cs_array_hip.h File Reference
#include "hip/hip_runtime.h"
#include "base/cs_base_hip.h"
+ Include dependency graph for cs_array_hip.h:
template<typename T , size_t stride>
__global__ void hip_kernel_set_value (cs_lnum_t n, const T ref_val, const int size_arrs, T **array_ptrs)
__global__ void hip_kernel_set_value (cs_lnum_t n, const T *ref_val, const int size_arrs, T **array_ptrs)
__global__ void hip_kernel_set_value (cs_lnum_t n, const T ref_val, T *array)
__global__ void hip_kernel_set_value (cs_lnum_t n, const T *ref_val, T *array)
__global__ void cs_hip_kernel_set_zero (cs_lnum_t n, T *array)
template<typename T , size_t stride, typename... Arrays>
void cs_arrays_set_value (hipStream_t stream, bool async, cs_lnum_t n_elts, T *ref_val, Arrays &&... arrays)
 Assign values to all elements of multiple arrays. ref_val is input as a pointer or an array. More...
void cs_arrays_set_value (hipStream_t stream, bool async, cs_lnum_t n_elts, T ref_val, Arrays &&... arrays)
 Assign values to all elements of multiple arrays. ref_val is input as a scalar value. More...
void cs_arrays_set_zero (hipStream_t stream, bool async, cs_lnum_t n_elts, Arrays &&... arrays)
template<typename T >
void cs_array_copy (hipStream_t stream, bool async, const cs_lnum_t size, const T *src, T *dest)
 Copy values from an array to another of the same dimensions. More...
◆ cs_array_copy()
void cs_array_copy ( hipStream_t  stream,
bool  async,
const T *  src,
T *  dest
Template parmeters. T type name
[in]streamhip stream used for the operation
[in]sizenumber of elements * dimension
[in]asyncuse asynchronous mode (no sync)
[in]srcsource array values
[out]destdestination array values
◆ cs_arrays_set_value() [1/2]
void cs_arrays_set_value ( hipStream_t  stream,
bool  async,
cs_lnum_t  n_elts,
T *  ref_val,
Arrays &&...  arrays
Template parmeters. T type name stride 1 for scalars, 3 for vectors, 6 for symetric tensors Arrays varadiac parameters pack
Function parameters:
[in]n_eltstotal number of elements to set
[in]ref_valvalue to assign
[out]arraysarrays to set
◆ cs_arrays_set_value() [2/2]
bool  async,
cs_lnum_t  n_elts,
T  ref_val,
Arrays &&...  arrays
◆ cs_arrays_set_zero()
void cs_arrays_set_zero ( hipStream_t  stream,
bool  async,
cs_lnum_t  n_elts,
Arrays &&...  arrays
◆ cs_hip_kernel_set_zero()
__global__ void cs_hip_kernel_set_zero ( cs_lnum_t  n,
T *  array
◆ hip_kernel_set_value() [1/4]
__global__ void hip_kernel_set_value ( cs_lnum_t  n,
const T *  ref_val,
T **  array_ptrs
◆ hip_kernel_set_value() [2/4]
const T *  ref_val,
T *  array
◆ hip_kernel_set_value() [3/4]
const T  ref_val,
T **  array_ptrs
◆ hip_kernel_set_value() [4/4]
const T  ref_val,
T *  array
