCALE_POWER
Definition: cs_wall_functions.h:58
@ CS_WALL_F_2SCALES_SMOOTH_ROUGH
@ CS_WALL_F_2SCALES_LOG
Definition: cs_wall_functions.h:60
@ CS_WALL_F_2SCALES_VDRIEST
Definition: cs_wall_functions.h:62
@ CS_WALL_F_DISABLED
Definition: cs_wall_functions.h:57
@ CS_WALL_F_UNSET
Definition: cs_wall_functions.h:56
@ CS_WALL_F_2SCALES_CONTINUOUS
Definition: cs_wall_functions.h:64
@ CS_WALL_F_SCALABLE_2SCALES_LOG
Definition: cs_wall_functions.h:61
static void cs_wall_functions_2scales_scalable(cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *dplus, cs_real_t *ypup, cs_real_t *cofimp)
Scalable wall function: shift the wall if .
Definition: cs_wall_functions.h:562
static void cs_wall_functions_2scales_log(cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t kinetic_en, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp)
Log law: piecewise linear and log, with two velocity scales based on the friction and the turbulent k...
Definition: cs_wall_functions.h:471
void cs_wall_functions_velocity(cs_wall_f_type_t iwallf, cs_real_t l_visc, cs_real_t t_visc, cs_real_t vel, cs_real_t y, cs_real_t rough_d, cs_real_t rnnb, cs_real_t kinetic_en, cs_real_t rough_t, cs_real_t buoyant_param, cs_real_t delta_t, cs_real_t turb_prandtl, int icodcl_th_fid, cs_real_t flux, cs_field_t *f_th, int *iuntur, cs_gnum_t *nsubla, cs_gnum_t *nlogla, cs_real_t *ustar, cs_real_t *uk, cs_real_t *yplus, cs_real_t *ypup, cs_real_t *cofimp, cs_real_t *dplus, cs_real_t *cfnns, cs_real_t *cfnnk, cs_real_t *cfnne, cs_real_t *dlmo)
Compute the friction velocity and / .
Definition: cs_wall_functions.cpp:340
static cs_real_t _uplus(cs_real_t yp, cs_real_t ka, cs_real_t B, cs_real_t cuv, cs_real_t y0, cs_real_t n)
Definition: cs_wall_functions.h:286
double precision epzero
epsilon
Definition: cstnum.f90:40
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:126
int order
Definition: cs_turbulence_model.h:184
wall functions descriptor.
Definition: cs_wall_functions.h:82
double ypluli
Definition: cs_wall_functions.h:88
Definition: cs_wall_functions.h:86
