45#if defined(__NEC__) && defined(__ve__)
47# define CS_NUMBERING_SIMD_SIZE 256
49#elif defined(SX) && defined(_SX)
51# define CS_NUMBERING_SIMD_SIZE 256
53#elif defined(__AVX512F__)
55# define CS_NUMBERING_SIMD_SIZE 64
57#elif defined(HAVE_CUDA)
59# define CS_NUMBERING_SIMD_SIZE 32
61#elif defined(HAVE_HIP)
63#if defined(__GFX8__) || defined(__GFX9__)
64# define CS_NUMBERING_SIMD_SIZE 64
66# define CS_NUMBERING_SIMD_SIZE 32
71# define CS_NUMBERING_SIMD_SIZE 4
143 size_t elt_bytes = n_elts * type_size;
144 size_t n_ceil = (((elt_bytes-1)/simd_bytes+1)*simd_bytes);
145 return n_ceil / type_size;
223 const char *description,
Definition: cs_defs.h:325
cs_log_t
Definition: cs_log.h:44
cs_numbering_t * cs_numbering_create_threaded(int n_threads, int n_groups, cs_lnum_t group_index[])
Create a default numbering information structure in case of threading.
Definition: cs_numbering.cpp:590
cs_numbering_t * cs_numbering_create_vectorized(cs_lnum_t n_elts, int vector_size)
Create a default numbering information structure in case of vectorization.
Definition: cs_numbering.cpp:548
void cs_numbering_log_info(cs_log_t log, const char *description, const cs_numbering_t *numbering)
Log information relative to a cs_numbering_t structure.
Definition: cs_numbering.cpp:648
cs_numbering_t * cs_numbering_create_default(cs_lnum_t n_elts)
Create a default numbering information structure.
Definition: cs_numbering.cpp:512
void cs_numbering_destroy(cs_numbering_t **numbering)
Destroy a numbering information structure.
Definition: cs_numbering.cpp:627
static size_t cs_numbering_simd_size(cs_lnum_t n_elts, size_t type_size)
Round size of array to ensure SIMD alignment.
Definition: cs_numbering.h:139
const char * cs_numbering_type_name[]
Definition: cs_numbering.cpp:69
cs_numbering_type_t
Definition: cs_numbering.h:81
@ CS_NUMBERING_THREADS
Definition: cs_numbering.h:85
@ CS_NUMBERING_VECTORIZE
Definition: cs_numbering.h:84
@ CS_NUMBERING_DEFAULT
Definition: cs_numbering.h:83
#define CS_NUMBERING_SIMD_SIZE
Definition: cs_numbering.h:71
void cs_numbering_dump(const cs_numbering_t *numbering)
Dump a cs_numbering_t structure.
Definition: cs_numbering.cpp:733
Definition: cs_numbering.h:91
cs_lnum_t * group_index
Definition: cs_numbering.h:106
int n_no_adj_halo_groups
Definition: cs_numbering.h:100
int vector_size
Definition: cs_numbering.h:95
cs_numbering_type_t type
Definition: cs_numbering.h:93
int n_threads
Definition: cs_numbering.h:97
int n_groups
Definition: cs_numbering.h:98
cs_lnum_t n_no_adj_halo_elts
Definition: cs_numbering.h:103
