cs_array_reduce.h
1#ifndef CS_ARRAY_REDUCE_H
2#define CS_ARRAY_REDUCE_H
5 * Common array reduction operations.
31 * Local headers
34#include "base/cs_defs.h"
35#include "base/cs_dispatch.h"
36#include "base/cs_reducers.h"
41 * Macro definitions
45 * Type definitions
48/*=============================================================================
49 * Public function prototypes
51
52/*----------------------------------------------------------------------------*/
53/*
54 * \brief Compute the min./max. of a 1-dimensional array.
55 *
56 * \param[in] n local number of elements
57 * \param[in] v pointer to values (size: n)
58 * \param[out] vmin minimum value
59 * \param[out] vmax maximum value
60 */
61/*----------------------------------------------------------------------------*/
62
63void
65 const cs_real_t v[],
66 cs_real_t &vmin,
67 cs_real_t &vmax);
68
69/*----------------------------------------------------------------------------*/
87/*----------------------------------------------------------------------------*/
88
89template <size_t stride>
90void
92 cs_lnum_t n_elts,
93 const cs_lnum_t *v_elt_list,
94 const cs_real_t v[],
95 double vsum[])
96{
97 struct cs_double_n<stride> rd;
98 struct cs_reduce_sum_nr<stride> reducer;
99
100 /* If all values are defined on same list */
101 if (v_elt_list == nullptr) {
102 ctx.parallel_for_reduce(n_elts, rd, reducer,
104 for (size_t k = 0; k < stride; k++)
105 res.r[k] = v[stride*i + k];
106 });
107 }
108 /* If values are defined on parent list */
109 else {
110 ctx.parallel_for_reduce(n_elts, rd, reducer,
112 for (size_t k = 0; k < stride; k++)
113 res.r[k] = v[stride*v_elt_list[i] + k];
114 });
115 }
116 ctx.wait();
117
118 for (size_t k = 0; k < stride; k++)
119 vsum[k] = rd.r[k];
120}
121
122/*----------------------------------------------------------------------------*/
146/*----------------------------------------------------------------------------*/
147
148void
150 const cs_lnum_t n_elts,
151 const int dim,
152 const cs_lnum_t *v_elt_list,
153 const cs_real_t v[],
154 double vmin[],
155 double vmax[],
156 double vsum[]);
157
158/*----------------------------------------------------------------------------*/
185/*----------------------------------------------------------------------------*/
186
187void
189 int dim,
190 const cs_lnum_t *v_elt_list,
191 const cs_lnum_t *w_elt_list,
192 const cs_real_t v[],
193 const cs_real_t w[],
194 double wsum[]);
195
196/*----------------------------------------------------------------------------*/
226/*----------------------------------------------------------------------------*/
227
228void
230 int dim,
231 const cs_lnum_t *v_elt_list,
232 const cs_lnum_t *w_elt_list,
233 const cs_real_t v[],
234 const cs_real_t w[],
235 double wsum[],
236 double wtot[]);
237
238/*----------------------------------------------------------------------------*/
258/*----------------------------------------------------------------------------*/
259
260void
262 int dim,
263 const cs_lnum_t *v_elt_list,
264 const cs_real_t v[],
265 cs_real_t vmin[],
266 cs_real_t vmax[]);
267
268/*----------------------------------------------------------------------------*/
300/*----------------------------------------------------------------------------*/
301
302void
304 cs_lnum_t n_elts,
305 int dim,
306 const cs_lnum_t *v_elt_list,
307 const cs_lnum_t *w_elt_list,
308 const cs_real_t v[],
309 const cs_real_t w[],
310 double vmin[],
311 double vmax[],
312 double vsum[],
313 double wsum[]);
314
315/*----------------------------------------------------------------------------*/
350/*----------------------------------------------------------------------------*/
351
352void
354 int dim,
355 const cs_lnum_t *v_elt_list,
356 const cs_lnum_t *w_elt_list,
357 const cs_real_t v[],
358 const cs_real_t w[],
359 double vmin[],
360 double vmax[],
361 double vsum[],
362 double wsum[],
363 double asum[],
364 double ssum[],
365 double wssum[]);
366
367/*----------------------------------------------------------------------------*/
397/*----------------------------------------------------------------------------*/
398
399void
401 const cs_lnum_t *src2v_idx,
402 const cs_lnum_t *src2v_ids,
403 const cs_lnum_t *filter_list,
404 int dim,
405 cs_lnum_t n_v_elts,
406 const cs_real_t v[],
407 const cs_real_t w[],
408 double vsum[],
409 double asum[],
410 double ssum[]);
411
412/*----------------------------------------------------------------------------*/
413
414#endif /* CS_ARRAY_REDUCE_H */
auto parallel_for_reduce(cs_lnum_t n, T &result, R &reducer, F &&f, Args &&... args)
Definition: cs_dispatch.h:2195
void wait(void)
Wait (synchronize) until launched computations have finished.
Definition: cs_dispatch.h:2211
Definition: cs_dispatch.h:2288
void cs_array_reduce_sum_l(cs_dispatch_context ctx, cs_lnum_t n_elts, const cs_lnum_t *v_elt_list, const cs_real_t v[], double vsum[])
Compute sums of an n-dimensional cs_real_t array's components.
Definition: cs_array_reduce.h:91
void cs_array_reduce_minmax(cs_lnum_t n, const cs_real_t v[], cs_real_t &vmin, cs_real_t &vmax)
Definition: cs_array_reduce.cpp:2672
void cs_array_reduce_simple_norms_l(cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double vmin[], double vmax[], double vsum[], double wsum[], double asum[], double ssum[], double wssum[])
Compute simple local stats and norms (minima, maxima, sum, weighted sum, sum of absolute values,...
Definition: cs_array_reduce.cpp:3125
void cs_array_reduce_wsum_components_l(cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double wsum[], double wtot[])
Compute weighted sums of an n-dimensional cs_real_t array's components. Output is both weighted sum a...
Definition: cs_array_reduce.cpp:2884
void cs_array_reduce_simple_stats_l(cs_dispatch_context ctx, const cs_lnum_t n_elts, const int dim, const cs_lnum_t *v_elt_list, const cs_real_t v[], double vmin[], double vmax[], double vsum[])
Compute simple local stats (minima, maxima, sum) of an n-dimensional cs_real_t array's components.
Definition: cs_array_reduce.cpp:2735
void cs_array_reduce_simple_stats_l_w(cs_dispatch_context ctx, cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double vmin[], double vmax[], double vsum[], double wsum[])
Compute simple local stats (minima, maxima, sum, weighted sum) of an n-dimensional cs_real_t array's ...
Definition: cs_array_reduce.cpp:3024
void cs_array_reduce_minmax_l(cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_real_t v[], cs_real_t vmin[], cs_real_t vmax[])
Definition: cs_array_reduce.cpp:2956
void cs_array_reduce_wsum_l(cs_lnum_t n_elts, int dim, const cs_lnum_t *v_elt_list, const cs_lnum_t *w_elt_list, const cs_real_t v[], const cs_real_t w[], double wsum[])
Definition: cs_array_reduce.cpp:2803
void cs_array_scatter_reduce_norms_l(cs_lnum_t n_src_elts, const cs_lnum_t *src2v_idx, const cs_lnum_t *src2v_ids, const cs_lnum_t *filter_list, int dim, cs_lnum_t n_v_elts, const cs_real_t v[], const cs_real_t w[], double vsum[], double asum[], double ssum[])
Compute simple local weighted norms (l1, l2) of an n-dimensional cs_real_t array's components The wei...
Definition: cs_array_reduce.cpp:3215
#define CS_F_HOST_DEVICE
Definition: cs_defs.h:555
Definition: cs_defs.h:332
Definition: cs_defs.h:325
@ k
Definition: cs_reducers.h:62
double r[stride]
Definition: cs_reducers.h:63
Definition: cs_reducers.h:217
