cs_physical_properties_default.h File Reference
+ Include dependency graph for cs_physical_properties_default.h:
void cs_physical_properties_update (int iterns)
 Fills physical properties which are variable in time. More...
◆ cs_physical_properties_update()
void cs_physical_properties_update ( int  iterns)
[in]iternsNavier-Stokes sub-iterations indicator:
  • if strictly negative, indicate that this function is called outside Navier-Stokes loop
  • if positive, Navier-Stokes iteration number.
