1#ifndef CS_ASTER_COUPLING_H
2#define CS_ASTER_COUPLING_H
void cs_aster_coupling_set_final_cvg(int icved)
Send global convergence value of FSI calculations.
Definition: cs_aster_coupling.cpp:1559
int cs_aster_coupling_get_current_cvg(void)
Receive convergence value of code_saturne/code_aster coupling.
Definition: cs_aster_coupling.cpp:1527
void cs_aster_coupling_set_coefficients(cs_real_t aexxst, cs_real_t bexxst, cs_real_t cfopre)
Set coefficient for prediction.
Definition: cs_aster_coupling.cpp:865
void cs_aster_coupling_compute_displacement(cs_real_t disp[][3])
Compute predicted or exact displacement of the fluid/structure interface.
Definition: cs_aster_coupling.cpp:1410
void cs_aster_coupling_send_bstress(void)
Send boundary stresse acting on the fluid/structure interface.
Definition: cs_aster_coupling.cpp:1168
void cs_aster_coupling_finalize(void)
Finalize exchange with code_aster.
Definition: cs_aster_coupling.cpp:815
struct _cs_aster_coupling_t cs_aster_coupling_t
Definition: cs_aster_coupling.h:48
int cs_aster_coupling_get_visualization(void)
Get visualization level for code_aster coupling.
Definition: cs_aster_coupling.cpp:1616
void cs_aster_coupling_set_visualization(int visualization)
Set visualization level for code_aster coupling.
Definition: cs_aster_coupling.cpp:1629
void cs_aster_coupling_initialize(int nalimx, cs_real_t epalim)
Initial exchange with code_aster.
Definition: cs_aster_coupling.cpp:643
void cs_aster_coupling_exchange_time_step(cs_real_t c_dt[])
Exchange time-step information with code_aster.
Definition: cs_aster_coupling.cpp:1048
int cs_aster_coupling_n_couplings(void)
Query number of couplings with code_aster.
Definition: cs_aster_coupling.cpp:621
void cs_aster_coupling_geometry(cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t almax)
Extract and exchange mesh information for surfaces coupled with code_aster.
Definition: cs_aster_coupling.cpp:891
cs_real_3_t * cs_aster_coupling_get_bstress_pointer(void)
Return pointer to array of boundary stress at faces coupled with code_aster.
Definition: cs_aster_coupling.cpp:1149
void cs_aster_coupling_set_verbosity(int verbosity)
Set verbosity level for code_aster coupling.
Definition: cs_aster_coupling.cpp:1597
int cs_aster_coupling_get_verbosity(void)
Get verbosity level for code_aster coupling.
Definition: cs_aster_coupling.cpp:1583
void cs_aster_coupling_recv_displacement(void)
Receive displacements of the fluid/structure interface.
Definition: cs_aster_coupling.cpp:1335
cs_real_t cs_aster_coupling_get_current_residual(void)
Definition: cs_aster_coupling.cpp:1543
void cs_aster_coupling_evaluate_cvg(void)
Evaluate convergence of the coupling.
Definition: cs_aster_coupling.cpp:1276
void cs_aster_coupling_save_values(void)
Save previous values.
Definition: cs_aster_coupling.cpp:1379
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
Definition: cs_defs.h:325
