cs_runaway_check.h File Reference
+ Include dependency graph for cs_runaway_check.h:
int cs_runaway_check (void)
 Check that defined field bounds are not exceeded. More...
void cs_runaway_check_define_field_max (int f_id, cs_real_t max_allowed)
 Define maximum value for a field, beyon which computation is aborted. More...
void cs_runaway_check_finalize (void)
◆ cs_runaway_check()
int cs_runaway_check ( void  )
0 if no bounds are exceeded, 1 if bounds are exceeded.
◆ cs_runaway_check_define_field_max()
void cs_runaway_check_define_field_max ( int  f_id,
Currently, only one field is handled, so calling this multiple times replaced the previous setting. Using a negative field id removes this check.
◆ cs_runaway_check_finalize()
void cs_runaway_check_finalize ( void  )
