cs_defs.h File Reference
#include "base/cs_config.h"
#include <type_traits>
#include <utility>
#include <mpi.h>
#include <typeinfo>
#include "assert.h"
+ Include dependency graph for cs_defs.h:
Classes
struct  cs_double_int_t
struct  cs_nvec3_t
struct  are_integral< Args >
 Utility template to check if a pack of parameters is made of integral types. More...
struct  are_integral< T, Args... >
struct  always_true< Args >
 Utility template which returns "true" for a given pack. This is necessary of std::enable_if_t<> when the template pack is not used for the if clause... More...
struct  dependent_false< T >
 Get the cs_datatype_t from a typename. More...
Namespaces
namespace  cs
Macros
#define _LIBINTL_H
#define _(String)   (String)
#define N_(String)   String
#define textdomain(String)   (String)
#define gettext(String)   (String)
#define dgettext(Domain, String)   (String)
#define dcgettext(Domain, String, Type)   (String)
#define bindtextdomain(Domain, Directory)   (Domain)
#define MPI_VERSION   1
#define MPI_Info   int
#define MPI_INFO_NULL   0
#define restrict
#define DISABLE_WARNING_PUSH
#define DISABLE_WARNING(warningName)
#define DISABLE_WARNING_POP
#define DISABLE_WARNING_LLVM(warningName)
#define __has_builtin(x)   0
#define CS_MPI_REAL   MPI_DOUBLE /* If cs_real_t is a double */
#define CS_MPI_GNUM   MPI_UNSIGNED
#define CS_MPI_LNUM   MPI_INT
#define CS_MPI_EFLAG   MPI_UNSIGNED /* MPI type for cs_mflag_t type */
#define CS_MPI_FLAG   MPI_UNSIGNED_SHORT /* MPI type for cs_flag_t type */
#define CS_MPI_COORD   MPI_DOUBLE /* MPI type for cs_coord_t type */
#define CS_GNUM_TYPE   CS_UINT32
#define CS_LNUM_TYPE   CS_INT32
#define CS_INT_TYPE   CS_INT32
#define CS_UINT_TYPE   CS_UINT32
#define CS_FLAG_TYPE   CS_UINT16
#define CS_EFLAG_TYPE   CS_UINT_TYPE
#define CS_REAL_TYPE   CS_DOUBLE
#define CS_COORD_TYPE   CS_DOUBLE
#define CS_THR_MIN   128
#define CS_CL_SIZE   64
#define CS_ABS(a)   ((a) < 0 ? -(a) : (a))
#define CS_MIN(a, b)   ((a) < (b) ? (a) : (b))
#define CS_MAX(a, b)   ((a) > (b) ? (a) : (b))
#define CS_UNUSED(x)   (void)(x)
#define CS_NO_WARN_IF_UNUSED(x)   (void)(x)
#define BEGIN_C_DECLS   extern "C" {
#define END_C_DECLS   }
#define CS_F_HOST
#define CS_F_DEVICE
#define CS_F_HOST_DEVICE
#define CS_V_CONSTANT   static const
#define CS_LAMBDA   [=] CS_F_HOST_DEVICE
#define CS_HOST_LAMBDA   [=] CS_F_HOST
#define CS_CLASS_LAMBDA   [=, *this] CS_F_HOST_DEVICE
Typedefs
using cs_stream_t = void *
typedef unsigned cs_gnum_t
 global mesh entity number More...
typedef int cs_lnum_t
 local mesh entity id More...
typedef double cs_coord_t
typedef double cs_real_t
 Floating-point value. More...
typedef char cs_byte_t
typedef unsigned short int cs_flag_t
typedef double cs_nreal_t
typedef double cs_dreal_t
typedef double cs_rreal_t
typedef cs_lnum_t cs_lnum_2_t[2]
 vector of 2 local mesh-entity ids More...
typedef cs_lnum_t cs_lnum_3_t[3]
typedef cs_coord_t cs_coord_3_t[3]
typedef cs_real_t cs_real_2_t[2]
 vector of 2 floating-point values More...
typedef cs_real_t cs_real_3_t[3]
 vector of 3 floating-point values More...
typedef cs_real_t cs_real_4_t[4]
 vector of 4 floating-point values More...
typedef cs_real_t cs_real_6_t[6]
 vector of 6 floating-point values More...
typedef cs_real_t cs_real_9_t[9]
typedef cs_real_t cs_real_10_t[10]
typedef cs_real_t cs_real_23_t[2][3]
typedef cs_real_t cs_real_33_t[3][3]
 3x3 matrix of floating-point values More...
typedef cs_real_t cs_real_66_t[6][6]
 6x6 matrix of floating-point values More...
typedef cs_real_t cs_real_99_t[9][9]
typedef cs_real_t cs_real_333_t[3][3][3]
typedef cs_real_t cs_real_34_t[3][4]
typedef cs_real_t cs_real_63_t[6][3]
typedef cs_real_t cs_real_69_t[6][9]
typedef cs_real_33_t cs_real_332_t[2]
 vector of 2 3x3 matrices of floating-point values More...
typedef cs_real_66_t cs_real_662_t[2]
typedef cs_nreal_t cs_nreal_3_t[3]
typedef cs_dreal_t cs_dreal_3_t[3]
typedef cs_rreal_t cs_rreal_3_t[3]
typedef void *() cs_destructor_t(void *s)
 Destroy a given structure. More...
Enumerations
enum  cs_datatype_t {
  CS_DATATYPE_NULL , CS_CHAR , CS_FLOAT , CS_DOUBLE ,
  CS_UINT16 , CS_INT32 , CS_INT64 , CS_UINT32 ,
  CS_UINT64
enum  cs_interlace_t { CS_INTERLACE , CS_NO_INTERLACE }
static cs_lnum_t cs_align (cs_lnum_t i, cs_lnum_t m)
 Given a base index i, return the next index aligned with a size m. More...
static int cs_get_thread_id (void)
 Retrieve the associated thread id (0 if no OpenMP or if outside an OpenMP region) More...
template<typename T >
CS_F_HOST_DEVICE T abs (const T a)
CS_F_HOST_DEVICE T min (const T a, const T b)
CS_F_HOST_DEVICE T max (const T a, const T b)
CS_F_HOST_DEVICE T clamp (const T x, const T xmin, const T xmax)
template<class T >
CS_F_HOST_DEVICE constexpr std::enable_if_t< std::is_move_constructible< T >::value &&std::is_move_assignable< T >::value > swap_objects (T &obj1, T &obj2)
 A swap method which is callable from GPU and not only CPU. More...
template<class T , std::size_t N>
CS_F_HOST_DEVICE constexpr void swap_objects (T(&obj1)[N], T(&obj2)[N])
template<typename Id1 >
CS_F_HOST_DEVICE unsigned int number_of_digits (Id1 val)
 Count number of digits in an integer. More...
CS_F_HOST_DEVICE void uint_to_char (char *dest, Id1 val)
 Convert an unsigned integer to an array of char. More...
CS_F_HOST_DEVICE void concatenate_char (char *dest, const char *src)
 Concatenate two strings (char *) More...
static cs_datatype_t cs_datatype_from_type ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< char > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< float > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< double > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< uint16_t > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< uint32_t > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< uint64_t > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< int32_t > ()
template<>
constexpr cs_datatype_t cs_datatype_from_type< int64_t > ()
const char cs_empty_string []
const size_t cs_datatype_size []
const char * cs_datatype_name []
MPI_Datatype cs_datatype_to_mpi []
int cs_glob_n_threads
int cs_glob_rank_id
int cs_glob_n_ranks
int cs_glob_node_rank_id
int cs_glob_node_n_ranks
MPI_Comm cs_glob_mpi_comm
Base macro and typedef definitions for system portability.
◆ _
#define _ (   String)    (String)
◆ __has_builtin
#define __has_builtin (   x)    0
◆ _LIBINTL_H
#define _LIBINTL_H
Value:
/* Prevent inclusion of <libintl.h> by other files
with incorrect or missing checks;
TODO locate files causing issues to avoid
requiring this workaround */
◆ BEGIN_C_DECLS
◆ bindtextdomain
#define bindtextdomain (   Domain,
  Directory
)    (Domain)
◆ CS_ABS
#define CS_ABS (   a)    ((a) < 0 ? -(a) : (a))
Absolute value of a
◆ CS_CL_SIZE
◆ CS_CLASS_LAMBDA
◆ CS_COORD_TYPE
◆ CS_EFLAG_TYPE
◆ CS_F_DEVICE
#define CS_F_DEVICE
◆ CS_F_HOST
#define CS_F_HOST
◆ CS_F_HOST_DEVICE
◆ CS_FLAG_TYPE
◆ CS_GNUM_TYPE
◆ CS_HOST_LAMBDA
◆ CS_INT_TYPE
◆ CS_LAMBDA
◆ CS_LNUM_TYPE
◆ CS_MAX
#define CS_MAX (   a,
  b
Maximum of a et b
◆ CS_MIN
#define CS_MIN (   a,
  b
Minimum of a et b
◆ CS_MPI_COORD
◆ CS_MPI_EFLAG
◆ CS_MPI_FLAG
◆ CS_MPI_GNUM
◆ CS_MPI_LNUM
◆ CS_MPI_REAL
◆ CS_NO_WARN_IF_UNUSED
#define CS_NO_WARN_IF_UNUSED (   x)    (void)(x)
◆ CS_REAL_TYPE
◆ CS_THR_MIN
◆ CS_UINT_TYPE
◆ CS_UNUSED
#define CS_UNUSED (   x)    (void)(x)
◆ CS_V_CONSTANT
◆ dcgettext
#define dcgettext (   Domain,
  String,
  Type
)    (String)
◆ dgettext
#define dgettext (   Domain,
  String
)    (String)
◆ DISABLE_WARNING
#define DISABLE_WARNING (   warningName)
◆ DISABLE_WARNING_LLVM
#define DISABLE_WARNING_LLVM (   warningName)
◆ DISABLE_WARNING_POP
◆ DISABLE_WARNING_PUSH
◆ END_C_DECLS
◆ gettext
#define gettext (   String)    (String)
◆ MPI_Info
◆ MPI_INFO_NULL
◆ MPI_VERSION
◆ N_
#define N_ (   String)    String
◆ restrict
#define restrict
◆ textdomain
#define textdomain (   String)    (String)
Typedef Documentation
◆ cs_byte_t
◆ cs_coord_3_t
◆ cs_coord_t
◆ cs_destructor_t
[in,out]spointer to a structure cast on-the-fly
a null pointer
◆ cs_dreal_3_t
◆ cs_dreal_t
◆ cs_flag_t
◆ cs_gnum_t
Global mesh-entity numbers are strictly positive (1 to n based) integers, so they are declared as a form of unsigned integer. Such a number is unique across MPI ranks; 2 mesh elements on different ranks share the same number if and only if they are local instances of the same global element (such as shared faces or vertices on rank boundaries). A value of 0 is commonly used to mark undefined (or not yet defined) element ids in various pre or post-processing stages.
◆ cs_lnum_2_t
cs_lnum_2_t
◆ cs_lnum_3_t
◆ cs_lnum_t
Local mesh-entity ids are signed integers, and be either 0 to n-1 or 1 to n based. When 0-based, the id prefix or postfix is preferred for associated variable names, while num is preferred when 1-based. In C code, using this type is recommended over using simple int integers, as 64-bit variants could be used in the future for shared-memory machines with large memory. This type should not be used to declare identifiers which are not mesh entities, such as groups, fields, or any other entity whose count does not depend on mesh size, so as not to pollute the readability and comprehensibility of the code.
◆ cs_nreal_3_t
◆ cs_nreal_t
◆ cs_real_10_t
◆ cs_real_23_t
◆ cs_real_2_t
cs_real_2_t
◆ cs_real_332_t
cs_real_332_t
◆ cs_real_333_t
◆ cs_real_33_t
cs_real_33_t
◆ cs_real_34_t
◆ cs_real_3_t
cs_real_3_t
◆ cs_real_4_t
cs_real_4_t
◆ cs_real_63_t
◆ cs_real_662_t
◆ cs_real_66_t
cs_real_66_t
◆ cs_real_69_t
◆ cs_real_6_t
cs_real_6_t
◆ cs_real_99_t
◆ cs_real_9_t
◆ cs_real_t
◆ cs_rreal_3_t
◆ cs_rreal_t
◆ cs_stream_t
◆ cs_datatype_t
Enumerator
CS_DATATYPE_NULL
CS_CHAR
CS_FLOAT
CS_DOUBLE
CS_UINT16
CS_INT32
CS_INT64
CS_UINT32
CS_UINT64
◆ cs_interlace_t
Enumerator
CS_INTERLACE
CS_NO_INTERLACE
◆ cs_align()
static cs_lnum_t cs_align ( cs_lnum_t  i,
cs_lnum_t  m
inlinestatic
This index is computed as follows:
if i > 0: ((i - 1) / m + 1) * m if i = 0: 0
[in]ibase index
[in]mblock size to align with
aligned index
◆ cs_datatype_from_type()
static cs_datatype_t cs_datatype_from_type ( )
inlinestatic
◆ cs_datatype_from_type< char >()
constexpr cs_datatype_t cs_datatype_from_type< char > ( )
inlineconstexpr
◆ cs_datatype_from_type< double >()
constexpr cs_datatype_t cs_datatype_from_type< double > ( )
inlineconstexpr
◆ cs_datatype_from_type< float >()
constexpr cs_datatype_t cs_datatype_from_type< float > ( )
inlineconstexpr
◆ cs_datatype_from_type< int32_t >()
constexpr cs_datatype_t cs_datatype_from_type< int32_t > ( )
inlineconstexpr
◆ cs_datatype_from_type< int64_t >()
constexpr cs_datatype_t cs_datatype_from_type< int64_t > ( )
inlineconstexpr
◆ cs_datatype_from_type< uint16_t >()
constexpr cs_datatype_t cs_datatype_from_type< uint16_t > ( )
inlineconstexpr
◆ cs_datatype_from_type< uint32_t >()
constexpr cs_datatype_t cs_datatype_from_type< uint32_t > ( )
inlineconstexpr
◆ cs_datatype_from_type< uint64_t >()
constexpr cs_datatype_t cs_datatype_from_type< uint64_t > ( )
inlineconstexpr
◆ cs_get_thread_id()
static int cs_get_thread_id ( void  )
inlinestatic
the id of the OpenMP thread
◆ cs_datatype_name
const char* cs_datatype_name[]
extern
◆ cs_datatype_size
const size_t cs_datatype_size[]
extern
◆ cs_datatype_to_mpi
MPI_Datatype cs_datatype_to_mpi[]
extern
◆ cs_empty_string
const char cs_empty_string[]
extern
◆ cs_glob_mpi_comm
extern
◆ cs_glob_n_ranks
int cs_glob_n_ranks
extern
Number of processes in communicator
◆ cs_glob_n_threads
extern
◆ cs_glob_node_n_ranks
extern
Number of ranks on node of main MPI communicator
◆ cs_glob_node_rank_id
extern
Rank on node in main MPI communicator
◆ cs_glob_rank_id
int cs_glob_rank_id
extern
Rank of process in communicator
