1#ifndef CS_FIELD_OPERATOR_H
2#define CS_FIELD_OPERATOR_H
Field boundary condition descriptor (for variables)
Definition: cs_field.h:107
Definition: cs_field.h:275
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:351
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:358
Definition: cs_defs.h:325
cs_real_t cs_real_63_t[6][3]
Definition: cs_defs.h:366
void cs_field_local_extrema_scalar(int f_id, cs_halo_type_t halo_type, cs_real_t *local_max, cs_real_t *local_min)
Find local extrema of a given scalar field at each cell.
Definition: cs_field_operator.cpp:1359
cs_field_interpolate_t
Definition: cs_field_operator.h:50
@ CS_FIELD_INTERPOLATE_MEAN
Definition: cs_field_operator.h:52
@ CS_FIELD_INTERPOLATE_GRADIENT
Definition: cs_field_operator.h:53
void cs_field_gradient_boundary_iprime_scalar(const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t var_iprime[])
Compute the values of a scalar field at boundary face I' positions.
Definition: cs_field_operator.cpp:815
void cs_field_gradient_boundary_iprime_vector(const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_3_t var_iprime[])
Compute the values of a vector field at boundary face I' positions.
Definition: cs_field_operator.cpp:990
void cs_field_gradient_tensor(const cs_field_t *f, bool use_previous_t, int inc, cs_real_63_t *grad)
void cs_field_synchronize(cs_field_t *f, cs_halo_type_t halo_type)
Synchronize current parallel and periodic field values.
Definition: cs_field_operator.cpp:1448
void cs_field_set_volume_average(cs_field_t *f, const cs_real_t mean)
Shift field values in order to set its spatial average to a given value.
Definition: cs_field_operator.cpp:1402
void cs_field_gradient_vector(const cs_field_t *f, bool use_previous_t, int inc, cs_real_33_t *grad)
void cs_field_gradient_scalar(const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *grad)
void cs_field_gradient_potential(const cs_field_t *f, bool use_previous_t, int inc, int hyd_p_flag, cs_real_3_t f_ext[], cs_real_3_t *grad)
void cs_field_gradient_boundary_iprime_tensor(const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_6_t var_iprime[])
Compute the values of a symmetric tensor field at boundary face I' positions.
Definition: cs_field_operator.cpp:1154
void cs_field_interpolate(cs_field_t *f, cs_field_interpolate_t interpolation_type, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], cs_real_t *val)
Interpolate field values at a given set of points.
Definition: cs_field_operator.cpp:1315
void cs_field_gradient_scalar_array(int f_id, int inc, cs_field_bc_coeffs_t *bc_coeffs, cs_real_t var[], cs_real_3_t grad[])
Compute cell gradient of scalar array using parameters associated with a given field.
Definition: cs_field_operator.cpp:435
cs_halo_type_t
Definition: cs_halo.h:53
