cs_aster_coupling.cpp File Reference
#include <stdarg.h>
#include <mpi.h>
#include <ple_coupling.h>
#include <ple_defs.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "fvm/fvm_io_num.h"
#include "fvm/fvm_nodal.h"
#include "fvm/fvm_nodal_extract.h"
#include "alge/cs_blas.h"
#include "alge/cs_face_to_vertex.h"
#include "base/cs_all_to_all.h"
#include "base/cs_array.h"
#include "base/cs_coupling.h"
#include "base/cs_interface.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "base/cs_paramedmem_coupling_utils.h"
#include "base/cs_part_to_block.h"
#include "base/cs_post.h"
#include "mesh/cs_mesh.h"
#include "mesh/cs_mesh_connect.h"
#include "base/cs_aster_coupling.h"
+ Include dependency graph for cs_aster_coupling.cpp:
int cs_aster_coupling_n_couplings (void)
 Query number of couplings with code_aster. More...
void cs_aster_coupling_initialize (int nalimx, cs_real_t epalim)
 Initial exchange with code_aster. More...
void cs_aster_coupling_finalize (void)
 Finalize coupling with code_aster. More...
void cs_aster_coupling_set_coefficients (cs_real_t aexxst, cs_real_t bexxst, cs_real_t cfopre)
 Set coefficient for prediction. More...
void cs_aster_coupling_geometry (cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t almax)
 Extract and exchange mesh information for surfaces coupled with code_aster. More...
void cs_aster_coupling_exchange_time_step (cs_real_t c_dt[])
 Exchange time-step information with code_aster. More...
cs_real_3_t * cs_aster_coupling_get_bstress_pointer (void)
 Return pointer to array of boundary stress at faces coupled with code_aster. More...
void cs_aster_coupling_send_bstress (void)
 Send stresses acting on the fluid/structure interface. More...
void cs_aster_coupling_evaluate_cvg (void)
 Evaluate convergence of the coupling. More...
void cs_aster_coupling_recv_displacement (void)
 Receive displacements of the fluid/structure interface. More...
void cs_aster_coupling_save_values (void)
 Save previous values. More...
void cs_aster_coupling_compute_displacement (cs_real_t disp[][3])
 Compute predicted or exact displacement of the fluid/structure interface. More...
int cs_aster_coupling_get_current_cvg (void)
 Receive convergence value of code_saturne/code_aster coupling. More...
cs_real_t cs_aster_coupling_get_current_residual (void)
void cs_aster_coupling_set_final_cvg (int icved)
 Send global convergence value of FSI calculations. More...
int cs_aster_coupling_get_verbosity (void)
 Get verbosity level for code_aster coupling. More...
void cs_aster_coupling_set_verbosity (int verbosity)
 Set verbosity level for code_aster coupling. More...
int cs_aster_coupling_get_visualization (void)
 Get visualization level for code_aster coupling. More...
void cs_aster_coupling_set_visualization (int visualization)
 Set visualization level for code_aster coupling. More...
◆ cs_aster_coupling_compute_displacement()
void cs_aster_coupling_compute_displacement ( cs_real_t  disp[][3])
[out]dispprescribed displacement at vertices
◆ cs_aster_coupling_evaluate_cvg()
void cs_aster_coupling_evaluate_cvg ( void  )
◆ cs_aster_coupling_exchange_time_step()
void cs_aster_coupling_exchange_time_step ( cs_real_t  c_dt[])
[in,out]c_dttime step at each cell
◆ cs_aster_coupling_finalize()
void cs_aster_coupling_finalize ( void  )
Finalize exchange with code_aster.
◆ cs_aster_coupling_geometry()
void cs_aster_coupling_geometry ( cs_lnum_t  n_faces,
const cs_lnum_t *  face_ids,
cs_real_t  almax
[in]n_facesnumber of coupled faces.
[in]face_idsids of coupled faces (ordered by increasing id)
[in]almaxcharacteristic macroscopic domain length
◆ cs_aster_coupling_get_bstress_pointer()
cs_real_3_t * cs_aster_coupling_get_bstress_pointer ( void  )
array of boundary stress from fluid at coupled faces
◆ cs_aster_coupling_get_current_cvg()
int cs_aster_coupling_get_current_cvg ( void  )
convergence indicator computed by coupling scheme (1: converged, 0: not converged)
◆ cs_aster_coupling_get_current_residual()
cs_real_t cs_aster_coupling_get_current_residual ( void  )
residual of the convergence
◆ cs_aster_coupling_get_verbosity()
int cs_aster_coupling_get_verbosity ( void  )
◆ cs_aster_coupling_get_visualization()
int cs_aster_coupling_get_visualization ( void  )
◆ cs_aster_coupling_initialize()
void cs_aster_coupling_initialize ( int  nalimx,
cs_real_t  epalim
[in]nalimxmaximum number of Noneation iterations of the structure displacement
[in]epalimrelative precision of Noneation of the structure displacement
◆ cs_aster_coupling_n_couplings()
int cs_aster_coupling_n_couplings ( void  )
Currently, a single coupling with code_aster is possible.
◆ cs_aster_coupling_recv_displacement()
void cs_aster_coupling_recv_displacement ( void  )
◆ cs_aster_coupling_save_values()
void cs_aster_coupling_save_values ( void  )
◆ cs_aster_coupling_send_bstress()
void cs_aster_coupling_send_bstress ( void  )
Send boundary stresse acting on the fluid/structure interface.
◆ cs_aster_coupling_set_coefficients()
void cs_aster_coupling_set_coefficients ( cs_real_t  aexxst,
cs_real_t  bexxst,
cs_real_t  cfopre
◆ cs_aster_coupling_set_final_cvg()
void cs_aster_coupling_set_final_cvg ( int  icved)
[in]icvedconvergence indicator (1: converged, 0: not converged)
◆ cs_aster_coupling_set_verbosity()
void cs_aster_coupling_set_verbosity ( int  verbosity)
[in]verbosityverbosity level for code_aster coupling
◆ cs_aster_coupling_set_visualization()
void cs_aster_coupling_set_visualization ( int  visualization)
[in]visualizationvisualization level for code_aster coupling
