| subroutine | field_get_n_fields (nfld) |
| | Return the number of defined fields. More...
| subroutine | field_get_id (name, id) |
| | Return an id associated with a given field name. More...
| subroutine | field_get_location (f_id, f_loc) |
| | Return the location of a given field. More...
| subroutine | field_get_id_try (name, id) |
| | Return an id associated with a given field name if present. More...
| subroutine | field_get_name (f_id, name) |
| | Return a given field's name. More...
| subroutine | field_get_dim (f_id, f_dim) |
| | Return a given field's dimension. More...
| subroutine | field_get_type (f_id, f_type) |
| | Return a given field's type. More...
| subroutine | field_get_key_id (name, id) |
| | Return an id associated with a given key name if present. More...
| subroutine | field_get_key_int (f_id, k_id, k_value) |
| | Return an integer value for a given key associated with a field. More...
| subroutine | field_get_key_int_by_name (f_id, k_name, k_value) |
| subroutine | field_get_key_double (f_id, k_id, k_value) |
| | Return a floating-point value for a given key associated with a field. More...
| subroutine | field_get_label (f_id, str) |
| | Return a label associated with a field. More...
| subroutine | field_get_val_s (field_id, p) |
| | Return pointer to the values array of a given scalar field. More...
| subroutine | field_get_val_s_by_name (name, p) |
| subroutine | field_get_val_prev_s_by_name (name, p) |
| | Return pointer to the array's previous values of a given scalar field. More...
| subroutine | field_get_val_v (field_id, p) |
| | Return pointer to the values array of a given vector field. More...
| subroutine | field_get_val_v_by_name (name, p) |
Module for field-related operations.
