163 const double values[]);
Definition: cs_defs.h:332
int cs_notebook_parameter_is_present(const char *name, int *editable)
Check if a parameter value is present.
Definition: cs_notebook.cpp:376
void cs_notebook_uncertain_output(void)
Write uncertain values to output file.
Definition: cs_notebook.cpp:795
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.cpp:408
const char * cs_notebook_parameter_get_description(char *name)
Returns the description of the parameter (GUI defined).
Definition: cs_notebook.cpp:473
void cs_notebook_get_values(int n, const int ids[], double values[])
Get a group of notebook variable values.
Definition: cs_notebook.cpp:509
void cs_notebook_log_setup(void)
Output the notebook info to the setup log.
Definition: cs_notebook.cpp:591
void cs_notebook_log(void)
Print values of editable notebook variables to default log file.
Definition: cs_notebook.cpp:630
int cs_notebook_parameter_get_id(const char *name)
Get id associated with a notebook parameter.
Definition: cs_notebook.cpp:490
int cs_notebook_nb_var(void)
Number of notebook variables.
Definition: cs_notebook.cpp:698
const char * cs_notebook_name_by_id(int id)
Get name of a notebook parameter based on its id.
Definition: cs_notebook.cpp:776
void cs_notebook_parameter_set_value(const char *name, cs_real_t val)
Set a parameter value (real) for an editable parameter.
Definition: cs_notebook.cpp:426
void cs_notebook_var_change_editable(int id, bool val)
Change the editable property of the notebook parameter.
Definition: cs_notebook.cpp:755
void cs_notebook_load_from_file(void)
Initialize the notebook object (based on cs_tree_node_t).
Definition: cs_notebook.cpp:286
int cs_notebook_parameter_get_openturns_status(char *name)
Indicate whether the parameter is used for a study with openturns.
Definition: cs_notebook.cpp:456
void cs_notebook_set_values(int n, const int ids[], const double values[])
Set a group of notebook variable values.
Definition: cs_notebook.cpp:534
bool cs_notebook_var_is_editable(int id)
Indicate if the notebook parameter is editable.
Definition: cs_notebook.cpp:716
void cs_notebook_destroy_all(void)
Destroy the notebook structure.
Definition: cs_notebook.cpp:561
bool cs_notebook_var_is_read_from_checkpoint(int id)
Indicate if the notebook parameter is read at restart.
Definition: cs_notebook.cpp:737
