43#define CS_IO_NAME_LEN 32
45#define CS_IO_ECHO_NONE -2
46#define CS_IO_ECHO_OPEN_CLOSE -1
47#define CS_IO_ECHO_HEADERS 0
125 const char *magic_string,
137 const char *magic_string,
169 const char *magic_string,
179 const char *magic_string,
211 const char *magic_string,
221 const char *magic_string,
523 size_t n_location_vals,
568 size_t n_location_vals,
615 size_t n_location_vals,
cs_datatype_t
Definition: cs_defs.h:290
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
#define MPI_Info
Definition: cs_defs.h:86
long cs_file_off_t
Definition: cs_file.h:123
cs_file_access_t
Definition: cs_file.h:83
cs_io_t * cs_io_initialize_with_index(const char *file_name, const char *magic_string, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.cpp:2024
void cs_io_log_finalize(void)
Definition: cs_io.cpp:3397
const char * cs_io_get_name(const cs_io_t *pp_io)
Definition: cs_io.cpp:2209
cs_io_mode_t
Definition: cs_io.h:55
@ CS_IO_MODE_READ
Definition: cs_io.h:57
@ CS_IO_MODE_WRITE
Definition: cs_io.h:58
size_t cs_io_get_echo(const cs_io_t *pp_io)
Definition: cs_io.cpp:2319
void cs_io_set_int(cs_io_sec_header_t *header, const cs_io_t *cs_io)
Definition: cs_io.cpp:2640
const char * cs_io_get_indexed_sec_name(const cs_io_t *inp, size_t id)
Definition: cs_io.cpp:2249
size_t cs_io_get_index_size(const cs_io_t *inp)
Definition: cs_io.cpp:2227
void cs_io_write_global(const char *sec_name, cs_gnum_t n_vals, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.cpp:3027
void cs_io_log_initialize(void)
Definition: cs_io.cpp:3380
void cs_io_get_data_in_mem(const cs_io_t *pp_io, size_t *nb, void **data)
Definition: cs_io.cpp:2337
void cs_io_finalize(cs_io_t **pp_io)
Definition: cs_io.cpp:2171
int cs_io_read_header(cs_io_t *inp, cs_io_sec_header_t *header)
Definition: cs_io.cpp:2365
void cs_io_write_block(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, const void *elts, cs_io_t *outp)
Definition: cs_io.cpp:3118
void cs_io_assert_cs_real(const cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.cpp:2749
void * cs_io_read_block(const cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, void *elts, cs_io_t *pp_io)
Definition: cs_io.cpp:2818
void cs_io_set_cs_lnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.cpp:2677
cs_io_sec_header_t cs_io_get_indexed_sec_header(const cs_io_t *inp, size_t id)
Definition: cs_io.cpp:2276
void cs_io_write_block_buffer(const char *sec_name, cs_gnum_t n_g_elts, cs_gnum_t global_num_start, cs_gnum_t global_num_end, size_t location_id, size_t index_id, size_t n_location_vals, cs_datatype_t elt_type, void *elts, cs_io_t *outp)
Definition: cs_io.cpp:3219
void cs_io_set_cs_gnum(cs_io_sec_header_t *header, const cs_io_t *pp_io)
Definition: cs_io.cpp:2714
cs_io_t * cs_io_initialize(const char *file_name, const char *magic_string, cs_io_mode_t mode, cs_file_access_t method, long echo, MPI_Info hints, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.cpp:1961
int cs_io_set_indexed_position(cs_io_t *inp, cs_io_sec_header_t *header, size_t id)
Definition: cs_io.cpp:2576
cs_file_off_t cs_io_get_offset(cs_io_t *inp)
Definition: cs_io.cpp:3347
void cs_io_set_offset(cs_io_t *inp, cs_file_off_t offset)
Definition: cs_io.cpp:3364
void * cs_io_read_index_block(cs_io_sec_header_t *header, cs_gnum_t global_num_start, cs_gnum_t global_num_end, cs_gnum_t *elts, cs_io_t *pp_io)
Definition: cs_io.cpp:2867
void * cs_io_read_global(const cs_io_sec_header_t *header, void *elts, cs_io_t *pp_io)
Definition: cs_io.cpp:2784
void cs_io_dump(const cs_io_t *cs_io)
Definition: cs_io.cpp:3503
struct _cs_io_t cs_io_t
Definition: cs_io.h:64
void cs_io_skip(const cs_io_sec_header_t *header, cs_io_t *pp_io)
Definition: cs_io.cpp:3293
cs_io_t * cs_io_initialize_with_index_from_mem(const char *file_name, const char *magic_string, cs_file_access_t method, long echo, size_t nb, void *data, MPI_Comm block_comm, MPI_Comm comm)
Definition: cs_io.cpp:2112
