cs_sort_partition.cpp File Reference
#include <float.h>
#include "bft/bft_printf.h"
#include "base/cs_mem.h"
#include "base/cs_sort_partition.h"
+ Include dependency graph for cs_sort_partition.cpp:
void cs_sort_partition_dest_rank_id (cs_lnum_t sampling_factor, size_t elt_size, cs_lnum_t n_elts, const void *elts, const cs_lnum_t *weight, const cs_lnum_t order[], int dest_rank_id[], cs_sort_partition_s_to_elt_t s_to_elt, cs_sort_partition_compare_t compare, const void *f_input, MPI_Comm comm)
 Determine to which rank data elements should be sent for parallel sorting or ordering. More...
◆ cs_sort_partition_dest_rank_id()
void cs_sort_partition_dest_rank_id ( cs_lnum_t  sampling_factor,
size_t  elt_size,
cs_lnum_t  n_elts,
const void *  elts,
const cs_lnum_t *  weight,
int  dest_rank_id[],
const void *  f_input,
MPI_Comm  comm
[in]sampling_factornumber of samples per rank
[in]elt_sizesize associated with each element
[in]n_eltsnumber of elements to be indexed
[in]eltsarray of elements
[in]weightoptional weight of each element, or nullptr
[in]orderordering array
[out]dest_rank_iddestination rank id (size: n_elts)
[in]s_to_eltcoordinate to element conversion function
[in]comparecomparison function
[in]f_inputoptional input to s_to_elt and compare, or nullptr
[in]commMPI communicator on which we build the global index
