cs_pressure_correction.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "alge/cs_blas.h"
#include "base/cs_ale.h"
#include "base/cs_array.h"
#include "base/cs_base_accel.h"
#include "base/cs_equation_iterative_solve.h"
#include "base/cs_field.h"
#include "base/cs_halo.h"
#include "base/cs_log.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_post.h"
#include "base/cs_reducers.h"
#include "base/cs_runge_kutta_integrator.h"
#include "base/cs_sat_coupling.h"
#include "base/cs_velocity_pressure.h"
#include "base/cs_vof.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_wall_condensation.h"
#include "alge/cs_balance.h"
#include "alge/cs_convection_diffusion.h"
#include "alge/cs_divergence.h"
#include "alge/cs_face_viscosity.h"
#include "alge/cs_gradient.h"
#include "alge/cs_matrix_building.h"
#include "alge/cs_sles_default.h"
#include "lagr/cs_lagr.h"
#include "atmo/cs_air_props.h"
#include "atmo/cs_atmo.h"
#include "cfbl/cs_cf_compute.h"
#include "cfbl/cs_cf_thermo.h"
#include "alge/cs_bad_cells_regularisation.h"
#include "base/cs_pressure_correction.h"
+ Include dependency graph for cs_pressure_correction.cpp:
Macros
#define CS_PRESSURE_CORRECTION_CDO_DBG   0
static void _hydrostatic_pressure_compute (const cs_mesh_t *m, cs_mesh_quantities_t *mq, int *indhyd, int iterns, const cs_real_t frcxt[][3], const cs_real_t dfrcxt[][3], cs_real_t cvar_hydro_pres[], cs_real_t iflux[], cs_real_t bflux[], cs_real_t dphi[], cs_real_t rhs[])
 Poisson equation resolution for hydrostatic pressure: $ \divs ( \grad P ) = \divs ( f ) $. More...
static void _pressure_correction_fv (int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[], cs_lnum_t ltmast[], const int isostd[], cs_real_t vel[][3], cs_real_t da_uu[][6], cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_dp, cs_real_t spcond[], cs_real_t svcond[], cs_real_t frcxt[][3], cs_real_t dfrcxt[][3])
 Perform the pressure correction step of the Navier-Stokes equations for incompressible or slightly compressible flows. More...
static void _pressure_correction_cdo (cs_real_t vel[][3], cs_field_bc_coeffs_t *bc_coeffs_v)
static cs_pressure_correction_cdo_t * _pressure_correction_cdo_create (void)
 Create and initialize a cs_pressure_correction_cdo_t structure. More...
void cs_pressure_correction_fv_activate (void)
 Activate the pressure increment solving with Legacy FV. More...
void cs_pressure_correction_cdo_activate (void)
 Activate the pressure increment solving with CDO. More...
void cs_pressure_correction_model_activate (void)
 Activate the pressure increment, either FV or CDO. More...
bool cs_pressure_correction_cdo_is_activated (void)
 Test if pressure solving with CDO is activated. More...
void cs_pressure_correction_cdo_init_setup (void)
 Start setting-up the pressure increment equation At this stage, numerical settings should be completely determined but connectivity and geometrical information is not yet available. More...
void cs_pressure_correction_cdo_finalize_setup (const cs_domain_t *domain)
 Finalize setting-up the pressure increment equation At this stage, numerical settings should be completely determined. More...
void cs_pressure_correction_cdo_destroy_all (void)
 Free the main structure related to the pressure correction. More...
void cs_pressure_correction (int iterns, cs_lnum_t nfbpcd, cs_lnum_t ncmast, cs_lnum_t ifbpcd[], cs_lnum_t ltmast[], const int isostd[], cs_real_t vel[][3], cs_real_t da_uu[][6], cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_dp, cs_real_t spcond[], cs_real_t svcond[], cs_real_t frcxt[][3], cs_real_t dfrcxt[][3])
static const char _err_empty_prcdo []
static bool cs_pressure_correction_cdo_active = false
static cs_pressure_correction_cdo_t * cs_pressure_correction_cdo = nullptr
Pressure correction step.
◆ CS_PRESSURE_CORRECTION_CDO_DBG
◆ _hydrostatic_pressure_compute()
static void _hydrostatic_pressure_compute ( const cs_mesh_t *  m,
cs_mesh_quantities_t *  mq,
int *  indhyd,
int  iterns,
cs_real_t  iflux[],
cs_real_t  bflux[],
cs_real_t  dphi[],
cs_real_t  rhs[]
static
[in]mpointer to glob mesh
[in]mqpointer to glob mesh quantiites
[out]need_updateindicator for cvar_hydro_pres update
[in]iternsNavier-Stokes iteration number
[in]frcxtexternal force generating hydrostatic pressure
[in]dfrcxtexternal force increment generating hydrostatic pressure
[out]cvar_hydro_preshydrostatic pressure increment
[in]ifluxwork array
[in]bfluxwork array
[out]dphiwork array
[in,out]rhswork array
◆ _pressure_correction_cdo()
static void _pressure_correction_cdo ( cs_real_t  vel[][3],
cs_field_bc_coeffs_t *  bc_coeffs_v
static
Remarks
  • CDO face-based scheme is used to solve the Poisson equation.
    - DIV \cdot Hdg \cdot GRAD \left(\delta p \right) =
- \divs \left( \rho \vect{\widetilde{u}}\right)
    The mass flux is then updated as follows:
 \dot{m}^{n+1} = \dot{m}^{n}
                - Hodge \cdot GRAD \left(\delta p \right)
[in]velvelocity values
[in]bc_coeffs_vboundary condition coefficients
◆ _pressure_correction_cdo_create()
static cs_pressure_correction_cdo_t * _pressure_correction_cdo_create ( void  )
static
a pointer to a newly allocated cs_pressure_correction_cdo_t structure
◆ _pressure_correction_fv()
static void _pressure_correction_fv ( int  iterns,
cs_lnum_t  nfbpcd,
cs_lnum_t  ncmast,
cs_lnum_t  ifbpcd[],
cs_lnum_t  ltmast[],
const int  isostd[],
cs_real_t  vel[][3],
cs_field_bc_coeffs_t *  bc_coeffs_v,
cs_field_bc_coeffs_t *  bc_coeffs_dp,
cs_real_t  spcond[],
cs_real_t  svcond[],
static
    D \left( \Delta t, \delta p \right) =
    - \Gamma^n
    + \dfrac{\rho^n - \rho^{n-1}}{\Delta t}
 \dot{m}^{n+1}_\ij = \dot{m}^{n}_\ij
                   - \Delta t \grad_\fij \delta p \cdot \vect{S}_\ij
Remarks
  • an iterative process is used to solve the Poisson equation.
  • if the arak coefficient is set to 1, the Rhie & Chow filter is activated.
[in]nfbpcdnumber of faces with condensation source term
[in]ncmastnumber of cells with condensation source terms
[in]ifbpcdindex of faces with condensation source term
[in]ltmastlist of cells with condensation source terms (1 to n numbering)
[in]isostdindicator of standard outlet and index of the reference outlet face
[in]velvelocity
[in,out]da_uuvelocity matrix
[in]bc_coeffs_vboundary condition structure for the variable
[in]bc_coeffs_dpboundary conditions structure for the pressure increment
[in]spcondvariable value associated to the condensation source term (for ivar=ipr, spcond is the flow rate $ \Gamma_{s,cond}^n $)
[in]svcondvariable value associated to the condensation source term (for ivar=ipr, svcond is the flow rate $ \Gamma_{v, cond}^n $)
[in]frcxtexternal forces making hydrostatic pressure
[in]dfrcxtvariation of the external forces composing the hydrostatic pressure
◆ cs_pressure_correction()
void cs_pressure_correction ( int  iterns,
cs_lnum_t  nfbpcd,
cs_lnum_t  ncmast,
cs_lnum_t  ifbpcd[],
cs_lnum_t  ltmast[],
const int  isostd[],
cs_real_t  vel[][3],
cs_real_t  spcond[],
cs_real_t  svcond[],
    - \Gamma^n
Either the legacy FV method or a CDO face-based scheme is used.
For the legacy case, the mass flux is updated as follows:
Remarks
[in]velvelocity
◆ cs_pressure_correction_cdo_activate()
void cs_pressure_correction_cdo_activate ( void  )
◆ cs_pressure_correction_cdo_destroy_all()
void cs_pressure_correction_cdo_destroy_all ( void  )
◆ cs_pressure_correction_cdo_finalize_setup()
void cs_pressure_correction_cdo_finalize_setup ( const cs_domain_t *  domain)
[in]domainpointer to a cs_domaint_t structure
◆ cs_pressure_correction_cdo_init_setup()
void cs_pressure_correction_cdo_init_setup ( void  )
◆ cs_pressure_correction_cdo_is_activated()
bool cs_pressure_correction_cdo_is_activated ( void  )
true if solving with CDO is requested, false otherwise
◆ cs_pressure_correction_fv_activate()
void cs_pressure_correction_fv_activate ( void  )
◆ cs_pressure_correction_model_activate()
void cs_pressure_correction_model_activate ( void  )
◆ _err_empty_prcdo
const char _err_empty_prcdo[]
static
Initial value:
" Stop execution. The structure related to the pressure correction is"
" empty.\n Please check your settings.\n"
cs_pressure_correction_cdo_t* cs_pressure_correction_cdo = nullptr
static
◆ cs_pressure_correction_cdo_active
static
