Include dependency graph for cs_param_types.h:Go to the source code of this file.
Classes | |
| struct | cs_param_convergence_t |
| Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or max. number of iterations) More... | |
| struct | cs_param_psteady_t |
| Set of parameters to check the convergence of the pseudo-steady algo. More... | |
| struct | cs_cdo_navsto_psteady_cvg_t |
Macros | |
| #define | CS_DOF_VTX_SCAL 0 |
| #define | CS_DOF_VTX_VECT 1 |
| #define | CS_DOF_FACE_SCAL 2 |
| #define | CS_DOF_FACE_VECT 3 |
| #define | CS_DOF_FACE_SCAP1 3 |
| #define | CS_DOF_FACE_SCAP2 4 |
| #define | CS_DOF_FACE_VECP0 3 |
| #define | CS_DOF_FACE_VECP1 5 |
| #define | CS_DOF_FACE_VECP2 6 |
| #define | CS_DOF_EDGE_SCAL 7 |
| #define | CS_N_DOF_CASES 8 |
| #define | CS_ISOTROPIC_DIFFUSION (1 << 0) |
| #define | CS_ORTHOTROPIC_DIFFUSION (1 << 1) |
| #define | CS_ANISOTROPIC_LEFT_DIFFUSION (1 << 2) |
| #define | CS_ANISOTROPIC_RIGHT_DIFFUSION (1 << 3) |
| #define | CS_ANISOTROPIC_DIFFUSION ((1 << 2) + (1 << 3)) |
| typedef void() | cs_analytic_func_t(cs_real_t time, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *coords, bool dense_output, void *input, cs_real_t *retval) |
| Generic function pointer for an evaluation relying on an analytic function. More... | |
| typedef void() | cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
| Generic function pointer for computing a quantity at predefined locations such as degrees of freedom (DoF): cells, faces, edges or or vertices. More... | |
| typedef void() | cs_time_func_t(double time, void *input, cs_real_t *retval) |
| Function which defines the evolution of a quantity according to the current time and any structure given as a parameter. More... | |
Enumerations | |
| enum | cs_param_space_scheme_t { CS_SPACE_SCHEME_LEGACY , CS_SPACE_SCHEME_CDOVB , CS_SPACE_SCHEME_CDOVCB , CS_SPACE_SCHEME_CDOEB , CS_SPACE_SCHEME_CDOFB , CS_SPACE_SCHEME_CDOCB , CS_SPACE_SCHEME_HHO_P0 , CS_SPACE_SCHEME_HHO_P1 , CS_SPACE_SCHEME_HHO_P2 , CS_SPACE_SCHEME_MACFB , CS_SPACE_N_SCHEMES } |
| Type of numerical scheme for the discretization in space. More... | |
| enum | cs_param_dof_reduction_t { CS_PARAM_REDUCTION_DERHAM , CS_PARAM_REDUCTION_AVERAGE , CS_PARAM_N_REDUCTIONS } |
| bool | cs_param_space_scheme_is_face_based (cs_param_space_scheme_t scheme) |
| Return true if the space scheme has degrees of freedom on faces, otherwise false. More... | |
| const char * | cs_param_get_space_scheme_name (cs_param_space_scheme_t scheme) |
| Get the name of the space discretization scheme. More... | |
| const char * | cs_param_get_time_scheme_name (cs_param_time_scheme_t scheme) |
| Get the name of the time discretization scheme. More... | |
| const char * | cs_param_get_advection_form_name (cs_param_advection_form_t adv_form) |
| Get the label associated to the advection formulation. More... | |
| const char * | cs_param_get_advection_scheme_name (cs_param_advection_scheme_t scheme) |
| Get the label of the advection scheme. More... | |
| const char * | cs_param_get_advection_strategy_name (cs_param_advection_strategy_t adv_stra) |
| Get the label associated to the advection strategy. More... | |
| const char * | cs_param_get_advection_extrapol_name (cs_param_advection_extrapol_t extrapol) |
| Get the label associated to the extrapolation used for the advection field. More... | |
| const char * | cs_param_get_bc_name (cs_param_bc_type_t bc) |
| Get the name of the type of boundary condition. More... | |
| const char * | cs_param_get_bc_enforcement_name (cs_param_bc_enforce_t type) |
| Get the name of the type of enforcement of the boundary condition. More... | |
| const char * | cs_param_get_nl_algo_name (cs_param_nl_algo_t algo) |
| Get the name of the non-linear algorithm. More... | |
| const char * | cs_param_get_nl_algo_label (cs_param_nl_algo_t algo) |
| Get the label (short name) of the non-linear algorithm. More... | |
| const char * | cs_param_get_solver_name (cs_param_solver_type_t solver) |
| Get the name of the solver. More... | |
| const char * | cs_param_get_precond_name (cs_param_precond_type_t precond) |
| Get the name of the preconditioner. More... | |
| const char * | cs_param_get_precond_block_name (cs_param_precond_block_t type) |
| Get the name of the type of block preconditioning. More... | |
| const char | cs_sep_h1 [80] |
| const char | cs_sep_h2 [80] |
| const char | cs_sepline [80] |
| const char | cs_med_sepline [50] |
Numerical settings for time discretization | |
| enum | cs_param_time_scheme_t { CS_TIME_SCHEME_STEADY , CS_TIME_SCHEME_EULER_IMPLICIT , CS_TIME_SCHEME_EULER_EXPLICIT , CS_TIME_SCHEME_CRANKNICO , CS_TIME_SCHEME_THETA , CS_TIME_SCHEME_BDF2 , CS_TIME_N_SCHEMES } |
Settings for non-linear algorithms | |
| enum | cs_param_nl_algo_t { CS_PARAM_NL_ALGO_NONE , CS_PARAM_NL_ALGO_PICARD , CS_PARAM_NL_ALGO_MODIFIED_PICARD , CS_PARAM_NL_ALGO_ANDERSON , CS_PARAM_N_NL_ALGOS } |
| Class of non-linear iterative algorithm. More... | |
| #define CS_PARAM_BC_CIRCULATION CS_BC_CIRCULATION |
Homogeneous Dirichlet boundary conditions. The value of a variable is set to zero.
| #define CS_PARAM_BC_DIRICHLET CS_BC_DIRICHLET |
| #define CS_PARAM_BC_HMG_DIRICHLET CS_BC_HMG_DIRICHLET |
| #define CS_PARAM_BC_HMG_NEUMANN CS_BC_HMG_NEUMANN |
| #define CS_PARAM_BC_NEUMANN CS_BC_NEUMANN |
| #define CS_PARAM_BC_NEUMANN_FULL CS_BC_NEUMANN_FULL |
| #define CS_PARAM_BC_ROBIN CS_BC_ROBIN |
| #define CS_PARAM_BC_SLIDING CS_BC_SYMMETRY |
| #define CS_PARAM_BC_WALL_PRECRIBED CS_BC_WALL_MODELLED |
| typedef void() cs_analytic_func_t(cs_real_t time, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *coords, bool dense_output, void *input, cs_real_t *retval) |
For the calling function, elt_ids is optional. If non-null, the coords array should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false.
| [in] | time | when ? |
| [in] | elt_ids | list of elements ids (in coords and retval) |
| [in] | coords | where ? |
| [in,out] | retval | resulting value(s). Must be allocated. |
| typedef void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
For the calling function, elt_ids is optional. If non-null, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false.
| typedef void() cs_time_func_t(double time, void *input, cs_real_t *retval) |
| [in] | time | value of the time at the end of the last iteration |
| [in] | retval | result of the evaluation |
Choice of how to extrapolate the advection field in the advection term.
Type of formulation for the advection term
Type of numerical scheme for the advection term
| Enumerator | |
| CS_PARAM_ADVECTION_SCHEME_CENTERED | centered discretization |
| CS_PARAM_ADVECTION_SCHEME_CIP | Continuous Interior Penalty discretization. Only available for CS_SPACE_SCHEME_CDOVCB space discretization. |
| CS_PARAM_ADVECTION_SCHEME_CIP_CW | Continuous Interior Penalty discretization. Only available for CS_SPACE_SCHEME_CDOVCB space discretization. Variant with a cellwise constant approximation of the advection field |
| CS_PARAM_ADVECTION_SCHEME_HYBRID_CENTERED_UPWIND | Centered discretization with a portion between [0,1] of upwinding. The portion is specified thanks to CS_EQKEY_ADV_UPWIND_PORTION If the portion is equal to 0, then one recovers CS_PARAM_ADVECTION_SCHEME_CENTERED. If the portion is equal to 1, then one recovers CS_PARAM_ADVECTION_SCHEME_UPWIND |
| CS_PARAM_ADVECTION_SCHEME_SAMARSKII | Weighting between an upwind and a centered discretization relying on the Peclet number. Weighting function = Samarskii |
| CS_PARAM_ADVECTION_SCHEME_SG | Weighting between an upwind and a centered discretization relying on the Peclet number. Weighting function = Scharfetter-Gummel |
| CS_PARAM_ADVECTION_SCHEME_UPWIND | Low order upwind discretization |
| CS_PARAM_ADVECTION_SCHEME_L0 | L0 stabilization |
| CS_PARAM_ADVECTION_SCHEME_CENTERED_V8 | centered discretization of v8 version |
| CS_PARAM_ADVECTION_SCHEME_UPWIND_V8 | upwind discretization of v8 version |
| CS_PARAM_ADVECTION_SCHEME_SOLU | centred scheme with consistent stabilization |
| CS_PARAM_ADVECTION_SCHEME_SOLU_SYM | centred scheme with consistent symetric stabilization |
| CS_PARAM_N_ADVECTION_SCHEMES | |
Choice of how to handle the advection term in an equation.
| Enumerator | |
| CS_PARAM_ADVECTION_IMPLICIT_FULL | The advection term is implicitly treated. The non-linearity stemming from this term has to be solved using a specific algorithm such as the Picard (fixed-point) technique or more elaborated techniques. |
| CS_PARAM_ADVECTION_IMPLICIT_LINEARIZED | The advection term is implicitly treated. The non-linearity stemming from this term is simplified. Namely, one assumes a linearized advection. This is equivalent to a one-step Picard technique. |
| CS_PARAM_ADVECTION_EXPLICIT | The advection term is treated explicitly. One keeps the non-linearity stemming from this term at the right hand-side. An extrapolation can be used for the advection field (cf. cs_param_advection_extrapol_t) |
| CS_PARAM_N_ADVECTION_STRATEGIES | |
Type of method for enforcing the boundary conditions. According to the type of numerical scheme, some enforcements are not available.
| Enumerator | |
| CS_PARAM_BC_ENFORCE_ALGEBRAIC | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with an algebraic manipulation of the linear system |
| CS_PARAM_BC_ENFORCE_PENALIZED | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a penalization technique using a huge value. |
| CS_PARAM_BC_ENFORCE_WEAK_NITSCHE | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a Nitsche-like penalization technique. This technique does not increase the conditioning number as much as CS_PARAM_BC_ENFORCE_PENALIZED but is more computationally intensive. The computation of the diffusion term should be activated with this choice. |
| CS_PARAM_BC_ENFORCE_WEAK_SYM | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a Nitsche-like penalization technique. This variant enables to keep the symmetry of the algebraic contrary to CS_PARAM_BC_ENFORCE_WEAK_NITSCHE. The computation of the diffusion term should be activated with this choice. |
| CS_PARAM_N_BC_ENFORCEMENTS | |
| enum cs_param_bc_type_t |
Type of boundary condition to enforce.
| enum cs_param_nl_algo_t |
Type of preconditioning by block
Type of preconditioner to use with the iterative solver. Some of the mentionned preconditioners are available only if the PETSc library is linked with code_saturne
| Enumerator | |
| CS_PARAM_PRECOND_NONE | No preconditioner |
| CS_PARAM_PRECOND_AMG | Algebraic multigrid preconditioner (additional options may be set using cs_param_amg_type_t) |
| CS_PARAM_PRECOND_BJACOB_ILU0 | Only with PETSc Block Jacobi with an ILU zero fill-in in each block |
| CS_PARAM_PRECOND_BJACOB_SGS | Only with PETSc Block Jacobi with a symmetric Gauss-Seidel in each block (rely on Eisenstat's trick with PETSc) |
| CS_PARAM_PRECOND_DIAG | Diagonal (also Jacobi) preconditioner. The cheapest one but not the most efficient one. |
| CS_PARAM_PRECOND_GKB_CG | Only with PETSc Golub-Kahan Bidiagonalization solver used as a preconditioner. Only useful if one has to solve a saddle-point system (such systems arise when solving Stokes or Navier-Stokes in a fully couple manner). Variant with CG as inner solver. |
| CS_PARAM_PRECOND_GKB_GMRES | Only with PETSc Golub-Kahan Bidiagonalization solver used as a preconditioner. Only useful if one has to solve a saddle-point system (such systems arise when solving Stokes or Navier-Stokes in a fully couple manner). Variant with GMRES as inner solver. |
| CS_PARAM_PRECOND_LU | Only with PETSc LU factorization (direct solver) with PETSc |
| CS_PARAM_PRECOND_ILU0 | Only with PETSc Incomplete LU factorization (fill-in coefficient set to 0) |
| CS_PARAM_PRECOND_ICC0 | Only with PETSc Incomplete Cholesky factorization (fill-in coefficient set to 0). This is variant of the ILU0 preconditioner dedicated to symmetric positive definite system |
| CS_PARAM_PRECOND_MUMPS | Only with MUMPS Sparse direct solver available with the MUMPS library and used as a preconditioner |
| CS_PARAM_PRECOND_HPDDM | Only with PETSc Use HPDDM and Geneo approach for coarse space with PETSc |
| CS_PARAM_PRECOND_POLY1 | Neumann polynomial preconditioning. Polynoms of order 1. |
| CS_PARAM_PRECOND_POLY2 | Neumann polynomial preconditioning. Polynoms of order 2. |
| CS_PARAM_PRECOND_SSOR | Symmetric Successive OverRelaxations (can be seen as a symmetric Gauss-Seidel preconditioner) |
| CS_PARAM_N_PRECOND_TYPES | |
Way to renormalize (or not) the residual arising during the resolution of linear systems
Type of solver used to solve a linear system. Some of the mentionned solver are available only if the PETSc library is linked with code_saturne.
| Enumerator | |
| CS_PARAM_SOLVER_NONE | No iterative solver (equivalent to a "preonly" choice in PETSc) |
| CS_PARAM_SOLVER_AMG | Algebraic multigrid solver (additional options may be set using cs_param_amg_type_t) |
| CS_PARAM_SOLVER_BICGS | Bi-Conjugate gradient (useful for non-symmetric systems) |
| CS_PARAM_SOLVER_BICGS2 | Stabilized Bi-Conjugate gradient (useful for non-symmetric systems) |
| CS_PARAM_SOLVER_CG | Conjugate Gradient (solver of choice for symmetric positive definite systems) |
| CS_PARAM_SOLVER_CR3 | 3-layer conjugate residual (can handle non-symmetric systems) |
| CS_PARAM_SOLVER_FCG | Flexible Conjugate Gradient (variant of the CG when the preconditioner may change from one iteration to another. For instance when using an AMG as preconditioner) |
| CS_PARAM_SOLVER_FGMRES | Only with PETSc Flexible Generalized Minimal RESidual |
| CS_PARAM_SOLVER_GAUSS_SEIDEL | Gauss-Seidel |
| CS_PARAM_SOLVER_GCR | Generalized conjugate residual (flexible iterative solver for symmetric or non-symmetric system) |
| CS_PARAM_SOLVER_GMRES | Only with PETSc Generalized Minimal RESidual |
| CS_PARAM_SOLVER_JACOBI | Jacobi (diagonal relaxation) |
| CS_PARAM_SOLVER_MUMPS | Only with PETSc or MUMPS MUMPS sparse direct solver |
| CS_PARAM_SOLVER_SYM_GAUSS_SEIDEL | Symmetric Gauss-Seidel |
| CS_PARAM_SOLVER_USER_DEFINED | User-defined iterative solver. It relies on the implementation of the the function cs_user_sles_it_solver() |
| CS_PARAM_N_SOLVER_TYPES | |
How is defined the degree of freedom.
Type of numerical scheme for the discretization in time
| const char * cs_param_get_advection_extrapol_name | ( | cs_param_advection_extrapol_t | extrapol | ) |
| [in] | extrapol | type of extrapolation for the advection field |
| const char * cs_param_get_advection_form_name | ( | cs_param_advection_form_t | adv_form | ) |
| [in] | adv_form | type of advection formulation |
| const char * cs_param_get_advection_scheme_name | ( | cs_param_advection_scheme_t | scheme | ) |
| [in] | scheme | type of advection scheme |
| const char * cs_param_get_advection_strategy_name | ( | cs_param_advection_strategy_t | adv_stra | ) |
| [in] | adv_stra | type of advection strategy |
| const char * cs_param_get_bc_enforcement_name | ( | cs_param_bc_enforce_t | type | ) |
| [in] | type | type of enforcement of boundary conditions |
| const char * cs_param_get_bc_name | ( | cs_param_bc_type_t | type | ) |
| [in] | type | type of boundary condition |
| const char * cs_param_get_nl_algo_label | ( | cs_param_nl_algo_t | algo | ) |
| [in] | algo | type of algorithm |
| const char * cs_param_get_nl_algo_name | ( | cs_param_nl_algo_t | algo | ) |
| const char * cs_param_get_precond_block_name | ( | cs_param_precond_block_t | type | ) |
| [in] | type | type of block preconditioning |
| const char * cs_param_get_precond_name | ( | cs_param_precond_type_t | precond | ) |
| [in] | precond | type of preconditioner |
| const char * cs_param_get_solver_name | ( | cs_param_solver_type_t | solver | ) |
| [in] | solver | type of iterative solver |
| const char * cs_param_get_space_scheme_name | ( | cs_param_space_scheme_t | scheme | ) |
| [in] | scheme | type of space scheme |
| const char * cs_param_get_time_scheme_name | ( | cs_param_time_scheme_t | scheme | ) |
| [in] | scheme | type of time scheme |
| bool cs_param_space_scheme_is_face_based | ( | cs_param_space_scheme_t | scheme | ) |
extern |
extern |
extern |
extern |
