cs_math_hip.h File Reference
#include <float.h>
#include "hip/hip_runtime.h"
#include <hip/hip_runtime_api.h>
#include "base/cs_base_hip.h"
+ Include dependency graph for cs_math_hip.h:
Classes
class  assembled_value< T,... >
 Class for value assembly using warp-based partial summation to reduce conflict occurences in downstream atomic addition. More...
class  assembled_value< T, Head, Tail... >
template<class V >
__device__ cs_hip_mask_t _conflict_mask (cs_hip_mask_t mask, V v) noexcept
 Return the bit mask of the threads that have the same value v. More...
template<class T >
__device__ bool _reduce_add (cs_hip_mask_t mask, cs_hip_mask_t peers, T &v) noexcept
 Reduction step for conflict-free addition. More...
template<typename T >
static __device__ void cs_math_3_normalize_hip (const T in[3], T out[3])
 Normalise a vector of 3 real values. More...
static __device__ T cs_math_3_square_norm_hip (const T in[3])
 Compute the square norm of a vector of 3 real values. More...
◆ _conflict_mask()
__device__ cs_hip_mask_t _conflict_mask ( cs_hip_mask_t  mask,
V  v
noexcept
This partitionins the incoming threads into groups whose members have the same v value.
This reduced to calling __match_any_sync on recent HIP (>=6.2) architectures.
[in]mask
[in]v
◆ _reduce_add()
__device__ bool _reduce_add ( cs_hip_mask_t  mask,
T &  v
noexcept
[in]maskmask for threads in warpp
[in,out]vvalue which should be reduced between threads
true for rank 0, false for others.
◆ cs_math_3_normalize_hip()
static __device__ void cs_math_3_normalize_hip ( const T  in[3],
T  out[3]
static
To normalize in-place, vin and vout may point to the same array.
[in]vinvector
[out]voutnormalized vector
◆ cs_math_3_square_norm_hip()
static __device__ T cs_math_3_square_norm_hip ( const T  in[3])
static
[in]vvector of 3 real values
square norm of v.
