1#ifndef CS_PHYSICAL_CONSTANTS_H
2#define CS_PHYSICAL_CONSTANTS_H
121#if (defined(__NVCC__) && defined(__CUDA_ARCH__)) \
122 || (defined(__HIPCC__) && defined(__HIP_DEVICE_COMPILE__)) \
123 || defined(SYCL_LANGUAGE_VERSION) \
124 || defined(HAVE_OPENMP_TARGET)
128#define cs_physical_constants_r 8.31446261815324
129#define cs_physical_constants_kb 1.380649e-23
130#define cs_physical_constants_celsius_to_kelvin 273.15
131#define cs_physical_constants_stephan 5.6703e-8
132#define cs_physical_constants_avogadro 6.02214076e23
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
const double cs_physical_constants_stephan
Definition: cs_physical_constants.cpp:451
void cs_physical_constants_log_setup(void)
Definition: cs_physical_constants.cpp:568
const double cs_physical_constants_r
Definition: cs_physical_constants.cpp:438
const double cs_physical_constants_kb
Definition: cs_physical_constants.cpp:442
const double cs_physical_constants_celsius_to_kelvin
Definition: cs_physical_constants.cpp:446
const double cs_physical_constants_avogadro
Definition: cs_physical_constants.cpp:455
Definition: cs_physical_constants.cpp:462
const cs_physical_constants_t * cs_glob_physical_constants
Definition: cs_physical_constants.cpp:459
void cs_fluid_properties_log_setup(void)
Definition: cs_physical_constants.cpp:599
cs_physical_constants_t * cs_get_glob_physical_constants(void)
Definition: cs_physical_constants.cpp:543
cs_fluid_properties_t * cs_get_glob_fluid_properties(void)
Definition: cs_physical_constants.cpp:556
Fluid properties descriptor.
int ivivar
Definition: cs_physical_constants.h:71
double kleak
Definition: cs_physical_constants.h:110
double viscl0
Definition: cs_physical_constants.h:75
int icp
Definition: cs_physical_constants.h:65
double pthermax
Definition: cs_physical_constants.h:105
double sleak
Definition: cs_physical_constants.h:109
double l00
Definition: cs_physical_constants.h:90
int p0_face_id
Definition: cs_physical_constants.h:82
double eint0
Definition: cs_physical_constants.h:107
double ro0
Definition: cs_physical_constants.h:74
double cv0
Definition: cs_physical_constants.h:86
double pthera
Definition: cs_physical_constants.h:103
int iviscv
Definition: cs_physical_constants.h:68
double viscv0
Definition: cs_physical_constants.h:76
double cpv0
Definition: cs_physical_constants.h:87
double r_pg_cnst
Definition: cs_physical_constants.h:93
double xmasmr
Definition: cs_physical_constants.h:97
double cvl
Definition: cs_physical_constants.h:89
double rvsra
Definition: cs_physical_constants.h:95
int irovar
Definition: cs_physical_constants.h:70
double pred0
Definition: cs_physical_constants.h:79
int ipthrm
Definition: cs_physical_constants.h:99
int ixyzp0
Definition: cs_physical_constants.h:63
int icv
Definition: cs_physical_constants.h:66
double pther
Definition: cs_physical_constants.h:101
double clatev
Definition: cs_physical_constants.h:96
double t0
Definition: cs_physical_constants.h:84
double r_v_cnst
Definition: cs_physical_constants.h:94
double cp0
Definition: cs_physical_constants.h:85
double lambda0
Definition: cs_physical_constants.h:91
double roref
Definition: cs_physical_constants.h:111
double p0
Definition: cs_physical_constants.h:78
int p0_rank_id
Definition: cs_physical_constants.h:83
int ivsuth
Definition: cs_physical_constants.h:72
Physical constants descriptor.
Definition: cs_physical_constants.h:51
int icorio
Definition: cs_physical_constants.h:54
