cs_rank_neighbors.cpp File Reference
#include <errno.h>
#include "bft/bft_printf.h"
#include "base/cs_block_dist.h"
#include "base/cs_crystal_router.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_order.h"
#include "base/cs_timer.h"
#include "base/cs_rank_neighbors.h"
+ Include dependency graph for cs_rank_neighbors.cpp:
cs_rank_neighbors_t * cs_rank_neighbors_create (size_t n_elts, const int elt_rank[])
 Create a rank neighbors structure base on a list of element ranks. More...
void cs_rank_neighbors_destroy (cs_rank_neighbors_t **n)
 Destroy a rank neighborhood structure. More...
void cs_rank_neighbors_to_index (const cs_rank_neighbors_t *n, size_t n_elts, const int elt_rank[], int *elt_rank_index)
 Given a list of element ranks, determine the associated element rank indexes in a rank neighborhood structure. More...
void cs_rank_neighbors_symmetrize (cs_rank_neighbors_t *n, MPI_Comm comm)
 Symmetrize a rank neighborhood structure. More...
void cs_rank_neighbors_count (const cs_rank_neighbors_t *n, size_t n_elts, const int *elt_rank_index, cs_lnum_t *elt_rank_count)
 Given a list of element rank indexes, count occurences for a rank neighborhood structure. More...
void cs_rank_neighbors_sync_count (const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, MPI_Comm comm)
 Exchange send and receive counts for rank neighborhoods. More...
void cs_rank_neighbors_sync_count_m (const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, cs_rank_neighbors_exchange_t exchange_type, MPI_Comm comm)
 Exchange send and receive counts for rank neighborhoods, using a given method. More...
cs_rank_neighbors_exchange_t cs_rank_neighbors_get_exchange_type (void)
 Get current type of rank neighbors collective algorithm choice. More...
void cs_rank_neighbors_set_exchange_type (cs_rank_neighbors_exchange_t t)
 Set current type of rank neighbors collective algorithm choice. More...
Management of parallel rank neighbors.
Algorithm names are based upon [11] and [10] .
◆ cs_rank_neighbors_count()
void cs_rank_neighbors_count ( const cs_rank_neighbors_t *  n,
size_t  n_elts,
const int *  elt_rank_index,
cs_lnum_t *  elt_rank_count
[in]npointer to rank neighborhood structure
[in]n_eltsnumber of elements
[in]elt_rank_indexelement rank index in neighborhood (size: n_elts)
[out]elt_rank_countelement rank count in neighborhood (size: n->size)
◆ cs_rank_neighbors_create()
cs_rank_neighbors_t * cs_rank_neighbors_create ( size_t  n_elts,
[in]elt_rankelement rank in
pointer to new rank neighborhood.
◆ cs_rank_neighbors_destroy()
void cs_rank_neighbors_destroy ( cs_rank_neighbors_t **  n)
[in,out]npointer to associated rank neighborhood
◆ cs_rank_neighbors_get_exchange_type()
cs_rank_neighbors_exchange_t cs_rank_neighbors_get_exchange_type ( void  )
◆ cs_rank_neighbors_set_exchange_type()
void cs_rank_neighbors_set_exchange_type ( cs_rank_neighbors_exchange_t  t)
ttype of rank neighbors collective algorithm choice
◆ cs_rank_neighbors_symmetrize()
void cs_rank_neighbors_symmetrize ( cs_rank_neighbors_t *  n,
MPI_Comm  comm
This is a collective operation, which ensures that if rank i has j among its neighbors, then j will also jave i among its neighbors.
[in,out]npointer to rank neighborhood structure
[in]commassociated communicator
◆ cs_rank_neighbors_sync_count()
void cs_rank_neighbors_sync_count ( const cs_rank_neighbors_t *  n_send,
cs_rank_neighbors_t **  n_recv,
const cs_lnum_t *  send_count,
cs_lnum_t **  recv_count,
MPI_Comm  comm
This allocates the n_recv ranks neighborhood structure and the recv_count counts array, which the caller is responsible for freeing.
[in]n_sendpointer to rank neighborhood used for sending
[out]n_recvpointer to rank neighborhood used for receiving
[in]send_countpointer to rank neighborhood used for sending
[in]recv_countpointer to rank neighborhood used for sending
◆ cs_rank_neighbors_sync_count_m()
void cs_rank_neighbors_sync_count_m ( const cs_rank_neighbors_t *  n_send,
MPI_Comm  comm
[in]exchange_typeexchange type
◆ cs_rank_neighbors_to_index()
void cs_rank_neighbors_to_index ( const cs_rank_neighbors_t *  n,
size_t  n_elts,
The elt_rank and elt_rank_index may be identical, in which case it is updated.
[in]elt_rankelement rank (size: n_elts)
[out]elt_rank_indexelement rank index in neighborhood (size: n_elts)
