cs_boundary_conditions_set_coeffs.cpp File Reference
Translation of the boundary conditions given by the user in a form that fits the solver. More...
#include <stdarg.h>
#include <mpi.h>
#include "bft/bft_printf.h"
#include "base/cs_1d_wall_thermal.h"
#include "base/cs_ale.h"
#include "base/cs_array.h"
#include "base/cs_assert.h"
#include "base/cs_base.h"
#include "base/cs_boundary.h"
#include "base/cs_boundary_conditions_check.h"
#include "base/cs_boundary_conditions_coupling.h"
#include "base/cs_boundary_conditions_set_coeffs_symmetry.h"
#include "base/cs_boundary_conditions_set_coeffs_turb.h"
#include "base/cs_boundary_conditions_type.h"
#include "cfbl/cs_cf_boundary_conditions.h"
#include "base/cs_coupling.h"
#include "base/cs_dispatch.h"
#include "base/cs_field.h"
#include "alge/cs_gradient_boundary.h"
#include "gui/cs_gui_boundary_conditions.h"
#include "gui/cs_gui_mobile_mesh.h"
#include "gui/cs_gui_util.h"
#include "base/cs_ht_convert.h"
#include "base/cs_internal_coupling.h"
#include "turb/cs_les_inflow.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_mobile_structures.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "rayt/cs_rad_transfer.h"
#include "rayt/cs_rad_transfer_bcs.h"
#include "base/cs_sat_coupling.h"
#include "base/cs_syr_coupling.h"
#include "base/cs_turbomachinery.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_vof.h"
#include "base/cs_wall_condensation.h"
#include "base/cs_wall_condensation_1d_thermal.h"
#include "base/cs_rotation.h"
#include "atmo/cs_atmo.h"
#include "ctwr/cs_ctwr_boundary_conditions.h"
#include "cogz/cs_combustion_boundary_conditions.h"
#include "comb/cs_coal_boundary_conditions.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
Macros
#define NOZPPM   2000 /* max number of boundary conditions zone */
template<bool need_flux_reconstruction>
static void _compute_bc_flux_grad (cs_dispatch_context &ctx, const int hyd_p_flag, const cs_real_t f_ext[][3], const cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_real_t val_ip_g[], const cs_real_t val_ip_d[], cs_real_t val_f[], cs_real_t flux[])
static void _compute_bc_grad (cs_dispatch_context &ctx, const int hyd_p_flag, const cs_real_t f_ext[][3], const cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_real_t val_ip_g[], cs_real_t val_f[])
static void _compute_bc_diff_flux (cs_dispatch_context &ctx, const cs_field_bc_coeffs_t *bc_coeffs, const int inc, const bool need_flux_reconstruction, const cs_real_t val_ip_d[], cs_real_t flux[])
void cs_boundary_conditions_set_coeffs (int nvar, int iterns, int isvhb, int italim, int itrfin, int ineefl, int itrfup, int isostd[], cs_real_t *visvdr, cs_real_t hbord[], cs_real_t theipb[], int nftcdt)
 Translation of the boundary conditions given by the user in a form that fits to the solver. More...
void cs_boundary_conditions_set_coeffs_init (void)
 Initialization of boundary condition arrays. More...
void cs_boundary_conditions_set_coeffs_pressure (cs_dispatch_context &ctx, cs_field_t *f_p)
 Update pressure boundary condition coefficients. More...
CS_F_HOST_DEVICE void cs_boundary_conditions_set_convective_outlet_scalar (cs_real_t &a, cs_real_t &af, cs_real_t &b, cs_real_t &bf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint)
 Set convective oulet boundary condition for a scalar. More...
CS_F_HOST_DEVICE void cs_boundary_conditions_set_generalized_sym_vector_aniso (cs_real_t a[3], cs_real_t af[3], cs_real_t b[3][3], cs_real_t bf[3][3], const cs_real_t pimpv[3], const cs_real_t qimpv[3], const cs_real_t hint[6], const cs_nreal_t normal[3])
 Set generalized BC for an anisotropic symmetric vector for a given face. More...
CS_F_HOST_DEVICE void cs_boundary_conditions_set_generalized_dirichlet_vector_aniso (cs_real_t a[3], cs_real_t af[3], cs_real_t b[3][3], cs_real_t bf[3][3], const cs_real_t pimpv[3], const cs_real_t qimpv[3], const cs_real_t hint[6], const cs_nreal_t normal[3])
 Set generalized Dirichlet BC for an anisotropic vector for a given face. More...
void cs_boundary_conditions_update_bc_coeff_face_values (cs_dispatch_context &ctx, const cs_field_t *f, cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_equation_param_t *eqp, const bool need_compute_bc_grad, const bool need_compute_bc_flux, int hyd_p_flag, cs_real_t f_ext[][3], cs_real_t *c_weight, const cs_real_t weighb[], const cs_real_t pvar[])
 Update face value for gradient and diffusion when solving in increment. More...
void cs_boundary_conditions_update_bc_coeff_face_values (cs_dispatch_context &ctx, cs_field_t *f, const cs_equation_param_t *eqp, const bool need_compute_bc_grad, const bool need_compute_bc_flux, int hyd_p_flag, cs_real_t f_ext[][3], cs_real_t *c_weight, const cs_real_t weighb[], const cs_real_t pvar[])
 Update boundary coefficient face values for gradient and diffusion when solving for a given field. More...
template<cs_lnum_t stride>
void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_equation_param_t *eqp, const cs_real_t pvar[][stride])
 Update face value for gradient and diffusion when solving in increments. More...
void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, const cs_real_t pvar[][stride])
template void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_equation_param_t *eqp, const cs_real_t pvar[][3])
template void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, cs_field_bc_coeffs_t *bc_coeffs, const int inc, const cs_equation_param_t *eqp, const cs_real_t pvar[][6])
template void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, const cs_real_t pvar[][3])
template void cs_boundary_conditions_update_bc_coeff_face_values_strided (cs_dispatch_context &ctx, cs_field_t *f, const cs_real_t pvar[][6])
void cs_boundary_conditions_ensure_bc_coeff_face_values_allocated (cs_field_bc_coeffs_t *bc_coeffs, cs_lnum_t n_b_faces, cs_lnum_t dim, cs_alloc_mode_t amode)
 Allocate BC coefficients face values if needed. More...
Boundary condition coefficients computation.
◆ NOZPPM
◆ _compute_bc_diff_flux()
static void _compute_bc_diff_flux ( cs_dispatch_context &  ctx,
const cs_field_bc_coeffs_t *  bc_coeffs,
const int  inc,
cs_real_t  flux[]
static
◆ _compute_bc_flux_grad()
static void _compute_bc_flux_grad ( cs_dispatch_context &  ctx,
const int  inc,
cs_real_t  val_f[],
cs_real_t  flux[]
static
◆ _compute_bc_grad()
static void _compute_bc_grad ( cs_dispatch_context &  ctx,
const int  inc,
cs_real_t  val_f[]
static
◆ cs_boundary_conditions_ensure_bc_coeff_face_values_allocated()
void cs_boundary_conditions_ensure_bc_coeff_face_values_allocated ( cs_field_bc_coeffs_t *  bc_coeffs,
cs_lnum_t  dim,
[in,out]bc_coeffspointer to boundary conditions coefficients.
[in]n_b_facesnumber of boundary faces
[in]dimassociated field dimension
[in]amodeallocation mode
◆ cs_boundary_conditions_set_coeffs()
void cs_boundary_conditions_set_coeffs ( int  nvar,
int  iterns,
int  isvhb,
int  italim,
int  itrfin,
int  ineefl,
int  itrfup,
int  isostd[],
cs_real_t *  visvdr,
cs_real_t  hbord[],
cs_real_t  theipb[],
int  nftcdt
The values at a boundary face $ \fib $ stored in the face center $ \centf $ of the variable $ P $ and its diffusive flux $ Q $ are written as:
P_{\face} = A_P^g + B_P^g P_{\centi}
and
Q_{\face} = A_P^f + B_P^f P_{\centi}
where $ P_\centi $ is the value of the variable $ P $ at the neighboring cell.
Warning
  • If we consider an increment of a variable, the boundary conditions read:
  \delta P_{\face} = B_P^g \delta P_{\centi}
    and
  \delta Q_{\face} = -B_P^f \delta P_{\centi}
  • For a vector field such as the velocity $ \vect{u} $ the boundary conditions may read:
  \vect{u}_{\face} = \vect{A}_u^g + \tens{B}_u^g \vect{u}_{\centi}
    and
  \vect{Q}_{\face} = \vect{A}_u^f + \tens{B}_u^f \vect{u}_{\centi}
    where $ \tens{B}_u^g $ and $ \tens{B}_u^f $ are 3x3 tensor matrix which coupled velocity components next to a boundary.
Please refer to the boundary conditions section of the theory guide for more informations, as well as the condli section.
[in]nvartotal number of variables
[in]iternsiteration number on Navier-Stokes equations
[in]isvhbid of field whose exchange coeffient should be saved at the walls, or -1.
[in]italimfor ALE
[in]itrfinLast velocity-pressure sub-iteration indicator
[in]ineeflfor ALE
[in]itrfupUpdate after velocity-pressure sub-iterations
[in,out]isostdindicator for standard outlet
[in]dttime step (per cell)
[in,out]visvdrdynamic viscosity after V. Driest damping in boundary cells
[out]hbordexchange coefficient at boundary
[out]theipbvalue of thermal scalar at $ \centip $ f boundary cells
[in]nftcdtGlobal indicator of condensation source terms (ie. sum on the processors of nfbpcd) cells associated to the face with condensation phenomenon
◆ cs_boundary_conditions_set_coeffs_init()
void cs_boundary_conditions_set_coeffs_init ( void  )
◆ cs_boundary_conditions_set_coeffs_pressure()
void cs_boundary_conditions_set_coeffs_pressure ( cs_dispatch_context &  ctx,
cs_field_t *  f_p
[in]ctxassociated dispatch context
[in]f_ppointer to field
◆ cs_boundary_conditions_set_convective_outlet_scalar()
CS_F_HOST_DEVICE void cs_boundary_conditions_set_convective_outlet_scalar ( cs_real_t &  a,
cs_real_t &  af,
cs_real_t &  b,
cs_real_t &  bf,
cs_real_t  pimp,
cs_real_t  cfl,
cs_real_t  hint
[out]aexplicit BC coefficient for gradients
[out]afexplicit BC coefficient for diffusive flux
[out]bimplicit BC coefficient for gradients
[out]bfimplicit BC coefficient for diffusive flux
[in]pimpflux value to impose
[in]cfllocal Courant number used to convect
[in]hintinternal exchange coefficient
◆ cs_boundary_conditions_set_generalized_dirichlet_vector_aniso()
CS_F_HOST_DEVICE void cs_boundary_conditions_set_generalized_dirichlet_vector_aniso ( cs_real_t  a[3],
cs_real_t  af[3],
cs_real_t  b[3][3],
cs_real_t  bf[3][3],
[in]pimpvDirichlet value to impose on the tangential components
[in]qimpvflux value to impose on the normal component
[in]normalunit normal
◆ cs_boundary_conditions_set_generalized_sym_vector_aniso()
CS_F_HOST_DEVICE void cs_boundary_conditions_set_generalized_sym_vector_aniso ( cs_real_t  a[3],
cs_real_t  af[3],
cs_real_t  b[3][3],
cs_real_t  bf[3][3],
[in]pimpvDirichlet value to impose on the normal component
[in]qimpvflux value to impose on the tangential components
◆ cs_boundary_conditions_update_bc_coeff_face_values() [1/2]
void cs_boundary_conditions_update_bc_coeff_face_values ( cs_dispatch_context &  ctx,
const cs_field_t *  f,
const int  inc,
int  hyd_p_flag,
cs_real_t *  c_weight,
[in]ctxreference to dispatch context
[in]fpointer to field
[in,out]bc_coeffsboundary condition structure
[in]inc0 if an increment, 1 otherwise
[in]eqpequation parameters
[in]need_compute_bc_gradval_f must be computed
[in]need_compute_bc_fluxflux must be computed
[in]hyd_p_flaghydrostatic pressure indicator
[in]f_extexterior force generating pressure
[in]c_weightviscosity by cell, or nullptr
[in]weighbboundary face weight for cells i in case of tensor diffusion, or nullptr
[in]varvariable values at cell centers
◆ cs_boundary_conditions_update_bc_coeff_face_values() [2/2]
cs_field_t *  f,
int  hyd_p_flag,
[in,out]fpointer to field
[in]hyd_p_flagflag for hydrostatic pressure
[in]c_weightanisotrop or symmetric cell tensor $ \tens{\mu}_\celli $, or nullptr
[in]pvarvariable values at cell centers
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [1/6]
template void cs_boundary_conditions_update_bc_coeff_face_values_strided ( cs_dispatch_context &  ctx,
cs_field_t *  f,
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [2/6]
cs_field_t *  f,
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [3/6]
cs_field_t *  f,
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [4/6]
cs_field_t *  f,
const int  inc,
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [5/6]
cs_field_t *  f,
const int  inc,
◆ cs_boundary_conditions_update_bc_coeff_face_values_strided() [6/6]
cs_field_t *  f,
const int  inc,
[in,out]bc_coeffsboundary condition structure for the variable
