cs_ale.cpp File Reference
+ Include dependency graph for cs_ale.cpp:
void cs_ale_compute_volume_from_displacement (cs_domain_t *domain)
 Compute of ALE volumic flux from displacement and deduced volume at time step n+1. More...
void cs_mesh_velocity_mass_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, const cs_real_t dt[], const cs_real_t crom[], const cs_real_t brom[], cs_real_t imasfl[], cs_real_t bmasfl[])
void cs_boundary_condition_ale_type (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, const bool init, const cs_real_t dt[], const int bc_type[], cs::mdspan< cs_real_t, 2, cs::layout::left > val_ext_vel)
void cs_ale_allocate (void)
 Allocation of ialtyb and impale for the ALE structure. More...
void cs_ale_update_mesh_quantities (cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol)
 Compute cell and face centers of gravity, cell volumes and update bad cells. More...
void cs_ale_project_displacement (const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj)
 Project the displacement on mesh vertices (solved on cell center). More...
void cs_ale_update_mesh (int itrale)
 Update mesh in the ALE framework. More...
void cs_ale_update_bcs (int *ale_bc_type, cs_real_3_t *b_fluid_vel)
 Update ALE BCs for required for the fluid. More...
void cs_ale_solve_mesh_velocity (const int iterns, const cs_real_t b_rho[], const cs_real_t i_mass_flux[], const cs_real_t b_mass_flux[])
 Solve a Poisson equation on the mesh velocity in ALE framework. More...
void cs_ale_activate (void)
 Activate the mesh velocity solving with CDO. More...
bool cs_ale_is_activated (void)
 Test if mesh velocity solving with CDO is activated. More...
void cs_ale_add_property_fields (void)
 Add "property" fields dedicated to the ALE model. More...
void cs_ale_initialize_volume_fields (void)
 Initialize volume fields dedicated to the ALE model. More...
void cs_ale_init_setup (cs_domain_t *domain)
 Setup the equations solving the mesh velocity when CDO is activated. More...
void cs_ale_log_setup (void)
void cs_ale_setup_boundaries (const cs_domain_t *domain)
 Setup the equations solving the mesh velocity. More...
void cs_ale_finalize_setup (cs_domain_t *domain)
 Finalize the setup stage for the equation of the mesh velocity. More...
void cs_ale_destroy_all (void)
 Free the main structure related to the ALE mesh velocity solving. More...
void cs_ale_restart_read (cs_restart_t *r)
 Read ALE data from restart file. More...
void cs_ale_restart_write (cs_restart_t *r)
 Write ALE data from restart file. More...
static cs_ale_data_t _cs_glob_ale_data
cs_ale_type_t cs_glob_ale = CS_ALE_NONE
cs_ale_data_t * cs_glob_ale_data = &_cs_glob_ale_data
int cs_glob_ale_n_ini_f = 0
int cs_glob_ale_need_init = -999
◆ cs_ale_activate()
void cs_ale_activate ( void  )
◆ cs_ale_add_property_fields()
void cs_ale_add_property_fields ( void  )
◆ cs_ale_allocate()
void cs_ale_allocate ( void  )
◆ cs_ale_compute_volume_from_displacement()
void cs_ale_compute_volume_from_displacement ( cs_domain_t *  domain)
◆ cs_ale_destroy_all()
void cs_ale_destroy_all ( void  )
◆ cs_ale_finalize_setup()
void cs_ale_finalize_setup ( cs_domain_t *  domain)
◆ cs_ale_init_setup()
void cs_ale_init_setup ( cs_domain_t *  domain)
◆ cs_ale_initialize_volume_fields()
void cs_ale_initialize_volume_fields ( void  )
◆ cs_ale_is_activated()
bool cs_ale_is_activated ( void  )
true if mesh velocity solving with CDO is requested, false otherwise
◆ cs_ale_log_setup()
void cs_ale_log_setup ( void  )
◆ cs_ale_project_displacement()
void cs_ale_project_displacement ( const int  ale_bc_type[],
const cs_real_3_t *  meshv,
const cs_real_3_t *  claale,
const cs_real_33_t *  clbale,
const cs_real_t *  dt,
cs_real_3_t *  disp_proj
[in]ale_bc_typeType of boundary for ALE
[in]meshvMesh velocity
[in]gradmMesh velocity gradient (du_i/dx_j : gradv[][i][j])
[in]claaleBoundary conditions A
[in]clbaleBoundary conditions B
[in]dtTime step
[out]disp_projDisplacement projected on vertices
◆ cs_ale_restart_read()
void cs_ale_restart_read ( cs_restart_t *  r)
[in,out]rassociated restart file pointer
◆ cs_ale_restart_write()
void cs_ale_restart_write ( cs_restart_t *  r)
◆ cs_ale_setup_boundaries()
void cs_ale_setup_boundaries ( const cs_domain_t *  domain)
[in]domainpointer to a cs_domain_t structure
◆ cs_ale_solve_mesh_velocity()
void cs_ale_solve_mesh_velocity ( const int  iterns,
It also updates the mesh displacement so that it can be used to update mass fluxes (due to mesh displacement).
[in]iternsNavier-Stokes iteration number
◆ cs_ale_update_bcs()
void cs_ale_update_bcs ( int *  ale_bc_type,
cs_real_3_t *  b_fluid_vel
[out]ale_bc_typetype of ALE bcs
[out]b_fluid_velFluid velocity at boundary faces
◆ cs_ale_update_mesh()
void cs_ale_update_mesh ( int  itrale)
[in]itralenumber of the current ALE iteration
◆ cs_ale_update_mesh_quantities()
void cs_ale_update_mesh_quantities ( cs_real_t *  min_vol,
cs_real_t *  max_vol,
cs_real_t *  tot_vol
[out]min_volMinimum cell volume
[out]max_volMaximum cell volume
[out]tot_volTotal cell volume
◆ cs_boundary_condition_ale_type()
void cs_boundary_condition_ale_type ( const cs_mesh_t *  m,
const cs_mesh_quantities_t *  mq,
const bool  init,
◆ cs_mesh_velocity_mass_flux()
void cs_mesh_velocity_mass_flux ( const cs_mesh_t *  m,
cs_real_t  imasfl[],
cs_real_t  bmasfl[]
◆ _cs_glob_ale_data
static
Initial value:
= {.impale = nullptr,
.bc_type = nullptr,
.ale_iteration = 0,
.implicit_coupling_ite = 0,
.i_mass_flux_ale = nullptr,
.b_mass_flux_ale = nullptr,
.gradu_pre = nullptr,
.gradp_pre = nullptr,
.gradvolf_pre = nullptr,
.gradhtot_pre = nullptr,
.gradrij_pre = nullptr,
.i_mass_flux_pre = nullptr,
.b_mass_flux_pre = nullptr,
.alprof_pre = nullptr,
.alprob_pre = nullptr,
.gamma_pre = nullptr}
◆ cs_glob_ale
◆ cs_glob_ale_data
cs_ale_data_t* cs_glob_ale_data = &_cs_glob_ale_data
◆ cs_glob_ale_n_ini_f
Number of iterations for fluid flow initialization
◆ cs_glob_ale_need_init
Indicate whether an iteration to initialize ALE is required
