cs_solid_zone.h
1#ifndef CS_SOLID_ZONE_H
2#define CS_SOLID_ZONE_H
5 * Solid zones handling.
35 * Local headers
38#include "base/cs_base.h"
40#include "base/cs_zone.h"
43 * Macro definitions
45
47 * Type definitions
49
50/*=============================================================================
51 * Global variables
53
54/*============================================================================
55 * Public function prototypes
57
58/*----------------------------------------------------------------------------*/
59/*
60 * \brief build solid flag for mesh cells.
61 *
62 * If no solid cells are present, returned pointer is null.
63
64 * If non-empty, the caller is responsible for freeing the flag
65 *
66 * \param[in] m pointer to mesh
67 *
68 * \return solid cell flag array (0 is fluid, 1 if solid), or null
69 */
70/*----------------------------------------------------------------------------*/
71
72int *
74
75/*----------------------------------------------------------------------------*/
76/*
77 * \brief Zero an array on cells of a solid zone
78 *
79 * \param[in] stride array stride
80 * \param[out] a array of cell values
81 */
82/*----------------------------------------------------------------------------*/
83
84void
86 cs_real_t *a);
87
88/*----------------------------------------------------------------------------*/
95/*----------------------------------------------------------------------------*/
96
97void
99 cs_real_t a[]);
100
101/*----------------------------------------------------------------------------*/
102
103#endif /* CS_SOLID_ZONE_H */
Definition: cs_defs.h:332
int * cs_solid_zone_flag(const cs_mesh_t *m)
Definition: cs_solid_zone.cpp:132
void cs_solid_zone_set_scalar_on_cells(cs_real_t ref_val, cs_real_t a[])
Assign a constant scalar value to cells of a solid zone.
Definition: cs_solid_zone.cpp:214
void cs_solid_zone_set_zero_on_cells(int stride, cs_real_t *a)
Zero an array on cells of a solid zone.
Definition: cs_solid_zone.cpp:159
Definition: cs_mesh.h:85
