cs_wall_distance.h
1#ifndef CS_WALL_DISTANCE_H
2#define CS_WALL_DISTANCE_H
5 * Compute distance to wall.
35 * Local headers
38#include "base/cs_defs.h"
41 * Type definitions
44typedef struct {
45
63 int method;
64
66
67/*=============================================================================
68 * Static global variables
69 *============================================================================*/
70
71/* Pointer to main time step structure */
72
74
75/*=============================================================================
76 * Public function prototypes
77 *============================================================================*/
78
79/*----------------------------------------------------------------------------*/
80/*
81 * \brief Compute distance to wall by solving a 3d diffusion equation.
82 *
83 * \param[in] iterns iteration number on Navier-Stokes equations
84 */
85/*----------------------------------------------------------------------------*/
86
87void
88cs_wall_distance(int iterns);
89
90/*----------------------------------------------------------------------------*/
91/*
92 * \param[in] visvdr dynamic viscosity in edge cells after
93 * driest velocity amortization
94 */
95/*----------------------------------------------------------------------------*/
96
97void
99
100/*----------------------------------------------------------------------------*/
105/*----------------------------------------------------------------------------*/
106
107void
109
110/*----------------------------------------------------------------------------*/
116/*----------------------------------------------------------------------------*/
117
120
121/*----------------------------------------------------------------------------*/
122
123#endif /* CS_WALL_DISTANCE_H */
Definition: cs_defs.h:332
void cs_wall_distance(int iterns)
Compute distance to wall by solving a 3d diffusion equation. Solve.
Definition: cs_wall_distance.cpp:136
const cs_wall_distance_options_t * cs_glob_wall_distance_options
Definition: cs_wall_distance.cpp:103
void cs_wall_distance_geometric(void)
Compute distance to wall by a brute force geometric approach (serial only)
Definition: cs_wall_distance.cpp:1072
void cs_wall_distance_yplus(cs_real_t visvdr[])
Compute the dimensionless distance to the wall solving a steady transport equation.
Definition: cs_wall_distance.cpp:645
cs_wall_distance_options_t * cs_get_glob_wall_distance_options(void)
Provide read/write access to cs_glob_wall_distance.
Definition: cs_wall_distance.cpp:1146
Definition: cs_wall_distance.h:44
int need_compute
Definition: cs_wall_distance.h:46
int is_up_to_date
Definition: cs_wall_distance.h:48
int method
Definition: cs_wall_distance.h:63
