cs_halo.h File Reference
+ Include dependency graph for cs_halo.h:
Classes
struct  cs_halo_t
Typedefs
typedef struct _cs_halo_state_t cs_halo_state_t
Enumerations
enum  cs_halo_type_t { CS_HALO_STANDARD , CS_HALO_EXTENDED , CS_HALO_N_TYPES }
enum  cs_halo_comm_mode_t { CS_HALO_COMM_P2P , CS_HALO_COMM_RMA_GET }
cs_halo_t * cs_halo_create (const cs_interface_set_t *ifs)
 Create a halo structure given an interface set. More...
void cs_halo_create_complete (cs_halo_t *halo)
 Ready halo for use. More...
cs_halo_t * cs_halo_create_from_ref (const cs_halo_t *ref)
 Create a halo structure, given a reference halo. More...
cs_halo_t * cs_halo_create_from_rank_neighbors (const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_idx[], const cs_lnum_t elt_id[], const int16_t elt_tr_id[], const fvm_periodicity_t *periodicity)
 Create a halo structure from distant element distant ranks and ids. More...
cs_halo_t * cs_halo_create_from_rank_neighbors (const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_idx[], const cs_lnum_t elt_id[])
void cs_halo_destroy (cs_halo_t **halo)
cs_halo_state_t * cs_halo_state_create (void)
 Create a halo state structure. More...
void cs_halo_state_destroy (cs_halo_state_t **halo_state)
 Destroy a halo state structure. More...
cs_halo_state_t * cs_halo_state_get_default (void)
 Get pointer to default halo state structure. More...
size_t cs_halo_pack_size (const cs_halo_t *halo, cs_datatype_t data_type, int stride)
 Compute required size for packing send data into dense buffer. More...
void cs_halo_renumber_cells (cs_halo_t *halo, const cs_lnum_t new_cell_id[])
void cs_halo_renumber_ghost_cells (cs_halo_t *halo, const cs_lnum_t old_cell_id[])
void * cs_halo_sync_pack_init_state (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *send_buf, cs_halo_state_t *hs)
 Initialize halo state prior to packing halo data to send. More...
void cs_halo_sync_pack (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val, void *send_buf, cs_halo_state_t *hs)
 Pack halo data to send into dense buffer. More...
void cs_halo_sync_start (const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
 Launch update array of values in case of parallelism or periodicity. More...
void cs_halo_sync_wait (const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
 Wait for completion of update array of values in case of parallelism or periodicity. More...
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val)
 Update array of values in case of parallelism or periodicity. More...
void cs_halo_sync_untyped (const cs_halo_t *halo, cs_halo_type_t sync_mode, size_t size, void *val)
void cs_halo_sync_num (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_lnum_t num[])
void cs_halo_sync_var (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
void cs_halo_sync_var_strided (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[], int stride)
bool cs_halo_get_use_barrier (void)
void cs_halo_set_use_barrier (bool use_barrier)
cs_halo_comm_mode_t cs_halo_get_comm_mode (void)
 Get default communication mode for halo exchange. More...
void cs_halo_set_comm_mode (cs_halo_comm_mode_t mode)
 Set default communication mode for halo exchange. More...
cs_alloc_mode_t cs_halo_get_buffer_alloc_mode (void)
 Get default host/device allocation mode for message packing arrays. More...
void cs_halo_set_buffer_alloc_mode (cs_alloc_mode_t mode)
 Set default host/device allocation mode for message packing arrays. More...
void * cs_halo_get_default_buffer (size_t size)
 Return pointer to working send buffer used by default halo state. More...
void cs_halo_dump (const cs_halo_t *halo, int print_level)
template<typename T >
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[])
template<int Stride, typename T >
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][Stride])
void cs_halo_sync (const cs_halo_t *halo, bool on_device, T val[])
void cs_halo_sync (const cs_halo_t *halo, bool on_device, T val[][Stride])
template<typename T , int N>
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_mdspan_r< T, N > span)
 Update ghost cell values of an mdspan with layout right data storage. Only callable for mdspan with N = 1 or N = 2. More...
void cs_halo_sync (const cs_halo_t *halo, bool on_device, cs_mdspan_r< T, N > &span)
 Update ghost cell values of an mdspan with layout right data storage, and using the standard halo mode Only callable for mdspan with N = 1 or N = 2. More...
void cs_halo_sync (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_mdspan_r< T, N > &span)
 Update ghost cell values of an mdspan with layout right data storage, will try to run on accelerated device if data pointer is recognized as a device pointer. Only callable for mdspan with N = 1 or N = 2. More...
void cs_halo_sync (const cs_halo_t *halo, cs_mdspan_r< T, N > &span)
 Update ghost cell values of an mdspan with layout right data storage, using the standard synchronization mode and will try to run on accelerated device if data pointer is recognized as a device pointer. Only callable for mdspan with N = 1 or N = 2. More...
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][3])
 Update ghost cell values of a spatial vector field, including rotational periodicity if present. More...
void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, T val[][3])
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][6])
 Update ghost cell values of a symmetric tensor field, including rotational periodicity if present. More...
void cs_halo_sync_r (const cs_halo_t *halo, bool on_device, T val[][6])
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, T val[][3][3])
 Update ghost cell values of a non-symmetric tensor field, including rotational periodicity if present. More...
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, bool on_device, cs_mdspan_r< T, N > span)
 Update ghost cell values of an mdspan with layout right data storage, including rotational periodicity if present. More...
void cs_halo_sync_r (const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_mdspan_r< T, N > span)
 Update ghost cell values of an mdspan with layout right data storage, including rotational periodicity if present. Will try to run on accelerated device if data pointer is recognized as a device pointer. More...
Typedef Documentation
◆ cs_halo_state_t
Structure to maintain halo exchange state
◆ cs_halo_comm_mode_t
Enumerator
CS_HALO_COMM_P2P
non-blocking point-to-point communication
MPI-3 one-sided with get semantics and active target synchronization
◆ cs_halo_type_t
‍Halo type
Enumerator
CS_HALO_STANDARD
standard halo
CS_HALO_EXTENDED
extended halo (vertex-adjacent cells)
CS_HALO_N_TYPES
◆ cs_halo_create()
cs_halo_t * cs_halo_create ( const cs_interface_set_t *  ifs)
[in]ifspointer to a cs_interface_set structure
pointer to created cs_halo_t structure
◆ cs_halo_create_complete()
void cs_halo_create_complete ( cs_halo_t *  halo)
Ready halo for use.
This function should be called after building a halo using the cs_halo_create_function and defined locally. It is called automatically by cs_halo_create_from_ref and cs_halo_create_from_rank_neighbors so does not need to be called again using these functions.
[in]halopointer to halo structure
◆ cs_halo_create_from_rank_neighbors() [1/2]
cs_halo_t * cs_halo_create_from_rank_neighbors ( const cs_rank_neighbors_t *  rn,
[in]rnassociated rank neighbors info
[in]n_local_eltsnumber of elements for local rank
[in]n_distant_eltsnumber of distant elements for local rank
[in]elt_rank_idxdistant element rank index in rank neighbors, ordered by rank (size: n_distant_elts)
[in]elt_tr_iddistant element transform id, or null (-1 for non-periodic elements)
[in]elt_iddistant element id (at distant rank), ordered by rank (size: n_distant_elts)
◆ cs_halo_create_from_rank_neighbors() [2/2]
const fvm_periodicity_t *  periodicity
[in]elt_tr_iddistant element transform id (-1 for non-periodic elements), null if non-periodic
[in]periodicityoptional periodicity, or null
◆ cs_halo_create_from_ref()
cs_halo_t * cs_halo_create_from_ref ( const cs_halo_t *  ref)
[in]refpointer to reference halo
◆ cs_halo_destroy()
void cs_halo_destroy ( cs_halo_t **  halo)
brief Destroy a halo structure.
[in,out]halopointer to pointer to cs_halo structure to destroy.
◆ cs_halo_dump()
void cs_halo_dump ( const cs_halo_t *  halo,
int  print_level
◆ cs_halo_get_buffer_alloc_mode()
cs_alloc_mode_t cs_halo_get_buffer_alloc_mode ( void  )
allocation mode
◆ cs_halo_get_comm_mode()
cs_halo_comm_mode_t cs_halo_get_comm_mode ( void  )
allocation mode
◆ cs_halo_get_default_buffer()
void * cs_halo_get_default_buffer ( size_t  size)
This allows sharing the allocation with other operations which might be used frequently, such as range set scatters (which play a similar role to halos for data which can be on process boundaries, such as vertex or face-based data).
If the current buffer's size is smaller than the requested size, it is increased.
Warning
The returned buffer should not be used while a halo exchange using the default halo state is in progress.
] halo pointer to pointer to cs_halo structure to destroy.
◆ cs_halo_get_use_barrier()
bool cs_halo_get_use_barrier ( void  )
◆ cs_halo_pack_size()
size_t cs_halo_pack_size ( const cs_halo_t *  halo,
int  stride
inline
[in]data_typedata type
[in]stridenumber of (interlaced) values by entity
required size, in bytes
◆ cs_halo_renumber_cells()
void cs_halo_renumber_cells ( cs_halo_t *  halo,
◆ cs_halo_renumber_ghost_cells()
void cs_halo_renumber_ghost_cells ( cs_halo_t *  halo,
◆ cs_halo_set_buffer_alloc_mode()
void cs_halo_set_buffer_alloc_mode ( cs_alloc_mode_t  mode)
[in]modeallocation mode to set
◆ cs_halo_set_comm_mode()
void cs_halo_set_comm_mode ( cs_halo_comm_mode_t  mode)
◆ cs_halo_set_use_barrier()
void cs_halo_set_use_barrier ( bool  use_barrier)
◆ cs_halo_state_create()
cs_halo_state_t * cs_halo_state_create ( void  )
pointer to created cs_halo_state_t structure.
◆ cs_halo_state_destroy()
void cs_halo_state_destroy ( cs_halo_state_t **  halo_state)
[in,out]halo_statepointer to pointer to cs_halo_state structure to destroy.
◆ cs_halo_state_get_default()
cs_halo_state_t * cs_halo_state_get_default ( void  )
◆ cs_halo_sync() [1/9]
void cs_halo_sync ( const cs_halo_t *  halo,
bool  on_device,
cs_mdspan_r< T, N > &  span
Template Parameters
in] T value type
Template Parameters
in] N stride size
[in]on_devicerun on accelerated device if possible
[in,out]spanreference to mdspan_r
◆ cs_halo_sync() [2/9]
bool  on_device,
T  val[]
◆ cs_halo_sync() [3/9]
bool  on_device,
T  val[][Stride]
◆ cs_halo_sync() [4/9]
bool  on_device,
Template Parameters
in] T value type
Template Parameters
in] N stride size
[in]sync_modesynchronization mode (std or ext)
◆ cs_halo_sync() [5/9]
bool  on_device,
T  val[]
This function aims at copying main values from local elements (id between 1 and n_local_elements) to ghost elements on distant ranks (id between n_local_elements + 1 to n_local_elements_with_halo).
Template Parameters
in] T value type
[in]sync_modesynchronization mode (standard or extended)
[in,out]valpointer to variable value array
◆ cs_halo_sync() [6/9]
bool  on_device,
T  val[][Stride]
◆ cs_halo_sync() [7/9]
int  stride,
void *  val
[in]valpointer to variable value array
◆ cs_halo_sync() [8/9]
Template Parameters
in] T value type
Template Parameters
in] N stride size
◆ cs_halo_sync() [9/9]
Template Parameters
in] T value type
Template Parameters
in] N stride size
◆ cs_halo_sync_num()
void cs_halo_sync_num ( const cs_halo_t *  halo,
cs_lnum_t  num[]
◆ cs_halo_sync_pack()
void cs_halo_sync_pack ( const cs_halo_t *  halo,
int  stride,
void *  val,
void *  send_buf,
cs_halo_state_t *  hs
A local state handler may be provided, or the default state handler will be used.
A local state and/or buffer may be provided, or the default (global) state and buffer will be used. If provided explicitely, the buffer must be of sufficient size.
[out]send_bufpointer to send buffer, null for global buffer
[in,out]hspointer to halo state, null for global state
◆ cs_halo_sync_pack_init_state()
void * cs_halo_sync_pack_init_state ( const cs_halo_t *  halo,
int  stride,
void *  send_buf,
This function is included in cs_halo_sync_pack, but may be called separately for specific implementations, such as for accelerator devices.
pointer to halo send buffer
◆ cs_halo_sync_r() [1/7]
void cs_halo_sync_r ( const cs_halo_t *  halo,
bool  on_device,
T  val[][3]
◆ cs_halo_sync_r() [2/7]
bool  on_device,
T  val[][6]
◆ cs_halo_sync_r() [3/7]
bool  on_device,
Template Parameters
in] T value type
Template Parameters
in] N stride size
◆ cs_halo_sync_r() [4/7]
bool  on_device,
T  val[][3]
Template Parameters
in] T value type
◆ cs_halo_sync_r() [5/7]
bool  on_device,
T  val[][3][3]
Template Parameters
in] T value type
◆ cs_halo_sync_r() [6/7]
bool  on_device,
T  val[][6]
Template Parameters
in] T value type
◆ cs_halo_sync_r() [7/7]
Template Parameters
in] T value type
Template Parameters
in] N stride size
◆ cs_halo_sync_start()
void cs_halo_sync_start ( const cs_halo_t *  halo,
void *  val,
The cs_halo_sync_pack function should have been called before this function, using the same hs argument.
◆ cs_halo_sync_untyped()
void cs_halo_sync_untyped ( const cs_halo_t *  halo,
size_t  size,
void *  val
◆ cs_halo_sync_var()
void cs_halo_sync_var ( const cs_halo_t *  halo,
cs_real_t  var[]
◆ cs_halo_sync_var_strided()
void cs_halo_sync_var_strided ( const cs_halo_t *  halo,
cs_real_t  var[],
int  stride
◆ cs_halo_sync_wait()
void cs_halo_sync_wait ( const cs_halo_t *  halo,
void *  val,
The cs_halo_sync_start function should have been called before this function, using the same hs argument.
