cs_runaway_check.cpp File Reference
Runaway (diverging) computation detection. More...
#include <stdarg.h>
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "base/cs_reducers.h"
#include "base/cs_runaway_check.h"
+ Include dependency graph for cs_runaway_check.cpp:
int cs_runaway_check (void)
 Check that defined field bounds are not exceeded. More...
void cs_runaway_check_define_field_max (int f_id, cs_real_t max_allowed)
 Define maximum value for a field, beyon which computation is aborted. More...
void cs_runaway_check_finalize (void)
◆ cs_runaway_check()
int cs_runaway_check ( void  )
0 if no bounds are exceeded, 1 if bounds are exceeded.
◆ cs_runaway_check_define_field_max()
void cs_runaway_check_define_field_max ( int  f_id,
Currently, only one field is handled, so calling this multiple times replaced the previous setting. Using a negative field id removes this check.
◆ cs_runaway_check_finalize()
void cs_runaway_check_finalize ( void  )
