cs_renumber.h File Reference
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_renumber.h:
Enumerations
enum  cs_renumber_cells_type_t {
  CS_RENUMBER_CELLS_SCOTCH_PART , CS_RENUMBER_CELLS_SCOTCH_ORDER , CS_RENUMBER_CELLS_METIS_PART , CS_RENUMBER_CELLS_METIS_ORDER ,
  CS_RENUMBER_CELLS_MORTON , CS_RENUMBER_CELLS_HILBERT , CS_RENUMBER_CELLS_RCM , CS_RENUMBER_CELLS_NONE
enum  cs_renumber_i_faces_type_t { CS_RENUMBER_I_FACES_BLOCK , CS_RENUMBER_I_FACES_MULTIPASS , CS_RENUMBER_I_FACES_SIMD , CS_RENUMBER_I_FACES_NONE }
enum  cs_renumber_b_faces_type_t { CS_RENUMBER_B_FACES_THREAD , CS_RENUMBER_B_FACES_SIMD , CS_RENUMBER_B_FACES_NONE }
enum  cs_renumber_vertices_type_t { CS_RENUMBER_VERTICES_BY_CELL_ADJ , CS_RENUMBER_VERTICES_BY_FACE_ADJ , CS_RENUMBER_VERTICES_NONE }
enum  cs_renumber_ordering_t { CS_RENUMBER_ADJACENT_LOW , CS_RENUMBER_ADJACENT_HIGH }
void cs_renumber_set_n_threads (int n_threads)
 Set the target number of threads for mesh renumbering. More...
int cs_renumber_get_n_threads (void)
 Return the target number of threads for mesh renumbering. More...
void cs_renumber_set_min_subset_size (cs_lnum_t min_i_subset_size, cs_lnum_t min_b_subset_size)
 Set the minimum sunset sizes when renumbering for threads. More...
void cs_renumber_get_min_subset_size (cs_lnum_t *min_i_subset_size, cs_lnum_t *min_b_subset_size)
 Get the minimum sunset sizes when renumbering for threads. More...
void cs_renumber_set_multipass_rebalance_factor (float relaxation_factor)
 Set the relaxtion factor for rebalancing with the multipass algorithm. More...
float cs_renumber_get_multipass_rebalance_factor (void)
 Get the relaxtion factor for rebalancing with the multipass algorithm. More...
void cs_renumber_set_algorithm (bool halo_adjacent_cells_last, bool halo_adjacent_faces_last, cs_renumber_ordering_t i_faces_base_ordering, cs_renumber_cells_type_t cells_pre_numbering, cs_renumber_cells_type_t cells_numbering, cs_renumber_i_faces_type_t i_faces_numbering, cs_renumber_b_faces_type_t b_faces_numbering, cs_renumber_vertices_type_t vertices_numbering)
 Select the algorithm for mesh renumbering. More...
void cs_renumber_get_algorithm (bool *halo_adjacent_cells_last, bool *halo_adjacent_faces_last, cs_renumber_ordering_t *i_faces_base_ordering, cs_renumber_cells_type_t *cells_pre_numbering, cs_renumber_cells_type_t *cells_numbering, cs_renumber_i_faces_type_t *i_faces_numbering, cs_renumber_b_faces_type_t *b_faces_numbering, cs_renumber_vertices_type_t *vertices_numbering)
 Return the algorithms for mesh renumbering. More...
void cs_renumber_mesh (cs_mesh_t *mesh, cs_lnum_t **cell_n2o, cs_lnum_t **i_face_n2o, cs_lnum_t **b_face_n2o, cs_lnum_t **vtx_n2o)
 Renumber mesh elements for vectorization or threading depending on code options and target machine. More...
void cs_renumber_cells (cs_mesh_t *mesh)
 Renumber cells depending on code options and target machine. More...
void cs_renumber_i_faces (cs_mesh_t *mesh)
 Renumber interior faces for vectorization or threading depending on code options and target machine. More...
void cs_renumber_i_faces_by_gnum (cs_mesh_t *mesh)
void cs_renumber_b_faces (cs_mesh_t *mesh)
 Renumber boundary faces for vectorization or threading depending on code options and target machine. More...
void cs_renumber_b_faces_by_gnum (cs_mesh_t *mesh)
void cs_renumber_b_faces_select_ignore (cs_mesh_t *mesh, cs_lnum_t n_faces, const cs_lnum_t face_ids[])
 Renumber boundary faces such that selected faces appear last and will be ignored. More...
void cs_renumber_vertices (cs_mesh_t *mesh)
 Renumber vertices depending on code options and target machine. More...
◆ cs_renumber_b_faces_type_t
Boundary faces renumbering algorithm types
Enumerator
Renumber for threads, with one block per thread, and no cell referenced by faces in different threads blocks.
Renumber to allow SIMD operations in boundary face->cell gather operations.
No boundary face numbering
◆ cs_renumber_cells_type_t
Cell renumbering algorithm types
Enumerator
Subpartition for thread blocks based SCOTCH library.
Fill-reducing ordering based on SCOTCH library.
Subpartition for thread blocks based METIS library.
Fill-reducing ordering based on METIS library.
Order cells using domain-local Morton space-filling curve.
Order cells using domain-local Hilbert space-filling curve.
Order cells using domain-local reverse Cuthill-McKee algorithm.
No cells renumbering
◆ cs_renumber_i_faces_type_t
Interior faces renumbering algorithm types
Enumerator
No shared cell in block This should produce blocks of similar (prescribed) size across thread groups.
Use multipass face numbering. This should produce a smaller number of blocks, with a diminishing number of faces per thread group.
Renumber to allow SIMD operations in interior face->cell gather operations (such as SpMV products with native matrix representation).
No interior face numbering
◆ cs_renumber_ordering_t
Ordering options for adjacency arrays
Enumerator
Lexicographical ordering with lowest adjacent id first
Lexicographical ordering with highest adjacent id first
◆ cs_renumber_vertices_type_t
Vertices renumbering algorithm types
Enumerator
Renumbering based on cell adjacency
Renumbering based on face adjacency
No vertex renumbering
◆ cs_renumber_b_faces()
void cs_renumber_b_faces ( cs_mesh_t *  mesh)
parameters: mesh <-> pointer to global mesh structure
[in,out]meshpointer to global mesh structure
◆ cs_renumber_b_faces_by_gnum()
void cs_renumber_b_faces_by_gnum ( cs_mesh_t *  mesh)
◆ cs_renumber_b_faces_select_ignore()
void cs_renumber_b_faces_select_ignore ( cs_mesh_t *  mesh,
cs_lnum_t  n_faces,
Those faces will appear last, and the local number of boundary faces set to the number of remaining faces; The mesh's n_b_faces_all and n_g_b_faces_all allows accessing the full boundary faces list.
[in]n_facesnumber of selected faces
[in]face_idsnumber of selected faces
◆ cs_renumber_cells()
void cs_renumber_cells ( cs_mesh_t *  mesh)
◆ cs_renumber_get_algorithm()
void cs_renumber_get_algorithm ( bool *  halo_adjacent_cells_last,
bool *  halo_adjacent_faces_last,
cs_renumber_ordering_t *  i_faces_base_ordering,
cs_renumber_cells_type_t *  cells_pre_numbering,
cs_renumber_cells_type_t *  cells_numbering,
cs_renumber_i_faces_type_t *  i_faces_numbering,
cs_renumber_b_faces_type_t *  b_faces_numbering,
cs_renumber_vertices_type_t *  vertices_numbering
Any argument may be passed nullptr if this option is not queried.
[out]halo_adjacent_cells_lastif true, cells adjacent to ghost cells will be placed last (after pre-numbering)
[out]halo_adjacent_faces_lastif true, interior faces adjacent to ghost cells will be placed last (after pre-numbering)
[out]i_faces_base_orderingpre-ordering of interior faces by lowest or highest adjacent cell id
[out]cells_pre_numberingalgorithm for cells pre-numbering
[out]cells_numberingalgorithm for cells numbering
[out]i_faces_numberingalgorithm for interior faces numbering
[out]b_faces_numberingalgorithm for boundary faces numbering
[out]vertices_numberingalgorithm for vertices numbering
◆ cs_renumber_get_min_subset_size()
void cs_renumber_get_min_subset_size ( cs_lnum_t *  min_i_subset_size,
cs_lnum_t *  min_b_subset_size
[out]min_i_subset_sizeminimum number of interior faces per thread per group, or nullptr
[out]min_b_subset_sizeminimum number of boundary faces per thread per group, or nullptr
◆ cs_renumber_get_multipass_rebalance_factor()
float cs_renumber_get_multipass_rebalance_factor ( void  )
relaxation factor for multipass renumbering rebalance step.
◆ cs_renumber_get_n_threads()
int cs_renumber_get_n_threads ( void  )
the target number of threads for mesh numbering
◆ cs_renumber_i_faces()
void cs_renumber_i_faces ( cs_mesh_t *  mesh)
◆ cs_renumber_i_faces_by_gnum()
void cs_renumber_i_faces_by_gnum ( cs_mesh_t *  mesh)
◆ cs_renumber_mesh()
void cs_renumber_mesh ( cs_mesh_t *  mesh,
cs_lnum_t **  cell_n2o,
cs_lnum_t **  i_face_n2o,
cs_lnum_t **  b_face_n2o,
cs_lnum_t **  vtx_n2o
Renumbering cells may also allow improving locality (and favor faces renumbering). It is also possible to place cells connected to ghost cells last, which may be useful to enable computation/communication overlap.
If new_to_old pointers are provided, the new to old mappings will be passed to this pointer. The caller then takes ownership and is responsible for freeing them
[in,out]cell_n2opointer to new to old cells array, or null
[in,out]i_face_n2opointer to new to old interior faces array, or null
[in,out]b_face_n2opointer to new to old boundary faces array, or null
[in,out]vtx_n2opointer to new to old vertices array, or null
◆ cs_renumber_set_algorithm()
void cs_renumber_set_algorithm ( bool  halo_adjacent_cells_last,
[in]halo_adjacent_cells_lastif true, cells adjacent to ghost cells will be placed last (after pre-numbering)
[in]halo_adjacent_faces_lastif true, interior faces adjacent to ghost cells will be placed last (after pre-numbering)
[in]i_faces_base_orderingpre-ordering of interior faces by lowest or highest adjacent cell id
[in]cells_pre_numberingalgorithm for cells pre-numbering
[in]cells_numberingalgorithm for cells numbering
[in]i_faces_numberingalgorithm for interior faces numbering
[in]b_faces_numberingalgorithm for boundary faces numbering
[in]vertices_numberingalgorithm for vertices numbering
◆ cs_renumber_set_min_subset_size()
void cs_renumber_set_min_subset_size ( cs_lnum_t  min_i_subset_size,
[in]min_i_subset_sizeminimum number of interior faces per thread per group
[in]min_b_subset_sizeminimum number of boundary faces per thread per group
◆ cs_renumber_set_multipass_rebalance_factor()
void cs_renumber_set_multipass_rebalance_factor ( float  relaxation_factor)
A relaxation factor of 0 disables rebalancing.
Depending on the mesh numbering, rebalancing may interfere with the multigrid algorithm's coarsening, especially in the presence of cell renumbering. In some cases, the coarsening will be less constrained and lead to better aggregation (and performance) when combining cells renumbering and multipass interior faces renumbering with no reblancing (i. e. with a relaxation factor of 0).
[in]relaxationfactor multipass renumbering rebalance step relaxation factor.
◆ cs_renumber_set_n_threads()
void cs_renumber_set_n_threads ( int  n_threads)
By default, the target number of threads is set to cs_glob_n_threads, but the value may be forced using this function. This is mainly useful for testing purposes.
[in]n_threadstarget number of threads for mesh numbering
◆ cs_renumber_vertices()
void cs_renumber_vertices ( cs_mesh_t *  mesh)
