cs_reducers.h File Reference
#include "base/cs_base.h"
#include "base/cs_math.h"
+ Include dependency graph for cs_reducers.h:
Classes
struct  cs_float_n< stride >
struct  cs_double_n< stride >
struct  cs_int_n< stride >
struct  cs_data_1int_1float
struct  cs_data_1int_2float
struct  cs_data_2int_2float
struct  cs_data_1double_2float
struct  cs_data_3float_3float
struct  cs_data_double_n< stride >
struct  cs_data_double_int_n< stride >
struct  cs_reduce_min1r_max1r_sum2r
struct  cs_reduce_sum1i_min1float
struct  cs_reduce_max_1gnum
struct  cs_reduce_max1r
struct  cs_reduce_min3float_max3float
struct  cs_reduce_sum_nr< stride >
struct  cs_reduce_sum_ni< stride >
struct  cs_reduce_min_max_nr< stride >
struct  cs_reduce_min_max_sum_nr< stride >
struct  cs_reduce_min1float_max1float_sum1int
struct  cs_reduce_min1float_max1float_sum2int
struct  cs_reduce_sum1double_min1float_max1float
struct  cs_reduce_min_max_sum_nr_with_norm< stride >
struct  cs_reduce_min_max_weighted_sum_nr< stride >
struct  cs_reduce_min_max_weighted_sum_nr_with_norm< stride >
struct  cs_reduce_max1float_bcast3float
struct  cs_reduce_minmax_n< stride >
struct  cs_reduce_min_nr< stride >
struct  cs_reduce_max_nr< stride >
struct  cs_reduce_minmaxloc_n< stride >
struct  cs_reduce_max2double_sum2double_sum4i
