◆ cs_resource_get_max_timestep()
| void cs_resource_get_max_timestep |
int |
ts_cur, |
int * |
ts_max |
Limit number of remaining time steps if the remaining allocated time is too small to attain the requested number of steps.
- Parameters
| [in] | ts_cur | current time step number |
| [in,out] | ts_max | maximum time step number |
◆ cs_resource_get_wt_limit()
| double cs_resource_get_wt_limit |
void |
Get current wall-clock time limit.
- Returns
- current wall-time limit (in seconds), or -1
◆ cs_resource_set_wt_limit()
| void cs_resource_set_wt_limit |
double |
wt | ) |
Set wall-clock time limit.
- Parameters
| [in] | wt | wall-time limit (in seconds), or -1 |
◆ cs_resource_wt_limit_check_set_status()
| void cs_resource_wt_limit_check_set_status |
const bool |
status | ) |
Set wall time limit check to false or true.
- Parameters
| [in] | status | status to set (activation or deactivation) |
