1#ifndef CS_RESTART_DEFAULT_H
2#define CS_RESTART_DEFAULT_H
struct _cs_map_name_to_id_t cs_map_name_to_id_t
Definition: cs_map.h:42
Definition: cs_restart.h:91
void cs_restart_read_variables(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, int t_id_flag, int read_flag[])
Read variables from checkpoint.
Definition: cs_restart_default.cpp:1970
void cs_restart_write_notebook_variables(cs_restart_t *r)
Write notebook parameters to main checkpoint.
Definition: cs_restart_default.cpp:2356
void cs_restart_read_field_info(cs_restart_t *r, cs_map_name_to_id_t **old_field_map)
Read field metadata from checkpoint.
Definition: cs_restart_default.cpp:1748
void cs_restart_initialize_fields_read_status(void)
Initialize fields read status array.
Definition: cs_restart_default.cpp:3358
void cs_restart_read_notebook_variables(cs_restart_t *r)
Read notebook parameters from main checkpoint.
Definition: cs_restart_default.cpp:2293
cs_restart_file_t
Definition: cs_restart_default.h:50
@ CS_RESTART_MAIN
Definition: cs_restart_default.h:53
@ CS_RESTART_AUXILIARY
Definition: cs_restart_default.h:54
@ CS_RESTART_LES_INFLOW
Definition: cs_restart_default.h:62
@ CS_RESTART_N_RESTART_FILES
Definition: cs_restart_default.h:64
@ CS_RESTART_1D_WALL_THERMAL
Definition: cs_restart_default.h:60
@ CS_RESTART_LAGR_STAT
Definition: cs_restart_default.h:58
@ CS_RESTART_DISABLED
Definition: cs_restart_default.h:52
@ CS_RESTART_RAD_TRANSFER
Definition: cs_restart_default.h:55
@ CS_RESTART_LAGR
Definition: cs_restart_default.h:57
@ CS_RESTART_IBM
Definition: cs_restart_default.h:63
void cs_restart_read_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and read them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.cpp:3247
int cs_restart_get_field_read_status(const int f_id)
Get checkpoint read status for a field based on its id.
Definition: cs_restart_default.cpp:3398
void cs_restart_write_bc_coeffs(cs_restart_t *r)
Write boundary condition coefficients for all fields to checkpoint.
Definition: cs_restart_default.cpp:2825
void cs_restart_read_linked_fields(cs_restart_t *r, const cs_map_name_to_id_t *old_field_map, const char *key, int read_flag[])
Read fields depending on others from checkpoint.
Definition: cs_restart_default.cpp:2412
void cs_restart_write_field_vals(cs_restart_t *r, int f_id, int t_id)
Write field values to checkpoint.
Definition: cs_restart_default.cpp:3111
void cs_restart_read_bc_coeffs(cs_restart_t *r)
Read boundary condition coefficients for all fields from checkpoint.
Definition: cs_restart_default.cpp:2678
void cs_restart_write_variables(cs_restart_t *r, int t_id_flag, int write_flag[])
Write variables to checkpoint.
Definition: cs_restart_default.cpp:2158
void cs_restart_read_time_step_info(cs_restart_t *r)
Read restart time step info.
Definition: cs_restart_default.cpp:3137
void cs_restart_set_auxiliary_field_options(void)
Set restart file values for fields when those values cannot be determined at field definition time.
Definition: cs_restart_default.cpp:3301
int cs_restart_read_field_vals(cs_restart_t *r, int f_id, int t_id)
Read field values from checkpoint.
Definition: cs_restart_default.cpp:2943
int cs_restart_write_linked_fields(cs_restart_t *r, const char *key, int write_flag[])
Write fields depending on others to checkpoint.
Definition: cs_restart_default.cpp:2584
void cs_restart_finalize_fields_read_status(void)
Finalize fields read status array.
Definition: cs_restart_default.cpp:3377
void cs_restart_write_fields(cs_restart_t *r, cs_restart_file_t r_id)
Loop over all fields and save them in the restart file which id is passed in argument if it matches t...
Definition: cs_restart_default.cpp:3212
void cs_restart_write_field_info(cs_restart_t *r)
Write field metadata to main checkpoint.
Definition: cs_restart_default.cpp:1888
