cs_paramedmem_coupling.h File Reference
#include "base/cs_field.h"
#include "base/cs_zone.h"
+ Include dependency graph for cs_paramedmem_coupling.h:
Namespaces
namespace  cs
Typedefs
using paramedmem_coupling_t = cs_paramedmem_coupling_t
Enumerations
enum  cs_medcpl_space_discr_t { CS_MEDCPL_ON_CELLS , CS_MEDCPL_ON_NODES , CS_MEDCPL_ON_NODES_FE }
enum  cs_medcpl_time_discr_t { CS_MEDCPL_NO_TIME , CS_MEDCPL_ONE_TIME , CS_MEDCPL_LINEAR_TIME }
enum  cs_medcpl_field_nature_t {
  CS_MEDCPL_FIELD_INT_CONSERVATION , CS_MEDCPL_FIELD_INT_MAXIMUM , CS_MEDCPL_FIELD_EXT_CONSERVATION , CS_MEDCPL_FIELD_EXT_MAXIMUM ,
  CS_MEDCPL_FIELD_N_NATURE
enum  cs_medcpl_dec_t { CS_MEDCPL_INTERPKERNELDEC , CS_MEDCPL_CFEMDEC }
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_id (int cpl_id)
 Retrieve coupling struct pointer by id. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_name (const char *name)
 Retrieve coupling struct pointer by name. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create (const char *app1_name, const char *app2_name, const char *cpl_name, cs_medcpl_dec_t type_dec)
 Create a new ParaMEDMEM coupling. More...
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create_uncoupled (const char *cpl_name)
 Create a new ParaMEDMEM handler structure with no actual coupling. More...
void cs_paramedmem_coupling_destroy (cs_paramedmem_coupling_t *c)
 Destroy a given ParaMEDMEM coupling structure. More...
void cs_paramedmem_coupling_all_finalize (void)
 Destroy all coupling structures. More...
int cs_paramedmem_get_number_of_couplings (void)
 Get number of defined couplings. More...
void cs_paramedmem_coupling_all_init (void)
 initialize couplings based on user functions. More...
void cs_paramedmem_coupling_define_mesh_fields (void)
 initialize coupled mesh and fields based on user functions. More...
void cs_paramedmem_coupling_log_setup (void)
 Log ParaMEDMEM coupling setup information. More...
◆ cs_medcpl_dec_t
Enumerator
CS_MEDCPL_CFEMDEC
◆ cs_medcpl_field_nature_t
Enumerator
◆ cs_medcpl_space_discr_t
Enumerator
CS_MEDCPL_ON_CELLS
CS_MEDCPL_ON_NODES
◆ cs_medcpl_time_discr_t
Enumerator
CS_MEDCPL_NO_TIME
CS_MEDCPL_ONE_TIME
◆ cs_paramedmem_coupling_all_finalize()
void cs_paramedmem_coupling_all_finalize ( void  )
◆ cs_paramedmem_coupling_all_init()
void cs_paramedmem_coupling_all_init ( void  )
◆ cs_paramedmem_coupling_by_id()
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_id ( int  cpl_id)
[in]cpl_idindex of the sought coupling
pointer to cs_paramedmem_coupling_t struct. Raise an error if the coupling does not exist.
◆ cs_paramedmem_coupling_by_name()
cs_paramedmem_coupling_t * cs_paramedmem_coupling_by_name ( const char *  name)
[in]namename of the coupling
pointer to cs_paramedmem_coupling_t struct or null if not found.
◆ cs_paramedmem_coupling_create()
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create ( const char *  app1_name,
const char *  app2_name,
const char *  cpl_name,
[in]app1_nameName of app n°1 or null if calling app is app1
[in]app2_nameName of app n°2 or null if calling app is app2
[in]cpl_nameName of the coupling. If null an automatic name is generated.
[in]type_decType of DEC used for Data exchange
pointer to newly created cs_paramedmem_coupling_t structure.
◆ cs_paramedmem_coupling_create_uncoupled()
cs_paramedmem_coupling_t * cs_paramedmem_coupling_create_uncoupled ( const char *  cpl_name)
This can be useful for a "dry run" when setting up a coupling, so as to first debug local commands before actually running in coupled mode.
In this case, data "received" matches the initialized values.
◆ cs_paramedmem_coupling_define_mesh_fields()
void cs_paramedmem_coupling_define_mesh_fields ( void  )
◆ cs_paramedmem_coupling_destroy()
void cs_paramedmem_coupling_destroy ( cs_paramedmem_coupling_t *  c)
[in]cpointer to cs_paramedmem_coupling_t structure
◆ cs_paramedmem_coupling_log_setup()
void cs_paramedmem_coupling_log_setup ( void  )
◆ cs_paramedmem_get_number_of_couplings()
int cs_paramedmem_get_number_of_couplings ( void  )
number of defined couplings (int)
