cs_timer_stats.h File Reference
#include "base/cs_timer.h"
#include "base/cs_time_plot.h"
+ Include dependency graph for cs_timer_stats.h:
void cs_timer_stats_initialize (void)
 Initialize timer statistics handling. More...
void cs_timer_stats_finalize (void)
 Finalize timer statistics handling. More...
void cs_timer_stats_set_start_time (int time_id)
 Set a start time for time stats. More...
void cs_timer_stats_set_plot_options (cs_time_plot_format_t format, int frequency, int n_buffer_steps, double flush_wtime)
 Set global timer statistics plot options. More...
void cs_timer_stats_increment_time_step (void)
 Increment time step for timer statistics. More...
int cs_timer_stats_create (const char *parent_name, const char *name, const char *label)
 Create a timer statistics structure. More...
int cs_timer_stats_id_by_name (const char *name)
 Return the id of a defined statistic based on its name. More...
void cs_timer_stats_set_plot (int id, int plot)
 Enable or disable plotting for a timer statistic. More...
int cs_timer_stats_is_active (int id)
 indicate if a timer for a given statistic is currently active. More...
void cs_timer_stats_start (int id)
 Start a timer for a given statistic. More...
void cs_timer_stats_stop (int id)
 Stop a timer for a given statistic. More...
int cs_timer_stats_switch (int id)
 Start a timer for a given statistic, stopping previous timers of the same type which are not a parent, and starting inactive parent timers if necessary. More...
void cs_timer_stats_add_diff (int id, const cs_timer_t *t0, const cs_timer_t *t1)
 Add a timing range to an inactive timer. More...
void cs_timer_stats_define_defaults (void)
 Define default timer statistics. More...
void cs_timer_stats_increment_stage (void)
 Switch stage for time statistics. More...
◆ cs_timer_stats_add_diff()
void cs_timer_stats_add_diff ( int  id,
const cs_timer_t *  t0,
const cs_timer_t *  t1
This does not modify parent timers, so consistency of active and inactive timers must be ensured by the caller.
[in]idid of statistic
[in]t0oldest timer value
[in]t1most recent timer value
◆ cs_timer_stats_create()
int cs_timer_stats_create ( const char *  parent_name,
const char *  name,
const char *  label
[in]parent_namename of parent statistic, or nullptr
[in]nameassociated canonical name
[in]labelassociated label, or nullptr
id of new timer stats structure
◆ cs_timer_stats_define_defaults()
void cs_timer_stats_define_defaults ( void  )
This creates 2 statistic timer trees, whose roots ids are:
  • 0 for computational operations
  • 1 for computational stages
◆ cs_timer_stats_finalize()
void cs_timer_stats_finalize ( void  )
◆ cs_timer_stats_id_by_name()
int cs_timer_stats_id_by_name ( const char *  name)
If no timer with the given name exists, -1 is returned.
[in]namestatitic name
id of the statistic, or -1 if not found
◆ cs_timer_stats_increment_stage()
void cs_timer_stats_increment_stage ( void  )
This saves current totals then resets them.
◆ cs_timer_stats_increment_time_step()
void cs_timer_stats_increment_time_step ( void  )
◆ cs_timer_stats_initialize()
void cs_timer_stats_initialize ( void  )
◆ cs_timer_stats_is_active()
int cs_timer_stats_is_active ( int  id)
1 if active, 0 otherwise
◆ cs_timer_stats_set_plot()
void cs_timer_stats_set_plot ( int  id,
int  plot
By default plotting is enabled for all statistics, except root statistic 1 (as it measures the same total time as root 0, with a different subtree).
This function is only effective before the first call to cs_timer_stats_increment_time_step.
[in]plot0 to disable, 1 to enable
◆ cs_timer_stats_set_plot_options()
void cs_timer_stats_set_plot_options ( cs_time_plot_format_t  format,
int  frequency,
int  n_buffer_steps,
double  flush_wtime
[in]formatassociated file format
[in]frequencyplot every n time steps
[in]n_buffer_stepsnumber of time steps in output buffer if file is not to be kept open
[in]flush_wtimeelapsed time interval between file flushes (if < 0, no forced flush)
◆ cs_timer_stats_set_start_time()
void cs_timer_stats_set_start_time ( int  time_id)
This is useful to shift the time id for restarts. This function must not be called after cs_timer_stats_increment_time_step.
[in]time_idassociated starting time id
◆ cs_timer_stats_start()
void cs_timer_stats_start ( int  id)
Parents of the current statistic are also started, if not active.
If a timer with the same root but different parents is active, we assume the current operation is a subset of the active timer, so the timer is not started, so as to avoid having a sum of parts larger than the total.
◆ cs_timer_stats_stop()
void cs_timer_stats_stop ( int  id)
Children of the current statistic are also stopped, if active.
◆ cs_timer_stats_switch()
int cs_timer_stats_switch ( int  id)
[in]idid of statistic with same root
id of previously active statistic, or -1 in case of error
