cs_field_operator.h File Reference
#include "base/cs_field.h"
#include "alge/cs_gradient.h"
+ Include dependency graph for cs_field_operator.h:
Enumerations
enum  cs_field_interpolate_t { CS_FIELD_INTERPOLATE_MEAN , CS_FIELD_INTERPOLATE_GRADIENT }
void cs_field_gradient_scalar (const cs_field_t *f, bool use_previous_t, int inc, cs_real_3_t *grad)
void cs_field_gradient_scalar_array (int f_id, int inc, cs_field_bc_coeffs_t *bc_coeffs, cs_real_t var[], cs_real_3_t grad[])
 Compute cell gradient of scalar array using parameters associated with a given field. More...
void cs_field_gradient_potential (const cs_field_t *f, bool use_previous_t, int inc, int hyd_p_flag, cs_real_3_t f_ext[], cs_real_3_t *grad)
void cs_field_gradient_vector (const cs_field_t *f, bool use_previous_t, int inc, cs_real_33_t *grad)
void cs_field_gradient_tensor (const cs_field_t *f, bool use_previous_t, int inc, cs_real_63_t *grad)
void cs_field_gradient_boundary_iprime_scalar (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_t var_iprime[])
 Compute the values of a scalar field at boundary face I' positions. More...
void cs_field_gradient_boundary_iprime_vector (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_3_t var_iprime[])
 Compute the values of a vector field at boundary face I' positions. More...
void cs_field_gradient_boundary_iprime_tensor (const cs_field_t *f, bool use_previous_t, cs_lnum_t n_faces, const cs_lnum_t *face_ids, cs_real_6_t var_iprime[])
 Compute the values of a symmetric tensor field at boundary face I' positions. More...
void cs_field_interpolate (cs_field_t *f, cs_field_interpolate_t interpolation_type, cs_lnum_t n_points, const cs_lnum_t point_location[], const cs_real_3_t point_coords[], cs_real_t *val)
 Interpolate field values at a given set of points. More...
void cs_field_local_extrema_scalar (int f_id, cs_halo_type_t halo_type, cs_real_t *local_max, cs_real_t *local_min)
 Find local extrema of a given scalar field at each cell. More...
void cs_field_set_volume_average (cs_field_t *f, const cs_real_t mean)
 Shift field values in order to set its spatial average to a given value. More...
void cs_field_synchronize (cs_field_t *f, cs_halo_type_t halo_type)
 Synchronize current parallel and periodic field values. More...
void cs_field_synchronize (cs_field_t *f, cs_halo_type_t halo_type, bool on_device)
◆ cs_field_interpolate_t
Enumerator
Mean element value (P0 interpolation)
Mean element value + gradient correction (pseudo-P1)
◆ cs_field_gradient_boundary_iprime_scalar()
void cs_field_gradient_boundary_iprime_scalar ( const cs_field_t *  f,
cs_lnum_t  n_faces,
const cs_lnum_t *  face_ids,
[in]fpointer to field
[in]use_previous_tshould we use values from the previous time step ?
[in]incif 0, solve on increment; 1 otherwise
[out]gradgradient
◆ cs_field_gradient_boundary_iprime_tensor()
void cs_field_gradient_boundary_iprime_tensor ( const cs_field_t *  f,
cs_lnum_t  n_faces,
[out]gradgradient
◆ cs_field_gradient_boundary_iprime_vector()
void cs_field_gradient_boundary_iprime_vector ( const cs_field_t *  f,
cs_lnum_t  n_faces,
[out]gradgradient
◆ cs_field_gradient_potential()
void cs_field_gradient_potential ( const cs_field_t *  f,
int  inc,
int  hyd_p_flag,
cs_real_3_t *  grad
◆ cs_field_gradient_scalar()
void cs_field_gradient_scalar ( const cs_field_t *  f,
int  inc,
cs_real_3_t *  grad
◆ cs_field_gradient_scalar_array()
void cs_field_gradient_scalar_array ( int  f_id,
int  inc,
cs_field_bc_coeffs_t *  bc_coeffs,
cs_real_t  var[],
cs_real_3_t  grad[]
[in]f_idassociated field id
[in]bc_coeffsboundary condition structure
[in,out]vargradient's base variable
[out]gradgradient
◆ cs_field_gradient_tensor()
void cs_field_gradient_tensor ( const cs_field_t *  f,
int  inc,
cs_real_63_t *  grad
◆ cs_field_gradient_vector()
void cs_field_gradient_vector ( const cs_field_t *  f,
int  inc,
cs_real_33_t *  grad
◆ cs_field_interpolate()
void cs_field_interpolate ( cs_field_t *  f,
cs_lnum_t  n_points,
cs_real_t *  val
[in]interpolation_typeinterpolation type
[in]n_pointsnumber of points at which interpolation is required
[in]point_locationlocation of points in mesh elements (based on the field location)
[in]point_coordspoint coordinates
[out]valinterpolated values
◆ cs_field_local_extrema_scalar()
void cs_field_local_extrema_scalar ( int  f_id,
cs_real_t *  local_max,
cs_real_t *  local_min
This assumes the field values have been synchronized.
[in]f_idscalar field id
[in]halo_typehalo type
[in,out]local_maxlocal maximum value
[in,out]local_minlocal minimum value
◆ cs_field_set_volume_average()
void cs_field_set_volume_average ( cs_field_t *  f,
const cs_real_t  va
[in]vareal value of volume average to be set
[in]vareal value of fluid volume average to be set
◆ cs_field_synchronize() [1/2]
void cs_field_synchronize ( cs_field_t *  f,
This function currently only upates fields based on CS_MESH_LOCATION_CELLS.
[in,out]fpointer to field
◆ cs_field_synchronize() [2/2]
bool  on_device
[in]on_devicespecify whether sync is done on device
