| #define | CS_MALLOC(_ptr, _ni, _type) |
| | Allocate memory for _ni elements of type _type. More...
| #define | CS_MALLOC_HD(_ptr, _ni, _type, _mode) |
| #define | CS_REALLOC(_ptr, _ni, _type) |
| | Reallocate memory for _ni elements of type _type. More...
| #define | CS_REALLOC_HD(_ptr, _ni, _type, _mode) |
| #define | CS_FREE(_ptr) cs_mem_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL |
| #define | CS_MEMALIGN(_ptr, _align, _ni, _type) |
| | Allocate aligned memory for _ni elements of type _type. More...
| #define | cs_alloc_mode CS_ALLOC_HOST |
| #define | cs_alloc_mode_read_mostly CS_ALLOC_HOST |
| #define | cs_alloc_mode_device CS_ALLOC_HOST |
| #define | cs_associate_device_ptr(_host_ptr, _ni, _size) ; |
| | Associate device memory with a given host memory pointer. More...
| #define | cs_disassociate_device_ptr(_host_ptr) ; |
| | Detach device memory from a given host memory pointer. More...
| #define | cs_set_alloc_mode(_host_ptr, mode) ; |
| | Set allocation mode for an already allocated pointer. More...
| #define | cs_set_alloc_mode_r(_host_ptr, mode) ; |
| | Set allocation mode for an already allocated pointer using pass by reference semantics for the pointer (C++ only). More...
| #define | cs_mem_advise_set_read_mostly(ptr) ; |
| | Advise memory system that a given allocation will be mostly read. More...
| int | cs_mem_stats (uint64_t *alloc_cur, uint64_t *alloc_max, uint64_t *n_allocs, uint64_t *n_reallocs, uint64_t *n_frees, uint64_t *n_current) |
| | Return memory allocation stats, if available. More...
| void * | cs_get_device_ptr (void *ptr) |
| | Return matching device pointer for a given pointer. More...
| const void * | cs_get_device_ptr_const (const void *ptr) |
| | Return matching device pointer for a given constant pointer. More...
| cs_alloc_mode_t | cs_check_device_ptr (const void *ptr) |
| | Check if a pointer is associated with a device. More...
| bool | cs_mem_is_device_ptr (const void *ptr) |
| | Check if a pointer is a device (or shared) pointer. More...
| void | cs_mem_advise_unset_read_mostly (void *ptr) |
| void | cs_sync_h2d (const void *ptr) |
| | Synchronize data from host to device. More...
| void | cs_sync_h2d_start (const void *ptr) |
| | Start synchronization of data from host to device. More...
| void | cs_sync_d2h (void *ptr) |
| | Synchronize data from device to host. More...
| void | cs_sync_d2h_start (void *ptr) |
| | Start synchronization of data from device to host. More...
| void | cs_sync_d2h_if_needed (void *ptr) |
| | Synchronize data from device to host, only if needed. More...
| void | cs_sync_d2h_if_needed_start (void *ptr) |
| | Start synchronization of data from device to host, only if needed. More...
| void | cs_prefetch_h2d (const void *ptr, size_t size) |
| | Prefetch data from host to device. More...
| void | cs_prefetch_d2h (void *ptr, size_t size) |
| | Prefetch data from device to host. More...
| void | cs_mem_hd_async_wait (void) |
| | Wait for asynchronous memory operations between device and pinned host memory to finish. More...
| void * cs_get_device_ptr |
void * |
ptr | ) |
inline |
If separate pointers are used on the host and device, the host pointer should be used with this function.
If memory is not allocated on device yet at the call site, it will be allocated automatically by this function.
- Parameters
- Returns
- pointer to device memory.
| const void * cs_get_device_ptr_const |
const void * |
ptr | ) |
inline |
- Parameters
- Returns
| int cs_mem_stats |
uint64_t * |
alloc_cur, |
uint64_t * |
alloc_max, |
uint64_t * |
n_allocs, |
uint64_t * |
n_reallocs, |
uint64_t * |
n_frees, |
uint64_t * |
n_current |
Availability of statistics depends on the cs_mem_init options.
- Parameters
| [out] | alloc_cur | current allocation size, or nullptr |
| [out] | alloc_max | max allocation size, or nullptr |
| [out] | n_allocs | total number of allocations, or nullptr |
| [out] | n_reallocs | total number of reallocations, or nullptr |
| [out] | n_frees | total number of frees, or nullptr |
| [out] | n_current | total number of current allocations, or nullptr |
\return 1 if stats are available, O otherwise.
With acceleration, alloc_cur and alloc_max should have 4 entries each 0: host 1: pinned (included in host) 2: unified (included in host and device) 3: device
- Parameters
| [out] | alloc_cur | current allocation sizes, or nullptr |
| [out] | alloc_max | max allocation sizes, or nullptr |
- Returns
- 1 if stats are available, O otherwise.
| void cs_sync_d2h |
void * |
ptr | ) |
inline |
If separate allocations are used on the host and device (mode == CS_ALLOC_HOST_DEVICE), the host pointer should be passed to this function.
Depending on the allocaton type, this can imply a copy, data prefetch, or a no-op.
This function assumes the provided pointer was allocated using CS_MALLOC_HD or CS_REALLOC_HD, as it uses the associated mapping to determine associated metadata.
- Parameters
| [in,out] | ptr | pointer to values to copy or prefetch |
| void cs_sync_d2h_if_needed |
void * |
ptr | ) |
inline |
Depending on the allocation type, this can imply a copy, data prefetch, or a no-op.
No operation occurs if the provided pointer was not allocated using CS_MALLOC_HD or CS_REALLOC_HD, as it uses the associated mapping to determine associated metadata.
- Parameters
| void cs_sync_d2h_if_needed_start |
void * |
ptr | ) |
inline |
- Parameters
| void cs_sync_d2h_start |
void * |
ptr | ) |
inline |
- Parameters
| void cs_sync_h2d |
const void * |
ptr | ) |
inline |
- Parameters
| [in,out] | ptr | host pointer to values to copy or prefetch |
| void cs_sync_h2d_start |
const void * |
ptr | ) |
inline |
- Parameters
